Author Topic: Installing triple trees  (Read 6215 times)
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: March 15, 2026, 08:20:04 AM »
Swapping out my V9’s triples for a set from a V7. I’ve never removed or installed triple trees before, though I’ve read and watched some videos that explain adjustment. Curious—resources all say to pack the bearings with grease. When I look at these bearings (angular contact style, perhaps?), sure there’s grease on them, but they’re not as globbed up as I’ve seen done to other wheel bearings and steering bearings. Does this style require it? Maybe all the grease I’m expecting has flown off?
Also, aside from the outer races that are already pressed in to their respective triples, do I need to do any sort of pressing when installing and tightening everything down?
Finally, to tighten up the lower ring nut, Guzzi calls for a special tool. Can I get by with using a steering stem / shock wrench and feel? The specific torque measurement is 50 +/- 5 Nm.
Closeup pic of the bearings on the triples:
Closeup shot on the style of bearings:
Screenshots from the service manual’s section on steering bearing adjustment:
« Last Edit: March 15, 2026, 08:33:21 AM by Dirk_S »
Online n3303j
  • Ron Cichowski
Re: Installing triple trees
« Reply #1 on: March 16, 2026, 08:05:47 AM »
Not sure of that bearing stack setup as I'm not used to seeing one that complex.
But fill the assembly full of grease. It's low speed and limited movement so no worry of overheating. Sealing is usually poorly done in this area. It is seldom disassembled for routine maintenance. Headset bearings usually fail due to corrosion. Filling the system full of grease helps keep the water and dirt out. It will ooze some but that can be wiped away as it occurs.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online n3303j
  • Ron Cichowski
« Reply #2 on: March 16, 2026, 08:45:26 AM »
Read through the included instructions. It makes sense. The only thing I'm uncomfortable with is preloading the radial thrust ball bearings to 36 ft/lb preload. That's over a 2,000 pound preload! The torque specs are published by the same people who call for 108 ft/lb on my rear axle on the T3. Twenty five foot pounds will keep the bearing stack securely in position and can be undone roadside with the toolkit provided.
BMW published a torque spec on the tapered roller (radial thrust) bearings in the swingarm of their K100RS. That number was around 3 ft/lb. That was enough to set proper preload on a heavily stressed bearing.
But! Is there a spacer between the two inner races that is establishing the distance between them? Are the bearings being clamped against this spacer by the ring nut? In turn is the ring nut holding the whole bearing stack against the lower triple tree bracket. If this is indeed so then the 36 ft/lbs makes sense. Then, without fancy tools, you could just crank it all down firmly and be close enough to perfect.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline faffi
« Reply #3 on: March 16, 2026, 08:58:08 AM »
Personally, I would replace the ball bearings with tapered ones, since they live much longer and are more robust. Under no circumstance, other than in an emergency, would I mix races from two different bearings - I always replace bearings as a complete set.
When I have installed new bearings, I have tightened the stem until there is noticeable drag, then backed them out so that the fork/handlebars will turn freely to the stop in either direction with a gentle nudge from center position, but without any slack when yanking back and forth down at the wheel axle.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Online Dirk_S
« Reply #4 on: March 16, 2026, 09:07:23 AM »
Parts fiche attached for reference.
I tightened up everything, but haven’t installed the forks, so when I rotate the triples to check for tightness, the new grease keeps the movement from feeling as free as I’d hoped. Perhaps I need to install the forks and wheel to get a good feel?
Online n3303j
  • Ron Cichowski
« Reply #5 on: March 16, 2026, 09:31:19 AM »
Wait until the grease thaws out! :wink
Meanwhile I see no intermediate spacer between the inner bearing races. So the lower ring nut establishes preload and the upper keeps the lower in place. So setting is conventional. Snug lower ring to eliminate any play under load but maintain freedom of movement (not 30+ ft/lb). Note, when you tighten the upper clamping ring it will take up all thrust play in the threads of the lower ring and tighten the bearing clearance. So steering freedom has to be checked with both rings set in their final relationship.
