Author Topic: Increase in valve clearance.  (Read 16785 times)
Offline GuzziNZ
« on: January 10, 2026, 01:32:09 PM »
The valve clearance on both sides for the intake valves is spot on at TDC but as the engine is advance past TDC the clearance doubles.
Any ideas?
Re: Increase in valve clearance.
« Reply #1 on: January 10, 2026, 01:53:45 PM »
How sure are you about TDC compression for each cylinder?
« Reply #2 on: January 10, 2026, 01:59:55 PM »
Any ideas?
What bike is it and have you had the camchain sprockets off ?
Has the woodruff key in the crank or camwheel sprocket sheared off ?
Are you winding the crank in the correct direction ?
Unless you have a liquid cooled V100 variant, it should be rotated clockwise when viewed from the front.
It sounds like the camshaft is not in exactly the right position when you are at TDC, how are you determining TDC ?
Also for clarity, it can be counterintuitive to use the term “advanced past TDC”. Although we all know to what you are referring, the term “advanced” in this context suggests a crank position before TDC.
A suggestion is to say, ”continued in direction of normal rotation”.
Also are you sure you are on the compression stroke ?
Is the problem only on the intake valve/s ?
If the exhaust valves are reading ok, then it’s not a timing thing, because you only have one camshaft.
« Last Edit: January 10, 2026, 02:05:16 PM by Huzo »
« Reply #3 on: January 10, 2026, 02:06:09 PM »
As long as there is any clearance at all, then the valve is closed. The compression value is immaterial, but if you are asking what stroke he is on, then ok.
« Last Edit: January 10, 2026, 02:08:42 PM by Huzo »
« Reply #4 on: January 10, 2026, 02:18:48 PM »
 :rolleyes:
What would you like to explain to me that's obvious next?
I'm not making any assumptions, but I'm also not trying to figure out ALL possibilities first.
So step 1 start with the most basic thing possible, assess the understanding of and certainty that the op actually has the motor at TDC compression each time.
Offline Mr Revhead
« Reply #5 on: January 10, 2026, 02:39:19 PM »
The marks on the flywheel (the lines ABOVE the D, right and S, left) are not always at full slack on the cam.  So set the correct setting at the correct makes and it will be right. This is from Guzziology
I'm assuming yours is 0.22?
I just set the T5 last weekend, a set it to a tight 0.22 and seems good.
« Reply #6 on: January 10, 2026, 04:36:14 PM »
:rolleyes:
Jeezuss Kev, please don’t start one of your things..
Your quaint one liner, whilst adequately descriptive to you as the author, was incomplete in its nature.
What does “how sure are you about compression” actually mean ?
PSI value ?
Equal on both sides ?
Were you enquiring as to whether he was on the correct stroke ?
People read what you say, not what you meant to say.
Please don’t pivot now and take the dialogue somewhere else and drift the thread.
Can we go back to the subject matter, no one’s lost an eye…yet.
« Reply #7 on: January 10, 2026, 05:01:44 PM »
PSI value ?
 :rolleyes:  :rolleyes: :rolleyes:
WTF would someone mean when asking about valve adjustments?
Sorry, my sentence lacked an "at" how sure he was about being AT TDC COMPRESSION....
« Last Edit: January 10, 2026, 05:03:17 PM by Kev m »
« Reply #8 on: January 10, 2026, 05:34:13 PM »
No need to be sorry Kev, I know you’re a rough and tumble type of guy, but if you proof read what you type, things will go better.
Also.
I offered several areas to start because no doubt some will be non applicable and some will have already been investigated. But if I run around long enough waving a weapon in the dark, eventually I’ll have to hit the mark.
As for your opening line …about valve adjustments ?
I go by what you say, not by what you meant to say.
Isn’t that your bread and butter..?
I know you’ll want to take another swipe, but I’ll stop if/when you do.
Can we get back to the bike ?
« Reply #9 on: January 10, 2026, 05:38:26 PM »
Also.
 :rolleyes:
Can't, still waiting on OP to provide more info.
Like answer the obvious....
« Reply #10 on: January 10, 2026, 05:47:04 PM »
I can’t (easily) see how he could be at TDC if he was on the wrong stroke with those symptoms.
At the top of the exhaust stroke, winding the crank over, would close the inlet valve clearance since it’s opening the valve. He says it’s widening the clearance, so it’s closing the valve…
Also in that configuration, there would be zero clearance on the inlet rocker at TDC on the exhaust, because the cam would already have started opening the inlet valve due to the overlap at that point.
I think he’s winding the crank the wrong way and some slack in the timing chain is being taken up by the tensioner being flattened, thus putting the cam timing out by a few degrees.
Just a comment on the obvious… :popcorn:
« Last Edit: January 10, 2026, 05:48:29 PM by Huzo »
Offline GuzziNZ
« Reply #11 on: January 10, 2026, 06:31:33 PM »
Just going to do a few more checks and will come back with what I find but bike is an 850T.
TDC was re-marked during overhaul as it was out a couple of degrees.
