Don't forget the small seal inside the housing.You can't see it unless you disassemble the diff.The seal is installed backwards that is the spring side faces the inside of the diff.The parts diagram show it and is on the axle nut side(right side) as assembled TOMB
I have previously replaced the big seal, the paper gasket, and even the small inner seal, so I am pretty sure its not from those areas .
Would it be helpful to remove the final drive, and check the mating surface with a straight edge, or use sandpaper on a flat surface to check for any warpage ? I did this to the sump cover, already previously.