The previous recommendation of tapered roller bearings is a sound choice if they are available for this application. They have a much higher load bearing capacity than the balls. Greater bearing area and 100% contact with both races all of the time.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #6 on: March 16, 2026, 09:37:48 AM »
Put your forks on & wheel on axle. If you have it correct when wheel is centered you move it each way L & R the wheel will drop at around 15* from center each way. The ball bearing set up is junk in my opinion, go with tapered roller bearings from a Western maker.
I don't preload , just snug up till proper drop happens & tighten lock ring.
Offline Moparnut72
« Reply #7 on: March 16, 2026, 09:12:47 PM »
"When I have installed new bearings, I have tightened the stem until there is noticeable drag, then backed them out so that the fork/handlebars will turn freely to the stop in either direction with a gentle nudge from center position, but without any slack when yanking back and forth down at the wheel axle."
This is almost word by word from a Harley manual. This is what I do. My Audace was notchy from day one. The nut was way too tight. I set it up this way and all was good. Ignore that torque figure. I think in my case maybe the manual writer meant the lock nut but it wasn't written that way.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline jhem68
« Reply #8 on: March 17, 2026, 04:42:12 AM »
I would like to see a little more follow up from this related thread:
https://wildguzzi.com/forum/index.php?topic=119054.0
I think if I were to get to needing a service on my 2018 V7 III steering stem bearing I would do the conversion IF I could get a reference to a decent replacement bearing. I think several members have had issues with the newer series V7 bearings due to minimal grease or corrosion.
John H
« Reply #9 on: March 17, 2026, 06:41:42 AM »
I did your research Pt# 2B011121 is 35x55x14.5 mm no taper roller that size, there is 35x55x14 mm
You could have done the same search, call AF1 and see if measurements are correct or measure your own
AI gave me the dimensions could be wrong also, I don't own a smallblock
You could use a 1/2mm shim under bearing, try finding that.
Headstock changed in 2017 w/V7III
« Last Edit: March 17, 2026, 06:57:59 AM by guzzisteve »
Online n3303j
  • Ron Cichowski
« Reply #10 on: March 17, 2026, 07:43:36 AM »
Check "This Old Tractor" or "Guzziology". They might list a replacement.
.5mm shims are easy work with a Dremel tool and a belt sander. I do all my shims out of a pack of assorted 6" X 12" shim stock. Easier than trying to stock every shim needed for a Guzzi final drive.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #11 on: March 17, 2026, 09:50:45 AM »
AI  if you just gave me different sizes, I DON'T CARE, isn't my bike. I don't own one. Isn't to hard to figure out.
Online Dirk_S
« Reply #12 on: March 17, 2026, 10:46:56 AM »
Steve, sometimes you remind me of Batty from Fern Gully. I mean that lovingly.
Offline cappisj1
« Reply #13 on: March 17, 2026, 10:57:19 AM »
Roller bearings have been used for years and are just fine for our Guzzi’s. Do the procedure like Moparnut72 suggested. Just know that too free of a swing from center to the steering stop may start you on a path to a head shake at speed. You want a slow swing to the stops with everything mounted up.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Online Dirk_S
« Reply #14 on: March 17, 2026, 12:42:27 PM »
Good to hear I don’t have to buy a special tool. Thanks all!
Offline mechanicsavant
« Reply #15 on: March 18, 2026, 05:05:44 PM »
I’m pretty sure I posted on another subject about the bean counters saving Pennie’s by not lubing steering head bearings & other cutting other corners. I remember putting a grease fitting in the steering head of a few dirt bikes to prevent corrosion. Might not be a bad idea! Also I believe seeing somthing in another posting about “ All balls racing “ selling a bearing upgrade set. It might have interchanged with Aprilia 650 CCmodel parts . I also remember someone saying those bearings were cheap off shore products . Oh well ,back to grease fittings.yout results may vary!
Offline Moparnut72
« Reply #16 on: March 19, 2026, 09:10:12 AM »
I put All Balls bearings in the steering stem of my T3. I was chastised for using these cheap bearings. For a bike that will be a really low mileage machine. The T3 uses Tapered rollers, they looked good to me. I know that a lot of guys on one of the Harley sites uses them with good results.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online n3303j
  • Ron Cichowski
« Reply #17 on: March 19, 2026, 09:29:51 AM »
Rollers rust out before they wear out so most any roller will be an improvement. Just fill the area with waterproof grease and stay out if salt water.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
