Author Topic: rear brake stay rod  (Read 4462 times)
Offline billbeall
  • born too late
rear brake stay rod
« on: September 24, 2026, 03:39:33 PM »
reassembling my '70 ambassador, I notice that the rear brake stay rod rubs against the nut on the hub.  am I doing something wrong?
Re: rear brake stay rod
« Reply #1 on: September 24, 2026, 04:07:51 PM »
Not uncommon. If it bothers you, insert the front end of the rod the other way through the brake bellcrank.
« Reply #2 on: September 24, 2026, 05:04:26 PM »
IIRC, this is pre-internet and before joining the MGNOC, I bent mine for clearance.
Offline billbeall
  • born too late
« Reply #3 on: September 24, 2026, 10:11:31 PM »
Thanks for the tip!
Offline matt franklin
« Reply #4 on: September 25, 2026, 07:54:58 PM »
Replace the missing nut on the distal end of the brake stay before you take it on the road  :shocked:
Offline TOMB
« Reply #5 on: September 27, 2026, 05:46:29 PM »
Here's an easy fix. Take the brake rod at the front-end. Over the swing arm and make sure the 90° bend goes through the hole from the outside. So the Cotter pin is behind the bracket that will move the rod off that bolt, a good eighth of an inch, and you'll have plenty of clearance. I just looked at the eldo, that's in my shed, and that's how that is set up, give it a try, pretty sure it'll work for you.
TOMB
« Last Edit: September 28, 2026, 02:18:27 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