Cam timing was set using 1.50mm clearance on intake and was opening within a degree or two of spec.
Cam was in excellent condition and new stein dinse lifter. (Hope they and good quality? )
Unlikely Cam sprocket pin has shared considering the retaining nuts high tightening torque.
Online n3303j
  • Ron Cichowski
« Reply #12 on: January 11, 2026, 08:21:53 AM »
QUOTE "Cam timing was set using 1.50mm clearance on intake and was opening within a degree or two of spec."
That's about 1/16 inch. I assume you meant 0.150 mm clearance which is about 6 thousanths of an inch.
You confirmed TDC mark matched flywheel mark with a straw in the spark plug hole just to confirm the flywheel isn't one bolt off on the bolt circle?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Bulldog9
« Reply #13 on: January 11, 2026, 04:03:39 PM »
To the op. Unless your cam timing is off, you are not at top dead center when you made your first adjustments. The fact that the Gap increased as you continue to turn the motor as proof that you were still on the cam.
Not sure how you're measuring for top dead center, but rule of thumb is to rotate the motor clockwise. Then immediately after the intake valves open and close, the Piston will begin climbing in the cylinder to reach TDC  Best practice is to measure this way. You can use a straw in the spark plug hole and track the Piston till it reaches true top dead center. In this situation, the cam will be off both of the intake and exhaust valve and you can make your adjustments.
MGNOC#23231
Offline GuzziNZ
« Reply #14 on: January 11, 2026, 05:41:54 PM »
I know it sounds strange but cam timing is checked with intake set at 1.50mm clearance.
Once confirmed its correct clearance is set at 0.22.
I watch intake open then close and use a soft rod to confirm when piston is at the top. D or S on flywheel will be close in the bell housing window.
So from TDC I turned engine in stages of about 8 degs.  Intake clearance increased on both sides by about 0.15mm before closing while  exhaust clearance was pretty stable before closing. Seems strange left and right are acting the same.
Online n3303j
  • Ron Cichowski
« Reply #15 on: January 11, 2026, 06:13:50 PM »
I'm confused. I have an 850 T3 and there is never more than set clearance at TDC between the rocker and valve tip.
I once set up a BMW twin on the wrong cylinder timing position.  Surprise, it ran but rocker clearance was very loose and noisy!
No reason for the clearance to open beyond set specifications unless the mechanical relationship between the crank and cam is in error when the setting is made. Possibly timing chain skipped a tooth? Key fell out of a sprocket at assembly? Timing marks between sprockets misaligned at assembly? Flywheel on wrong bolt pattern?
Clearance spec in the manual is 0.22 mm (or 0.00866 inches). No reason for it ever to open past that number. It would just make more noise.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Bulldog9
« Reply #16 on: January 11, 2026, 09:36:33 PM »
I agree he likely has the cam out of timing and probably off by one tooth on the sprocket.
MGNOC#23231
Offline moto-uno
« Reply #17 on: January 13, 2026, 11:59:21 PM »
  Was this motorcycle running well before you took it apart ?
  Your method of checking valve timing sounds correct ( most cam manufacturers suggest around .050" to .060" valve clearance when checking cam timing)
  Your removed the lifters and looked down the lifter bores to check the cam. Are you sure the cam had no wear around the ends of the base circles ?
  Lastly , if you look in the intake ports , do you see heavy carbon deposits around the valve where it enters the valve guide ?
Keep us posted  :thumb:
Offline faffi
« Reply #18 on: January 14, 2026, 02:00:13 AM »
I am with Bulldog9, and likely a few others, that cam timing is likely off.
Have you tried to check valve clearance on the inlet valve when the exhaust is fully open? Or checked the clearance of the inlet valves around the whole closed period, to see if clearance varies around the base circle? It should remain virtually the same other than at each end of the closed period; when it begins to get on the cam, where clearance will begin to reduce towards zero, and from where the valve just close until it is completely off the cam lobe, where clearance should go from zero to base circle value.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
« Reply #19 on: January 14, 2026, 06:11:43 AM »
Which brings us back to my original question.
How certain are you/have you verified that the motor is truly at TDC of the compression stroke for the cylinder in question. If cam timing is off, it is not.
Offline Stretch
« Reply #20 on: January 14, 2026, 06:24:59 AM »
I'd put a skewer/straw in each plug hole, and make sure each cylinder
IS REALLY AT TDC, set the valves, and then one can go back and
check valve timing, etc..
As others have said, it's a good idea to make sure that the engine
is being rotated in the correct direction when lining up timing marks and so forth.
(I was gonna say, "the right way" when describing engine rotation above,
but, "in the correct direction" is far less ambiguous, and MIGHT protect me
from the grammar policeman.....    :evil: :grin: :copcar: :thumb:)
                                                    -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
« Reply #21 on: January 14, 2026, 07:28:30 AM »
Ok, I'll get pedantic.
TDC = the physical position of the piston in the cylinder at the very top of travel. It happens at different times for each cylinder on a twin motor.
