Author Topic: 22 V7-850 Missing (ignition)  (Read 3831 times)
Offline Phlox
« on: June 21, 2026, 07:50:33 AM »
My '22 V7 has developed a miss, I believe on the left head (haven't dug up a light to confirm).  Idle had been surging a bit at lights, but as of last weeks riding there's a proper miss at idle and sometimes at ~2300-3000 RPM.  I have not had a chance to blow it apart and check for mouse damage, which is certainly a possibility, but is this a known issue/just move this wire here type of thing or am I in it for a new stator/cps assembly?  Wherever I search I can only find info on older 7's and 850T#'s.   She is coming up on the 24K service so I may hold off on any drastic actions till then.
Online Vagrant
Re: 22 V7-850 Missing (ignition)
« Reply #1 on: June 21, 2026, 08:17:39 AM »
Just do the full service now and make sure you get new plugs. I'd also unscrew the plug cap from the wire and check for corrosion.
« Reply #2 on: June 21, 2026, 10:01:05 AM »
They are known to spark to ground, change the plug caps.
Offline Phlox
« Reply #3 on: July 05, 2026, 10:22:41 AM »
for posterity, I went through the caps and cleaned up some corrosion on the spring.  It seems like they might get a bit of moisture ingress on the wire attachment point (or its just high voltage doing its thing).  It fixed 80-90% of the issue.  I ended up swapping the plug wire assemblies and its fully cleared up.
From taking these apart, I believe these are resistor caps, since there appears to be a resistor in them, but as far as I can tell the stock plugs are resistor plugs, which you wouldn't normally stack up.  Maybe something needed to get around a poor canbus layout.
