Author Topic: Unobtanium? Breva 1100 airbox-to-throttle bodies boots  (Read 7678 times)
Offline jfear
« on: September 14, 2026, 06:55:38 PM »
Pretty self explanatory: Acquired an engine-less Breva, sourced a mill and have it in-frame and digging through the parts box find that the boots are junk.
I had mopes that Mistral or the like made something what would eliminate the boot altogether, but no.
Has anyone fabbed their own? I wonder if I could dimension one and print out of TPE....
Re: Unobtanium? Breva 1100 airbox-to-throttle bodies boots
« Reply #1 on: September 14, 2026, 08:51:03 PM »
It may be possible to have reproductions made by Clauss Studios. I needed a NLA airbox-to-frame boot for a Cagiva Elefant a few years back, sent it to Greg Clauss and he reproduced it. https://www.claussstudios.com/index.html
Maybe check with Hamlin Cycles?
« Reply #2 on: September 15, 2026, 08:36:21 AM »
Complete airbox with boots for $80 + $30 shipping: https://www.ebay.com/itm/406606438547
Airbox w/boots and throttle bodies for $218: https://www.ebay.com/itm/336543843415
Offline jfear
« Reply #3 on: September 15, 2026, 07:47:29 PM »
Ogling those for a bit, it's just that I'll have three airboxes in various states if I pull the trigger  :cry:
May have to happen, tho
Online Ed / AF1 Racing
« Reply #4 on: September 16, 2026, 11:01:17 AM »
was part # GU05114430 Intake hose, may help in search, it is NLA
The rubber TB to engine head one is still available, GU01114390 Hose
« Reply #5 on: September 16, 2026, 01:47:38 PM »
So your problem is? <scratching head> It's an old low production motorcycle. When you see something you think you might need, it's time to pull the trigger. If you don't, it will be gone soon.
Online ridingron
« Reply #6 on: September 16, 2026, 07:20:10 PM »
Maybe you'll own 3 in various states to get the tubes.
Maybe try to sell the air boxes to help pay for the purchase of number 3?
« Last Edit: September 17, 2026, 11:05:47 PM by ridingron »
Offline jfear
« Reply #7 on: September 16, 2026, 10:06:27 PM »
Moola and wishful thinking, in addition to fam issues taking my focus off the ball.
The yujje
Offline jfear
« Reply #8 on: September 16, 2026, 10:16:14 PM »
Yup, cheers!
Offline Perazzimx14
« Reply #9 on: September 17, 2026, 07:43:38 AM »
Old low production model motorcycle is a double edge sword. There is also the possibility of the parts not selling because nobody needs them. I had a ton of V50 parts that I tried to sell then tried to give away and then toss in the recycle bin because there was no market for them. Old and/or rare do not equate to interest or value.
Offline jfear
« Reply #10 on: September 17, 2026, 10:25:44 PM »
Pulled the trigger - thanks all!
Offline jfear
I hate that I'm back, but Unobtanium?
« Reply #11 on: October 12, 2026, 07:39:17 PM »
I pulled the rigger on that airbox, good experience with the seller (it's where I got the motor for this Breva), but while installing the airbox yesterday and trying to nudge the tube slot onto the airbox a crack appeared on the tube itself: they are rotted too.
Crazy idea but hear me out: a shrink-tube sleeve over the intake tube itself to try and seal/reinforce the thing?
I realize this is in deepest left field but since the GU05114430 is discontinued and pod filters are verboten....I'm trying to think outside of all the boxes
Online Bulldog9
« Reply #12 on: October 12, 2026, 10:08:05 PM »
Of course if you buy it you'll never need it lol.
MGNOC#23231
Re: I hate that I'm back, but Unobtanium?
« Reply #13 on: October 13, 2026, 12:22:08 PM »
Because of the ridges, heat-shrink is unlikely to seal it, but may reinforce it.
Do you have a cracked one to send to Clauss Studios to be reproduced? If you don't want to deal with it, send one to me and I'll have it done.
Offline Huzo
« Reply #14 on: October 13, 2026, 04:24:18 PM »
You obviously know your way around the Breva/Norge pretty well so this may be unnecessary to point out, but the ducts do not need to be removed for removal/replacement of the throttle bodies.
Mine have never been detached from the ‘box.
If the ducts are warm and the airbox is displaced as far as practicable to the rear, the TB’s will wiggle in between quite ok upon refitment.
This is probably not news to you.
Offline jfear
« Reply #15 on: October 16, 2026, 06:01:47 PM »
I could see that while fiddling things around but the crack became evident regardless. I'll have to do the Clauss thing methinks! Do they simply make molds of the OG part and recast? I may be able to that myself, though it would be nice to have a pro handle it.
« Reply #16 on: October 16, 2026, 06:20:29 PM »
Yes, Greg uses the original part to make the mold. The Cagiva Elefant airbox-to-frame boot I sent had cracks in it and the new part had lines exactly where the cracks were and the Cagiva logo.
If you make some for yourself, then there won't be a source for anyone else needing them (unless you can make more). If Greg Clauss makes them, then they'll be available for everyone.
Online jcctx
« Reply #17 on: October 17, 2026, 01:03:55 PM »
Just thinking~ were it mine I would spray the old one with some of that "magic" sealer they advertise on TV???????
Online Bulldog9
« Reply #18 on: October 17, 2026, 06:56:23 PM »
We had a similar problem with the carb to head boots on our XS1100s cracking back in the 90s and early 2000s.
After cleaning well, I used high heat black RTV and gave them a good coating with a firm brush. Lasted 20 years and still working with minimal peeling. I imagine the same would be true for the TB to airbox boots.
Eventually I found a set and have them in a box for 'someday'
MGNOC#23231
Offline jfear
« Reply #19 on: October 18, 2026, 02:13:32 AM »
Well said.
Those of you with experience with Clauss: what's the general price and turnaround time?
Offline theoneandonlymin
« Reply #20 on: October 18, 2026, 04:56:38 AM »
Would self amalgamating tape work ?
« Reply #21 on: October 18, 2026, 11:42:56 AM »
Well said.
When I had the Cagiva boot made, he gave me one for free, for sending him the sample. That was at least 10 years ago, so I don't remember exactly how long it took, maybe two weeks at most. Contact Greg for more information.
Offline jfear
« Reply #22 on: October 18, 2026, 03:09:00 PM »
Emailed him yesterday so I'm crossing my digits.
Last night discovered that the 02 sensor was for the dynojet the PO had installed( the dynojet modules became rat food).
Time to hunt one (stock or another lambda-massager) down!
Offline Roman Hordan
« Reply #23 on: October 19, 2026, 05:13:57 AM »
Glad you're getting the Clauss thing going, that's probably the best route for the boots since it'll leave a source for the next guy too.
On the O2 sensor, if the Dynojet modules are gone and you're going back to stock, it's worth checking whether the PO left the stock ECU and harness intact before you buy anything. The sensor is cheap compared to chasing a mapping problem later. Once it's all together, make sure the sensor is actually reading properly, because a dead or contaminated one will have the ECU running oddly, and that gets blamed on everything else first.
Good luck with it, sounds like a fun rescue project.
Offline jfear
« Reply #24 on: October 19, 2026, 05:43:51 PM »
The OG wire harness was a modified, broken and chewed extensively by packrats. most of the wires from the dynojet units were chewed down to the rubber boots to the module. Seriously - WTF is it about wires that rodents and lagomorphs can't get enough of?  :cry:
Still waiting to hear from Clauss but yeah, having a source for the next inmate will be nice, if we can get it going.
Offline jfear
« Reply #25 on: October 21, 2026, 06:22:09 PM »
I just twigged to what you were referring to  - in my field we call it F-4 tape.
I will definitely give that a go, though I reckon it will be a temporary solution. I know it gets left forever on aircraft but I usually see it protecting one thing from another thing, not acting as a seal.
Have you used it as a seal?
Online sk66
« Reply #26 on: October 22, 2026, 09:02:21 AM »
I would paint them with a rubber coating; something like plasti dip, flex seal, or leak stopper, they are all available in aerosol. You could dip them and coat both inside/outside if you bought it in qt container, but that might be too heavy of buildup (?).
Steven
2014 California 1400 Touring
Offline Bisbonian
  • Living the Dream
« Reply #27 on: October 22, 2026, 11:48:27 AM »
I may have the old stock O2 sensor from my 1200 Sport I could send you. I’ll check when I get home.
Offline jfear
« Reply #28 on: October 22, 2026, 05:50:41 PM »
I actually got a used one off fleabay- I appreciate the thought tho!
« Reply #29 on: October 23, 2026, 03:33:37 AM »
No, but I think I would.
Luckily last winter when I was putting the NorgeGT together I was able to buy a new one from Fowlers I think.
