Author Topic: Please show me... Your Sport 1100  (Read 68951 times)
Kentktk
Re: Please show me... Your Sport 1100
« Reply #90 on: August 18, 2012, 07:41:02 PM »
Looks like some junk dude had sitting in garage with which he had a desire to make a good looking bike look bad. He has it up around the throttle body inlets too. Oh, my mistake that`s Farkle`s or maybe Bling, really makes things Pop though.......lol
Offline Greenman
« Reply #91 on: August 18, 2012, 07:55:21 PM »
ok, enough Sport 1100 porn,
What have you done to make you Sport 1100 go like it was supposed too?
I have, in no particular order.
WP springs in the forks.
Created a star ground point at the regulator.
Headlamp now switched by relays.
Breather on  the rear drive.
gaitors on the forks (triumph T100 ones are an exact fit).
268 emulsion tube. 65 idle jet, 152 mains. K&N filter with the top cut out of the airbox.
Tommoselli 2C throttle. Aprillia RSV1000 RHS switchgear to allow this, headlights now hardwired on.
taller screen for reduced wind blast.
re-profiled seat with a bum stop.
mistral crossover.
I'm sure I done more than this, by for today this is what I remember.
Dennis :beat_horse
DD
Sport 1100 carb
Offline QCGoose
  • Chris McFate
« Reply #92 on: August 18, 2012, 09:49:28 PM »
Mine has a Mistral crossover, Mistral carbon-fiber round cans, and a Creedon chip.
1998 Guzzi V11 EV
1997 Guzzi 1100 Sport
2004 Ducati Monster 1000Sie
1970 Honda CB175
"It is good to have an end to journey towards; but it is the journey that matters in the end."
« Reply #93 on: August 19, 2012, 12:42:22 AM »
Well then, that would be the "Please tell me about your Sport 1100" thread that you haven't started yet.
« Reply #94 on: August 19, 2012, 07:54:39 AM »
Keihin FCR41 carburetors
Staintune full exhaust system
Brembo cast iron front brake rotors
Brembo GP radial master cylinder
Offline JBU
    • www.joelurruty.com
« Reply #95 on: August 19, 2012, 08:39:02 AM »
gasoline.
JBU
Offline Blueboarhound
« Reply #96 on: August 19, 2012, 06:01:39 PM »
Rocker59,
Post some pics of your Sport 1100's brake set up! I'd like to check them out.
« Last Edit: August 19, 2012, 06:05:20 PM by Blueboarhound »
1993 Ducati 900SS
1993 Moto Guzzi Daytona 1000
1996 Moto Guzzi Sport 1100
2012 Moto Guzzi Stelvio NTX
« Reply #97 on: August 19, 2012, 07:29:57 PM »
Your Sport 1100
Wounded goose (Sorry Paul, you asked)
1993 Ducati 900SS
pauljenkins
« Reply #98 on: August 19, 2012, 07:52:36 PM »
So what's the sketch with that one ?
Undergoing resoration ?
Looks superb to me
« Reply #99 on: August 19, 2012, 08:42:10 PM »
It's torn down for some motor work (spun a bearing and needs rod/crank repairs). I've owned it since new and overall it's in very good shape aside from the current motor issue.
1993 Ducati 900SS
pauljenkins
« Reply #100 on: August 19, 2012, 08:48:58 PM »
Well in that pic it looks like a brand new bike on the factory production line.
When you say, spun a bearing, could you elaborate
« Reply #101 on: August 19, 2012, 10:47:41 PM »
Here is a link to the thread I posted about it awhile back.
http://wildguzzi.com/forum/index.php?topic=49991.msg747765#msg747765
1993 Ducati 900SS
pauljenkins
« Reply #102 on: August 19, 2012, 11:03:05 PM »
Offline Guzzirider
    • MGCGB Pennine Branch
« Reply #103 on: August 20, 2012, 02:11:27 AM »
My Sport Corsa #133 at Ty Croes in July 2001, my first ever track day.
I sold her in 2004- she was on eBay last year so she is still around somewhere.
1225 Daytona
Ducati ST4S
Offline Murray
« Reply #104 on: August 20, 2012, 05:26:46 AM »
1994 1100 sport, Manual taps Keihin FCR41 carburetors K&N pods Dommino quater turn throttle, Full Termi system bottom of the tank where the airbox welded up to add another approx 4.5 litres capacity, WP springs (front), 916 master cylinder with 999 four pad callipers and a Karma adaptor bracket for the callipers and braking low carbon steel discs (although these are just about toast and I have some new ISR's waiting in the wings). Steering damper removed, forks pulled about 10mm through the tripple trees, pro grip gel grips, accel voltage reg although this was more because the OEM one died. Currently running Bridegstone 023's as I have found that modern sport touring tyres will out perform the old thing. Has approx 130 000kms on the clock. Ventra rack with the grab handle.
