I recently installed a set of organic pads to replace the sintered (moto guzzi-labeled) pads that provided nearly no stopping power in the rear. The organics provided noticeable improvement BUT the pedal still requires too much movement before anything happens. I have to move my foot forward in order to apply any serious pressure/stopping power. I CAN now activate the ABS, which I couldn't with the sintered pads but it requires a heavy duty foot-rearrange/pressure on the lever.The pedal is firm ONCE it gets to the point where it applying the pads to the rotor but regardless of the available pedal adjustment, it is too much movement for good feel. It doesn't feel as if it needs bleeding though I guess I'll give that a try - unbolt the caliper, turn it so the bleed is at the top. Interestingly, the service manual shows bleeding the rear with the caliper mounted/bleed at the bottom. ;) I guess that would work with a pressure bleeder/syringe feeding from the caliper but the pic in the manual doesn't show a pressure bleeder/ syringe.Only other thing I can think of that might help would be a much larger diameter "rubber" on the pedal...
