Author Topic: Convert Wanted  (Read 1683 times)
Offline n3303j
  • Ron Cichowski
Convert Wanted
« on: October 19, 2026, 11:30:31 AM »
After years (maybe 15) of lusting after a Convert I finally convinced DW that I should have one. That was a challenge in itself.
Alas now there appears there are none for sale in the USA (Syracuse is junk and don't want to buy sidecar bike with blown torque converter).
Best wished for would have second generation flywheel, be in the eastern USA and at a sensible price.
Certainly there must be one about that is not getting the attention it deserves and is in need of a good home. I'm pretty good at T3 so the learning curve wouldn't be steep
Any leads would be appreciated.
Thanks, Ron Cichowski
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Stretch
Re: Convert Wanted
« Reply #1 on: October 19, 2026, 06:16:19 PM »
If ya find 2, let me know!  :grin:
Nick's latest acquisition is the sort of deal to fall into.
I'm unabashedly a wee bit envious of that one....... :drool:
                                     -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline Moparnut72
Re: Convert Wanted
« Reply #2 on: October 20, 2026, 08:40:07 AM »
There is one for sale in the MGNOC classified. I believe it is fairly close to you unless my geography is messed up.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #3 on: October 20, 2026, 08:49:21 AM »
kk
Geography is correct. But that bike was also listed in our swap column and was sold when I called over a month ago. Seller just never took down his advert. Which was a disappointment because it sounded like exactly what I was looking for.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Re: Convert Wanted
« Reply #4 on: October 20, 2026, 09:03:37 AM »
The call of the Convert can be strong.   A motorcycle like no other.
Good luck on your endeavor.  I see decent examples become available regularly.  This one in Ohio shows promise.  https://www.facebook.com/share/1HNPCpHWDY/
If you want to learn a bit about the innards of the Convert, my build thread is here.
https://wildguzzi.com/forum/index.php?topic=115986.0
I transformed my crusty project into this, because I love going so far upside down it is ridiculous.
Online Bulldog9
MGNOC#23231
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #6 on: October 20, 2026, 11:27:28 AM »
Dropped a note to the Ohio machine. Advert over a year old. We shall see.
Already visited the New York machine. Owner said it ran but couldn't make it do so. Bike looked like a "career" to get it running. Looked like it had never been cared for. Even at the $1,500 he quoted as bottom it wasn't worth the risk.
Ohio fellow just replied with a "YES" available. Guess I'll do some talking with him. Didn't know there were 1985 Converts. Doesn't say Convert on side covers but does have transmission plumbing.
Let the adventure begin.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline TN Mark
Re: Convert Wanted
« Reply #7 on: October 20, 2026, 11:29:54 AM »
There was a batch of Cal II automatics as well.
An ‘updated’ Convert perhaps.
Online Aldo
Re: Convert Wanted
« Reply #8 on: October 20, 2026, 01:24:09 PM »
They come and go in waves.
Found these on FB Marketplace
https://www.facebook.com/marketplace/item/1258762392925578/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A19025f27-8a96-4f93-9c16-e2c9ee30ddad
https://www.facebook.com/marketplace/item/2037941533517729/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A19025f27-8a96-4f93-9c16-e2c9ee30ddad
Ohio Convert is a '75, which means it likely has the the stamped flywheel...which is prone to destruction. It has only 8k miles, so it probably still running on the stamped flywheel.  The one on my '75 let go at 17.5K.
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #9 on: October 20, 2026, 03:00:50 PM »
Thought about machining a reinforcing ring and having it welded into the current flywheel (I have a lathe). Also will true up the torque converter. I assume the flywheel failure is due to metal fatigue as the assembly gets flexed every revolution unless the whole assembly shares a common centerline.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Aldo
Re: Convert Wanted
« Reply #10 on: October 20, 2026, 04:56:23 PM »
I had my stamped one welded back up and balanced when it decided to grenade, but replaced it with the heavy one to keep my mind at ease.  I have pics of my welded one on some of my older posts.
Threw the welded stamped one on the shelf for safe keeping; I think I gave it to the buyer when i sold that Convert.
My current "Ambo-vert" sports the '81 motor with heavy flywheel, so no concerns there.
1973 Eldorado 850
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #11 on: October 20, 2026, 05:27:11 PM »
Looks like me & my truck are going to Ohio this coming Monday to check out and pick up a Convert. Thanks for the lead.
Odd; if I log into Facebook with my wife's account and search for Convert Moto Guzzi I only come up with the Syracuse bike. But your link worked and the deal is in progress.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Re: Convert Wanted
« Reply #12 on: October 20, 2026, 05:56:40 PM »
If you buy a heavy flywheel and put it on a shelf next to the bike, the stamped one will never fail.  :wink: Seems to work for some reason.
Offline TN Mark
Re: Convert Wanted
« Reply #13 on: October 20, 2026, 06:02:47 PM »
The stamped flywheel on my last Convert broke at exactly 10,000 miles. Fortunately I was close to home as I had to push it.
Offline spmoto
Re: Convert Wanted
« Reply #14 on: October 20, 2026, 06:51:50 PM »
I know of a nice 1980 convert here in Maine. The owner is a good friend who has put about 7-8k trouble free miles on it this summer. I think it has under 20k total miles. He is thinking of letting it go so send me a PM if seriously interested and I'll put you in touch with the owner.
