Author Topic: Loop header clamps  (Read 377 times)
Online wirespokes
Loop header clamps
« on: November 04, 2026, 07:41:52 PM »
Eldorados and Ambassadors have clamps on the headers to the frame. Just wondering how necessary they are since the newer bikes don't have them. Maybe the threaded-in header retainers aren't as robust and it makes a difference?
Re: Loop header clamps
« Reply #1 on: November 05, 2026, 11:02:09 AM »
If your using the mufflers with the crossover, then the header to frame clamps are not needed, though if I had the clamps I would use them.
If your using mufflers without the crossover, then it's a must to run the clamps. The mufflers could wiggle a bit and cause the header to head nut to loosen.
JMHO,
Offline Fontain25
« Reply #2 on: November 11, 2026, 04:47:10 PM »
The original aluminum clamps are hard to find. they make a steel clamp that would do the job.
Online wirespokes
« Reply #3 on: November 11, 2026, 06:46:28 PM »
I just got some used steel ones. Is there anything to be done against scratching the frame or headers?