Next step is to go into the motor as its starting to show its age.
pauljenkins
« Reply #105 on: August 20, 2012, 08:18:41 PM »
Just wondering if anyone's seen rear bodywork like this before.
Offline tazio
« Reply #106 on: August 20, 2012, 09:41:43 PM »
That sucker's keeled over !! ;-T ;-T
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
« Reply #107 on: August 20, 2012, 09:52:57 PM »
That appears to be a modified 1990s Ducati Supersport tail section.
pauljenkins
« Reply #108 on: August 20, 2012, 10:58:56 PM »
Hmmm,
Not convinced.
It does look very Ducati, but to get such a neat fit around the airbox like that would me more work than most would be prepared to undertake,
« Reply #109 on: August 20, 2012, 11:23:56 PM »
Trust me.  It's a modified Solo Tail from a Ducati Supersport.
It was done by more than one person, in more than one way.
There were people who did not care for the hips on the Sport 1100.
There were at least two aftermarket tails specifically built to address that, plus all the custom Supersport tails that were adapted.
You'll find more pix of the conversions, if you continue searching around.
The one you pictured would be better, if they'd used the Ducati tail light instead of leaving the stocker hanging out there.  If you looked at it from the rear, there would be a void above the stock tail light where the Ducati light should be mounted (flush).
« Last Edit: August 20, 2012, 11:26:36 PM by rocker59 »
« Reply #110 on: August 20, 2012, 11:34:16 PM »
side by side comparo:
Offline QCGoose
  • Chris McFate
« Reply #111 on: August 20, 2012, 11:43:09 PM »
Hard to believe, as I find that to be one of the Sport's sexiest aesthetic attributes. The girl has got some curves and she wears them well.  ;)
1998 Guzzi V11 EV
1970 Honda CB175
« Reply #112 on: August 21, 2012, 12:10:44 AM »
One of the tails was actually called "Lipo-Section".  Radguzzi, up in Maine, had one.
Offline Murray
« Reply #113 on: August 21, 2012, 06:58:44 AM »
It was actually a  stien diense kit I remember seeing it in the catalogue way back when there was also a dual seat that was similar. Although back then the exchange rate wasn't quiet as healthy as it is now and it was something like $1800 plus paint included a new rear subframe with the mounting for the batts etc,
« Reply #114 on: August 21, 2012, 10:32:03 AM »
They had some cool stuff for the Sport 1100s back in the day.
Orange Guzzi
« Reply #115 on: August 21, 2012, 11:59:41 AM »
Dreamed I wrecked my spot 1100 last night.  Turned the throttle wide open in 1st gear and the bike front wheel came up and thru me off the back.  Got up and brushed myself off, picked up the bike, restarted it and proceeded too do the whole scene over again.  Second time around I lost the battery and was walking around trying to find it so I could go home.  I new it was a dream because the bike wheel not pull the front wheel by just cracking  the throttle.  Have to slip the clutch a little to get it up.
Offline QCGoose
  • Chris McFate
« Reply #116 on: August 21, 2012, 12:33:36 PM »
 :o
I had to reread that! The first thing I saw was "wrecked my spot 1100 last night" and only noticed the "Dreamed" in my peripheral. Because of that, I thought "Dreamed" instead was "Damn".  :D
1998 Guzzi V11 EV
1970 Honda CB175
Offline oldmxdog61u
  • enjoy life...
« Reply #117 on: August 26, 2015, 05:09:13 PM »
I am in the process of getting a silver sport 1100 in october and this thread is just making it harder to wait!  Mine is a 1996. Yippeeeee!
Enjoy life!
1985 lemans 1000 (gone)
1996 Sport 1100 (gone)
2007 norge (ahhhhh)
1984 yz250 (gone to museum)
1977 Cr125m Elsinore (sold)
1973 HD FX (back to my bro)
1974 Eldorado (grace)
Offline Aaron D.
« Reply #118 on: August 26, 2015, 07:43:17 PM »
1996 is the best year, you know.
« Reply #119 on: August 26, 2015, 07:47:05 PM »
I'm thinking 1994..  :popcorn:
