Author Topic: California 1400 Touring Suspension Upgrades?  (Read 672 times)
Online sk66
« on: November 10, 2026, 09:22:06 AM »
I've owned a 2014 1400 Touring for a couple years now and I'm considering upgrading the suspension. The Matris option (cartridges and shocks) comes in at $2200 delivered which seems a lot for a bike that's only worth around $5k. But I'm OK with that as long as the benefits are significant... Are they?
I don't find the stock suspension terrible, just not particularly confidence inspiring either. I find it to be both kind of boat like on smooth roads/sweepers and nervous when on rough surface (road patches, ground for repaving, etc).  But this is my first big cruiser type bike; closest would be the BMW R1150RT I owned before... so I don't know what I might/should expect I guess.
Also, are there better options that the Matris?
I did see a previous post on this from 2017, but there wasn't much to it.
« Last Edit: November 10, 2026, 09:36:46 AM by sk66 »
Steven
2014 California 1400 Touring
Online TN Mark
Re: California 1400 Touring Suspension Upgrades?
« Reply #1 on: November 11, 2026, 06:59:26 AM »
My  Eldorado had Matris fork internals and Matris piggyback rear shocks when I bought it. They’re quite nice. I don’t have a frame of reference to the OEM parts as these upgrades were already done.
From everything I’ve read, the OEM rear shocks were quite poor.
Online sk66
« Reply #2 on: November 11, 2026, 08:34:41 AM »
It surprised me because all of the magazine reviews I read said it was great...
Steven
« Reply #3 on: November 11, 2026, 10:55:09 AM »
You've taken the time to adjust them, I assume?  Check spring rates?
It's a 2014.  You have serviced the forks?
Hamlin Cycles in Bethel, CT is a day drive for you.  If you want the best guy on the east who's done dozens of those bikes and hundred of Guzzi bikes during his career you have that option.
I drove a 14 model of that bike when it was new and it was very good out of the box.
« Last Edit: November 11, 2026, 10:55:57 AM by kingoffleece »
Offline Moparnut72
« Reply #4 on: November 11, 2026, 12:12:53 PM »
The shocks on my Audace were very good also. The rears had remote reservoirs which the other 1400's didn't have as far as  know.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online blu guzz
  • Loves to ride
« Reply #5 on: November 11, 2026, 01:21:40 PM »
I have had a California Custom and an Eldorado.
The custom had 4 inch piggyback shocks as standard.  I felt that it was good enough that I didn't have to change it and owned it from 500 to about 9500 miles.
The Eldo had the stock 3 inch rears as I think the touring may too. From the start which was at 18000 miles until 29000 miles the stock shocks only felt bearable.  There are many small backroads in my area without center line, about wide driveway size. Unfortunately, they are not maintained in pristine condition by the county.  They are beautiful little 25 mph roads that look like what you would have found in the 19th century except without the ancient asphalt. I made the mistake of trying to take my wife to see all this beauty and it beat the devil out of her and me now too due to the increased sag.  I found a lightly used set of Matris rears on the forum and put them on.
All problems solved. The quality of the forks is better than the stock rear shocks so it kept up with the back just fine until March 8 when it became the property of Erie Ins. I would say get them if you can.
Blue Guzz
« Reply #6 on: November 11, 2026, 01:25:50 PM »
The elephant in the room is a bike that's 12 years old.  Expecting any serviceable item to be in as delivered condition is a bit optimistic at best.
Online sk66
« Reply #7 on: November 11, 2026, 03:25:20 PM »
I've adjusted the rear and haven't found particularly good settings. I don't think I've ever changed fork oil that wasn't a result of failed seals, but it is at the replace interval.
Steven
Online sk66
« Reply #8 on: November 11, 2026, 03:32:29 PM »
And 30K on the clock... I wouldn't know what "as delivered" would be.
Steven
« Reply #9 on: November 11, 2026, 04:37:08 PM »
Everything new.  Rears are shot at 30K.  If fronts have been done in past two years they will be as good as they can be as delivered.  They can be much better.
Online sk66
« Reply #10 on: November 12, 2026, 09:22:05 AM »
Order placed...
Steven
Online TN Mark
« Reply #11 on: November 12, 2026, 09:31:46 AM »
sk66, is your 2014 CA Tour still on the original demand sensor and are you using an AGM battery or a lithium LifeP04?
I had my demand sensor replaced replaced last month at 2200 miles in my 2016 Eldorado. Doing so absolutely cured my random URGENT SERVICE fault warnings. Then I replaced my one year Yuasa YTX AGM battery with an Antigravity ATX-20-HD and that cemented the elimination of random fault codes.
Online TN Mark
« Reply #12 on: November 12, 2026, 09:33:54 AM »
The oem rear shocks on the Eldorado were made for looks, not performance. Other 1400 models most certainly received higher quality rear suspension. I 'think' all the forks were the same for all the models.
What aftermarket shocks and fork internals did you go with?
« Last Edit: November 12, 2026, 09:35:37 AM by TN Mark »
Online sk66
« Reply #13 on: November 12, 2026, 10:42:41 AM »
Original demand sensor w/o issue. I'm running an Ionic S6 LiFePO4.
Matris
« Last Edit: November 12, 2026, 10:43:57 AM by sk66 »
Steven
Offline guzzista
« Reply #14 on: November 15, 2026, 06:20:45 PM »
+1 on the Matris. The later version of 1400 forks (Kaifa) is  even more price point built than the earlier Sachs , but the Matris swap made a def. improvement. As for the shocks, the originals were predictably shot at 30+K miles. I  used the Shock Factory units (without piggyback reservoirs ) and that also improved the ride a bunch.
Online sk66
« Reply #15 on: November 16, 2026, 09:33:34 AM »
The only thing I'm going to miss is the remote preload adjustment. But I seldom ride two up so it's not that big of a loss.
Steven
Offline Ncdan
« Reply #16 on: November 16, 2026, 12:04:27 PM »
The suspension on my 2015 1400 tourer was quite sufficient. However the need for the 3rd TPS replacement for failed sensors within 14k was the final straw for my 1400 experience.
Other than that issue I must say that was the best motorcycle that I’ve ever owned as far as power, handing and comfort. It was a mile eating beast.
Online TN Mark
« Reply #17 on: November 16, 2026, 12:39:26 PM »
Sadly Ncdan, I suspect your two Demand Sensor replacements may have been before the upgraded item came out.
I had the same issues with my oem Demand Sensor that you and many others did. The day I replaced the original Demand Sensor with the new design, it's been 100% reliable. The bike is actually trust worthy now. I also greatly upgraded the battery going from a Yuasa YTX-20 AGM to the Antigravity ATX-20-HD Lithium LifeP04 as well. Two of the best upgrades my 1400 had left to do.
I knew going into my 2016 Eldorado that a new Demand Sensor was very likely going to be needed. I learned all the bad behaviors from reading posts from you, Kevin and others. Therefore, I new what to do once I started seeing the eronious fault codes etc.
« Last Edit: November 16, 2026, 12:46:11 PM by TN Mark »
Offline Ncdan
« Reply #18 on: November 16, 2026, 07:51:37 PM »
In hindsight mark, I should have maybe held on a little longer in hopes for a fix. I’ll alwsys hold the company responsible for not doing the right thing and having a recall.