But it also is important to remember its relationship to the camshaft and how that controls valve timing
TDC Exhaust = piston top of travel on the exhaust stroke of the 4-stroke cycle (typically this means exhaust valve is open or in the process of closing and the intake is getting ready to open. In both cases there should be basically no lash)
TDC Compression = piston at top of travel on the compression stroke, meaning squeezing the gasses in the sealed combustion chamber. (For this both valves just be closed and intake especially shouldn't be getting ready to open for a while because that shouldn't occur until after the power stroke down and the exhaust stroke up).
But differences in camshaft lobe shape can mean slight differences in when some of the lash is starting to be taken up. And most importantly the timing chain/belt is what preserves the relationship between the crankshaft and camshaft to make these things happen at the right time.
Ok, I'm sorry. I do know that most of your understand these things, but I think some still don't put all the pieces together or forget parts at times (don't we all). But I wanted to spell it out so there was no more misunderstanding of meaning.
Now valve lash IS TYPICALLY checked at TDC OF COMPRESSION for the reasons stated. But honestly you CAN check lash anytime/anywhere in the 4-stroke cycle WHERE the base of the cam lobe is contracting the lifter/pushrod/follower etc.
For instance if the exhaust valve is wide open there's a good chance the intake is completely closed and vice versa.
The OP seems to have a problem where
he's not on TDC compression of the cylinder he's checking when he thinks he is. Whether that's bad camshaft timing, bad timing marks, or a misunderstanding on how to read them, I dunno.
So OP, what do you think it is? How will you check each possibility?
« Reply #22 on: January 14, 2026, 09:05:27 AM »
Tappets move when engine runs, haven't heard if the engine actually runs or is it all bs & all Guzzi motors do this.   I have seen tappets hit the valve covers, does that mean that motor has an issue?  Are you going to say NO it can't do that?  Food for thought on what you are talking about.
Offline GuzziNZ
« Reply #23 on: January 16, 2026, 08:14:28 PM »
So here are my results.
Made up a piston stop and checked TDC. Both sides are within the thickness of the line.
Specs for valve open/close are at 1.50mm valve clearance
IN OPEN 20 BTDC
IN CLOSE 52 ATDC
EX OPEN 52 BBDC
EX CLOSE 20 ATDC.
Only ever checked timing using the right hand cylinder but this time I checked both.
RH cylinder. IN 15 and 52.  EX 51 and 20
LH cylinder. IN 12! and 51. EX 46! and 20.
Fired it up again and no loud tapping this time.
So valve clearance has never moved between checks
As I have never checked LH valve timing I can't say if its changed but funny how both IN and EX open are retarded the same amount pointing to manufacturing tolerance?
Will just keep riding it and scope cam next time sump is off.
« Last Edit: January 16, 2026, 08:16:18 PM by GuzziNZ »
« Reply #24 on: January 17, 2026, 07:01:10 AM »
IN OPEN 20 BTDC
IN CLOSE 52 ATDC
EX OPEN 52 BBDC
EX CLOSE 20 ATDC.
Don't you mean ABDC
AND the unstated obvious is that you're talking:
IN OPEN 20 BTDC of the EXHAUST STROKE
IN CLOSE 52 ABDC of the INTAKE STROKE
EX OPEN 52 BBDC of the POWER STROKE
EX CLOSE 20 ATDC of the EXHAUST STROKE
So the intake valve doesn't "close more" ATDC of the compression stroke.
So I'm still confused how you could see more clearance at the intake slight after either.
Online Bulldog9
« Reply #25 on: January 17, 2026, 07:23:46 AM »
Seems to me you're making it over complicated.
If you truly have the Piston at top dead center on the compression stroke And as you turn the motor past top dead center clearance opens or widens then your cam is not in sync with the crank.
The only changing clearance that should happen as the motor turns past top dead center is that your clearances should close as the cam rotates to open either the intake or the exhaust valves.
MGNOC#23231
Offline GuzziNZ
« Reply #26 on: January 17, 2026, 12:17:57 PM »
All I have show is  that all valve closing to within 1 degree of spec and there is no way to change timing without throwing these out of spec. So I am guessing it is poor manufacturing tolerance or extreme wear and its hard to imagine that the base circle has worn so leaning toward poor manufacturing.
« Last Edit: January 17, 2026, 12:21:02 PM by GuzziNZ »
Online Frenchfrog
« Reply #27 on: January 17, 2026, 01:29:38 PM »
chain wear, slight inaccuracy when measuring.
The kind of difference that you have found is minimal as far as I'm concerned, especially for a road going bike with mileage.
Online acogoff
« Reply #28 on: January 17, 2026, 03:00:36 PM »
     Just drive it with the clearance set to spec at top dead center. My T3 has has had more valve clearance past top dead center for the 47 years I have owned it
 and the engine runs just fine.
Marshall County Minnesota USA
Offline GuzziNZ
« Reply #29 on: January 17, 2026, 11:31:08 PM »
Thanks for reply Acogoff, that's exactly what I'm going to do.
As clearance never seems to change I think it is what it is.