Steve M
Online Bulldog9
Re: Convert Wanted
« Reply #15 on: October 20, 2026, 08:56:08 PM »
True for 6 years and 9k miles for me ... Total of 45k Miles on my beauty. According to Dave Richardson and others, if it was going to fail, it would have by now, but for Posterity Sake, I have a NOS Stamped and one of the Machined Flywheel connector plate thinggys on standby.
« Last Edit: October 21, 2026, 11:23:22 AM by Bulldog9 »
MGNOC#23231
Online fotoguzzi
Re: Convert Wanted
« Reply #16 on: October 20, 2026, 10:29:07 PM »
I built this Vert back in 2006-07 it was fabulous! ‘98 EV power plant with FI and all the EV electronics.. had to fab up a flywheel that could trigger the crank sensor, that was the biggest hurdle. Then squeezing in the ATF tank and the fuel return link to the gas tank and more. It was a fun exercise in “can it be done” I proved to my self I could do it! It was called the SPEVert.. SP body, EV motor, Vert running gear.it was pretty fast too relative to the stock Convert with heavy flywheel. Sadly.. I sold it and shipped it off to a guy in  New Zealand.
Re: Convert Wanted
« Reply #17 on: October 21, 2026, 07:24:04 AM »
Upon further study of the pictures I have questions about this machine.  I am wondering why a bike with 8000 miles has been repainted, seat changed out, mufflers replaced and tail light assembly removed and replaced with cheapo crap?
Offline Vagrant
Re: Convert Wanted
« Reply #18 on: October 21, 2026, 07:30:23 AM »
Does anybody else see the humor in this thread. People begging to buy a 50 year old Guzzy!
And yet you can't give away a new or used one.
Offline TN Mark
Re: Convert Wanted
« Reply #19 on: October 21, 2026, 08:30:03 AM »
Yea. It’s a rather sad circumstance for many newer Moto Guzzi dealers.
I had three Converts decades ago at different times. Plus a G5. Would I
like another Convert one today? Yes, yes I would.
But there’s only so much room in the garage and I wouldn’t replace my
Victory Hard-Ball or my Eldorado 1400 with one.
Sadly, for Moto Guzzi, they don’t make a bike I’d like to buy today.
IMHO, their 1400 line was the epitome of their motorcycle design.
Re: Convert Wanted
« Reply #20 on: October 21, 2026, 09:15:04 AM »
My advice is to hang tight and keep a watch.  Before you know it a better, cheaper, and closer Convert than the one in Ohio will become available.
Online Bulldog9
Re: Convert Wanted
« Reply #21 on: October 21, 2026, 11:34:16 AM »
50 Years is a LONG time to keep something unmodified. I wouldn't assume foul play or problems.
I have new Paint, run a Bassa Exhaust, changed out the seat and rear fender. I don't even know if my tail light is the right one. It came with a King/Queen Monstrosity and a second custom Bench seat. The Original seat/rear cowl and wings were long gone, before the guy I bought it from.
I bought one of the Original Guzzi Barn Door windscreens, but take it off in warmer weather.
MGNOC#23231
Re: Convert Wanted
« Reply #22 on: October 21, 2026, 01:03:21 PM »
The main point I was trying to make was - bide your time,  a closer, cheaper and better Convert will make itself available.  IMO opinion the Ohio bike is over priced for what it is.
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #23 on: October 21, 2026, 06:27:26 PM »
Steve M
Hi Steve, Peter is indeed a wonderful person with quite the collection of bikes. Went to Maine today and examined and rode the '80 Convert. Then wrote the check. I HAVE A CONVERT! I'll have to go back with a truck next visit to pick the machine up. Today was an adventure ride on the V11EV.
Thank you for the tip. It paid off well.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Bulldog9
Re: Convert Wanted
« Reply #24 on: October 22, 2026, 09:32:23 AM »
Congrats! Can't wait to see the pics!
MGNOC#23231
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #25 on: October 28, 2026, 02:46:40 PM »
It's in my garage!
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Tkelly
Re: Convert Wanted
« Reply #26 on: October 29, 2026, 05:12:24 AM »
Put the windjammer and heated grips on and you are ready to roll.
Offline chuck peterson
Re: Convert Wanted
« Reply #27 on: October 29, 2026, 06:59:31 AM »
It's in my garage!
Daaaaaahhhhmmmmmm…..it’s got the wings! You’re golden!
Nice Pervert! Lo-range go throttle up at 55…
Still no salt on the roads, hit it!
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline n3303j
  • Ron Cichowski
Re: Convert Wanted
« Reply #28 on: October 29, 2026, 07:17:21 AM »
Heated grips are a Must Have.
Windjammer makes the bike look too "front heavy" unless you have HUGE rear bags. I'm a loyal fan of National Cycle Plexifairing. Excellent protection and keeps rhe bike looking "light".
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Stretch
Re: Convert Wanted
« Reply #29 on: October 29, 2026, 03:03:31 PM »
Looks like a good 'un!
Those Plexifairings are decent.
                           -Stretch
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2015 Triumph Trophy
