Author Topic: Best kept secret or early April fools joke?  (Read 30221 times)
Online Bulldog9
Re: Best kept secret or early April fools joke?
« Reply #30 on: December 15, 2025, 08:24:24 PM »
Walk around…? https://youtu.be/W9ulUhJgVwk?feature=shared
When you put a proper headlight on it, and it goes missing, you will find it in my garage.........  :cool:
I was thinking the other day that being that I turned the V7ii Stornello into a V85 alternative, I should buy a V85 and turn it into a V7 Sport Alternative. Maybe after I sell a couple....... The Stable is over filled.
MGNOC#23231
« Reply #31 on: December 15, 2025, 09:05:26 PM »
Is that the one that now has many silver parts instead of black?
Yes.
Engine is next.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #32 on: December 15, 2025, 09:47:33 PM »
Yes.
Engine is next.
Silver looks better!
Although some of the off colors like copper, graphite, or a variant of olive green might also look good.  the old Kal-Gard colors come to mind.
I used some of this on a DR650 790cc cylinder.  Just a touch different from the OEM engine color.
https://www.walmart.com/ip/Duplicolor-DE1651-3-Pack-Engine-Enamel-with-Ceramic-Cast-Coat-Iron-Color-12-oz/813965043
« Last Edit: December 15, 2025, 09:59:08 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
« Reply #33 on: December 16, 2025, 04:13:17 AM »
Getting the old stuff off is the thing.
I’d like to get it done with dry ice blasting, the CO2 just melts then gasses off.
« Reply #34 on: December 16, 2025, 04:16:55 AM »
Also, speaking with Pete Roper today, he enlightened me in a couple of areas regarding boring and stroking small blocks.
The crank will most usually crash into other metal stuff in there and it becomes impossible to control the crankcase presssure via conventional venting etc..
Just a royal PITA and you hit the limit of a whole lot of parameters.
« Reply #35 on: December 16, 2025, 05:56:47 AM »
Smallblock motor is at it's end for enlargement but you could charge it w/a blower to blow the heads off!!
Offline sdcr
« Reply #36 on: December 16, 2025, 01:24:51 PM »
https://www.youtube.com/watch?v=41kBl7VH0pI
If this is in fact real there will be a red one at my house.
If this were a real Moto Guzzi, and not an AI dream bike, it would probably list for $18,000-$24,000.
One could build a similar MC a platform, using an 1100 EV, and adding seats, bars, etc from any past Tonti frame machines. I can’t imagine one would need to spend more than $10,000, to create a very nice one.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Online PeteS
« Reply #37 on: December 16, 2025, 02:16:30 PM »
Put the V85 motor in a V7. Could easily be tuned to make 100 HP or more as an 850. Not superbike territory but at least be able to keep up with 750 Sportbikes. Just for reference the new Norton Manxman makes 206HP with a 4 cylinder 1200 or 103 HP from 600cc. Likely cut into V100 sales thiugh.
« Reply #38 on: December 16, 2025, 03:59:09 PM »
So what is the displacement of the current V85 mill and how will it “easily be tuned” to get a 100 horse power figure …? :popcorn:
« Last Edit: December 16, 2025, 04:00:17 PM by Huzo »
Online Bulldog9
« Reply #39 on: December 16, 2025, 04:49:48 PM »
The crank will most usually crash into other metal stuff in there and it becomes impossible to control the crankcase pressure via conventional venting etc..
Hear me out. Keep the same crankshaft, and head and pistons unchanged, but increase the stroke and use longer connecting rods, and taller jugs (cyls). My pea brain says to get to 950, you'd need to increase stroke/length by: (follow my ramble)
The current V85 is an oversquare motor - Bore = 84 mm (0.084 m) Stroke = 77 mm (0.077 m).
If you kept the 84mm bore, and went undersquare and used a 86mm stroke (9mm increase) by using taller Cyls and CRs, you'd be at 953cc.
The only real problem I would see with this is clearance at the case/lower cyl opening for the CR, but if youre making new CR's you can adjust for that. This is the red suspender snapping approach and only requires new 9mm longer Connecting Rods and Cyls. Heck, depending on the length of the CYL sleeve in the jug, you might be able to get away with a 9mm spacer and new CR's.
Keeping with the same insanity, increasing bore to 85mm is more involved, new pistons, remachining heads for larger jugs (maybe) but bumps displacement to 978CC.....
Both are close enough to call it a 1000 and you'd have a torquey little motor, but less potential power at the top end.
I've been round and round with Pete on this years ago, and I respect the man, but don't agree. Neither do I have the machine shop capabilities to do this. But in my mind, a 9mm (.34in) increase in stroke and cyl height isn't a bridge too far, nor is a 1mm increase in bore.
Pardon my geeking out, this is leftover slag from my time building High Powered NA VW/Porsche Type IV motors. If I had the ability and resources, I'd do it. Again,  The ONLY real problem I see here is that the CR's could touch the case where the cyls insert, and properly fashioned CRs could be used to offset that potential.
I know, I know, you will say that the Guzzi Engineers would have done it if possible, but hey, they aren't even able to properly grease swing arm and steering yoke bearings.........  :popcorn: :evil:
MGNOC#23231
Online Bulldog9
« Reply #40 on: December 16, 2025, 04:52:53 PM »
Yeah, but why? the rest of the V7 is not made for that kind of power or speed......
