Author Topic: Stelvio NTX ABS error and no speedo  (Read 8464 times)
Offline Dingo1
« on: February 09, 2026, 01:01:39 AM »
My 2012 Stelvio on a ride noticed ABS error light on constantly and no speedo reading. Have checked all fuses, wiring and earths that I can see. Replaced front and rear (new)  ABS sensors, checked Guzzi Diag for codes, battery is good. To me its like ( as a novice ) that the ABS module has no power hence no wheel sensor data sent back to the module but has voltage at the module on both positive feeds. Checked instrument panel for codes and none logged for panel and ECU.  I'm running out of ideas , help much appreciated.
Offline Bulldog9
Re: Stelvio NTX ABS error and no speedo
« Reply #1 on: February 09, 2026, 09:50:09 AM »
There is a speed sensor on the swingarm. Check the connections and wiring first, but may have to replace it. Not an uncommon problem.
MGNOC#23231
Offline Dingo1
« Reply #2 on: February 09, 2026, 02:04:22 PM »
I have replaced both front and rear ABS sensors with new ones.
Offline Bulldog9
« Reply #3 on: February 09, 2026, 03:16:03 PM »
Have you disconnected the battery and taken the bike out for a ride after swapping the sensors out? Sometimes needs a few miles to recalibrate.
I'm not 100% sure (don't own a Stelvio), and there are variations in the CARC bikes, but I believe the rear speed sensor for the speedo and ABS is the same on the Stelvio. https://www.af1racing.com/883768-OEM-Moto-Guzzi-Speed-Sensor---883768-ex-GU06765400
« Last Edit: February 09, 2026, 03:50:32 PM by Bulldog9 »
MGNOC#23231
Offline Dingo1
« Reply #4 on: February 09, 2026, 11:33:18 PM »
Battery was disconnected when working on bike, only rode short distance 100M on driveway to see if speedo registered after replacing sensors and it didn't. Both new sensors are genuine Moto Guzzi and correct part number.
Offline paulbricey
« Reply #5 on: February 10, 2026, 05:19:03 AM »
Riding to live
Offline Bulldog9
« Reply #6 on: February 10, 2026, 11:18:14 AM »
Double check all connections wires and connectors from wheels to ABS pump to dash including grounds and go for a longer ride.
Is this bike new to you? did you buy it with this problem? Or did this just start out of the blue? Have you gone out and tested to see if the ABS is working?
If all checks out, you may have a dash issue. Worth the time to pull the cluster, disconnect, clean all the connections and reconnect. You may have a bad dash.
Barring that, I'm out of ideas, but there is a large Stelvio group here and elsewhere that may be able to help you run the issue down.
« Last Edit: February 10, 2026, 11:23:57 AM by Bulldog9 »
MGNOC#23231
Offline Dingo1
« Reply #7 on: February 10, 2026, 02:04:06 PM »
Double checked connections from ABS module to sensors with multimeter. Problem just came out the blue, month or so prior did a $400KM + road trip no issues. Can't say I've activated the ABS ever. I've spoken to other Guzzi  experts and last suggestion is take bike to a dealer and get checked with PADS diagnostic tool as in Guzzi Diag I'm not seeing any errors. Thanks for your help.
Offline Dingo1
« Reply #8 on: February 19, 2026, 01:52:08 PM »
Well went to the dealer, they couldn't retrieve any extra information as PADS diagnostics can't read my bike as too old. So back to the drawing board as they say.
Online PJPR01
« Reply #9 on: February 19, 2026, 01:57:47 PM »
From memory, I think this is correct...and I believe the speed sensor is different from the ABS sensor, at least I recall it being that way on the Norge.  The wire can fray, or it gets water in it...it runs on the underside of the CARC with the connector towards the middle of the bike/near the frame.
Will have to look at the bike when I get home to confirm.
« Last Edit: February 19, 2026, 01:58:24 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline averb
« Reply #10 on: February 19, 2026, 03:54:45 PM »
There is a ton of Stelvio specific knowledge here - https://advrider.com/f/threads/moto-guzzi-stelvio-merged-threadfest.113158/page-3690#post-54403793
Offline MadMike
« Reply #11 on: February 24, 2026, 07:44:45 PM »
I gave up on my ABS on my 2013 Stelvio after constant ABS light and mushy rear caliper. Ripped out the Abs Module. Connected the brake lines together and had the ABS light from the dash permanently disabled.
2013 MG Stelvio NTX, 1975 MG Eldorado,
1991 BMW R100GS/PD, 1976 BMW R75/6,
2004 HD Roadglide
Offline Dingo1
« Reply #12 on: February 25, 2026, 03:08:57 PM »
Oh no, do you have speedo reading though?
Offline MadMike
« Reply #13 on: February 26, 2026, 05:54:39 AM »
Yes - Speedo and Odometer... no issues. The electrical connector needs to be separated from the German branded (ATE) Chinese made pump and plugged back into the bike.
2004 HD Roadglide
Offline theoneandonlymin
« Reply #14 on: March 10, 2026, 01:25:52 AM »
Random guess, could the ABS switch be an issue ?
Offline Dingo1
« Reply #15 on: March 10, 2026, 04:59:55 PM »
Switch could be an issue but doesn't explain no speedo. But thinking maybe a wire has shorted out to ground etc