MGNOC#23231
Online Moparnut72
« Reply #41 on: December 16, 2025, 05:24:01 PM »
I don't think V7 buyers would be interested in that level of power. I know I wouldn't, my '26 V7 has quite a bit of power. However I haven't been able to see how much passing power it has at 80 or 90 mph. The Mandello had more than I ever used, I had it up to 113 mph corrected on a long line of cars out in the middle of Nevada. Would that much power be a good idea on the V7's frame which wasn't designed for it.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online PeteS
« Reply #42 on: December 16, 2025, 05:54:24 PM »
I am talking about a modern LeMans. Not a touring bike. My 50 year old LeMans can handle 130 MPH without flinching with far more primative suspension.
Ducati 851s were making 110 HP over 30 years ago without variable valve timing. The V100 is fine sport touring bike but fairly heavy for a pure sport bike. Why do you think a V7 couldn’t handle 150 MPH?
« Last Edit: December 16, 2025, 05:57:38 PM by PeteS »
Online bad Chad
« Reply #43 on: December 16, 2025, 07:42:03 PM »
Pete Roper has said there is no way a modern Guzzi 850 can make a reliable 100plus HP, period  It's amazing they are able to get 80hp out of it.
1988 YX600 Radian
Online SIR REAL ED
« Reply #44 on: December 16, 2025, 07:46:15 PM »
You need to turn the idle up on that beast.  Sound too Harley-ish....
2002 MZ Skorpion
1994 DR Skorpion
Online SIR REAL ED
« Reply #45 on: December 16, 2025, 07:56:12 PM »
I think you meant to say the 9mm more stoke has to come from the crank itself (move the crank pin 4.5mm away from center), then shorten the connecting rod by 4.5mm.  IIRC, that is how Powroll used to stroke the Honda single cylinder engines.
I might be misconstruing something.....
2002 MZ Skorpion
1994 DR Skorpion
« Reply #46 on: December 16, 2025, 09:04:26 PM »
How will you increase the stroke if you retain the same crank ?
« Reply #47 on: December 16, 2025, 09:44:51 PM »
If Norton steals 100 sales from anybody I'll be amazed.
Online Bulldog9
« Reply #48 on: December 17, 2025, 05:42:51 AM »
LOL, sorry for the distraction, ignore the maroon in the corner............. . Playing around with the idea of an "April Fools Joke" Seemed funny yesterday :popcorn:
« Last Edit: December 17, 2025, 05:44:19 AM by Bulldog9 »
MGNOC#23231
Offline TN Mark
« Reply #49 on: December 17, 2025, 06:33:57 AM »
Not a distraction at all. Alternative and optional ideas and questions are quite good and should be welcomed.
Online SIR REAL ED
« Reply #50 on: December 17, 2025, 06:40:00 AM »
I think the quest for the Magical Moto Guzzi needs to continue.
Once upon a time, Moto Guzzi engineers thought invisible grease was an impossible goal.
Lick your wounds and carry on.
"To a wise man, every day is a new life!"
"One foot in front of the other, soldier, one foot in front of the other...."
2002 MZ Skorpion
1994 DR Skorpion
Offline TN Mark
« Reply #51 on: December 17, 2025, 07:19:01 AM »
A stock V85 (853cc) makes about 65 rwhp. It can easily make about 83rwhp with readily available intake, tuning and exhaust mods. That’s a 27% increase over stock which is really quite impressive.
Can it make 100rwhp? Not without significant modifications in its inherent design. These modifications simply aren’t at all readily available. Neither is there anyone building the parts to take the V85 to the 100rwhp mark.
An 853cc V-Twin can absolutely be designed to make 100rwhp. The current Moto Guzzi V85 V-Twin just isn’t among the 100rwhp group.
If the Moto Guzzi V85 engine, transmission, frame, drivetrain etc can’t handle 100rwhp, I’d suggest that’s a design flaw from the start.
« Last Edit: December 17, 2025, 07:25:23 AM by TN Mark »
« Reply #52 on: December 17, 2025, 09:01:47 PM »
Actually, I think you meant “moron in the corner…”
Online Bulldog9
« Reply #53 on: December 18, 2025, 04:39:25 AM »
Of course....
https://share.google/images/vEn2e1FzT6fM49t5l
MGNOC#23231
Online SIR REAL ED
« Reply #54 on: December 18, 2025, 08:02:36 AM »
Of course....
I knew exactly what Bulldog9 meant.  I always think of a picture I saw taken at some protest of a neck beard holding a sign that said"
"YOUR A BUNCH OF MORANS!"
2002 MZ Skorpion
1994 DR Skorpion
« Reply #55 on: December 18, 2025, 01:09:18 PM »
Ahhh yes.
Now I get it, that angle makes it funny…. :boozing: :thumb: :weiner:
Online Bulldog9
« Reply #56 on: December 18, 2025, 07:53:25 PM »
Ahhh yes.
It's a more polite way to call someone (or one's self) a Moron........... Sorry Huzo  lol........... Too many Saturday Mornings listening to Looney Toons.............. . It's also where I got my education and exposure to Classical Music.
I just thought I'd have some fun with it. Then the next morning, the mood passed to keep it going.
BUt back on Topic, I would really like to see variations of the V85 with a proper headlight, lowered suspension, small fairing, more performance than a V7 but less than the V100..... It's a gap that could and should be exploited.
MGNOC#23231
Offline cloudbase
« Reply #57 on: December 20, 2025, 08:02:36 AM »
According to the video, the V120 has that new transverse engine.
« Reply #58 on: December 20, 2025, 08:08:34 AM »
If you're really chasing horsepower, wouldn't one ditch the shaft for a chain?
Online PilotJet
« Reply #59 on: December 20, 2025, 10:31:35 AM »
A large under seat storage compartment for small essentials? Is that like jumbo shrimp?
