Author Topic: Replacing Bar End on V7 Stone  (Read 13273 times)
Rick T.
« on: April 14, 2014, 11:11:36 AM »
I got an Oberon barend/mirror for my V7 Stone.  But ran into this...
How do I remove that inner threaded piece?
« Last Edit: April 14, 2014, 11:23:37 AM by Rick T. »
Offline tonUPRacer
    • My Racer FB page
Re: Replacing Bar End on V7 Stone
« Reply #1 on: April 14, 2014, 11:26:50 AM »
I just fitted Rizoma Reverse Retro's to my V7R. I think you may need to find a different mirror. Most the mirrors I looked into for our bikes used an adapter collar and then the bar-end is clamped on to the adapter. You may be able to pull the "guts" out of the bar, but it may be easier to return your mirrors and buy a mirror w/ adapter. Look into CRG or Rizoma, I'm sure there are others.
2013 V7 Racer #393
2001 Ducati 900SS (sold)
1999 Ducati 900M (sold)
1979 HD XLS Sportster (sold)
warendt
« Reply #2 on: April 14, 2014, 12:22:17 PM »
I cut the bar insert off and then mounted like the bar end.
Offline tonUPRacer
    • My Racer FB page
« Reply #3 on: April 14, 2014, 12:45:49 PM »
well there you go, 2 options. If you do choose to cut then you can't go back to stock form if that matters to you.
edit: if you know what you're doing you could build something and go back to stock (see machinist thread)
« Last Edit: April 14, 2014, 12:53:03 PM by tonUPRacer »
2013 V7 Racer #393
« Reply #4 on: April 14, 2014, 12:58:35 PM »
A new set of bars!
Ah, the slippery slope!
 :bike
Rick T.
« Reply #5 on: April 14, 2014, 01:14:45 PM »
A new set of bars!
 :bike
I did this for now...
Joe G
« Reply #6 on: April 14, 2014, 02:19:28 PM »
The inserts are not threaded. They have a groove in the center. The bar is swaged into this groove. I got the feeling Moto Guzzi really didn't want me to drill them out so I did it anyway.
        Joe G
Rick T.
« Reply #7 on: April 14, 2014, 03:50:15 PM »
Thanks guys.  I think I'll keep the Oberon kit on my Ducati.  It's a real clean install and high quality piece.  AF1 offers the CRG Mirror/Rhino Moto combo and I may simply go for that option for my V7.  Or... get new bars ($70 for LSL Superbike Talls).
Was just suprised to see it done that way.  Only other bike I had that was like that was my Triumph Speed Four about 12 years ago.
Rick T.
« Reply #8 on: April 16, 2014, 10:33:41 AM »
Broke down and ordered this (in all-black)...
From http://www.af1racing.com/store/Scripts/prodView.asp?idProduct=61342
I'll keep the Oberon kit on my Ducati for now.
Offline malik
« Reply #9 on: April 16, 2014, 10:08:00 PM »
A new set of bars!
 :bike
I changed the bars on the V7C - Laverda multi-adjustable - the bonus is that after experimenting with different positions (followed by 500k rides),  I now no longer get that pain in the top of the back near the end of the day. The bars sport CFGs. But RickT's final solution is elegant.
Mal
HarleyTheBarber
« Reply #10 on: May 12, 2015, 06:28:33 PM »
Hi Rick,
How do you like those lane splitters in all black from AF1?
Are they sleek and functional?Any vibration? Just want a little feedback before I break down and spend the wopping $250!!!!
Also did you use the thread lock compound?
Thanks, Harley
Offline Moto Fugazzi
    • Griso
« Reply #11 on: May 12, 2015, 06:47:42 PM »
Hi Rick,
Thanks, Harley
Looks like Rick cashed out on us.
I have the CRG's LS, and they work great. You do have to get used to everything being much smaller.
Shop around, and you'll find better prices than $250. You also don't need those fancy bar ends. I used the insert piece that comes with the mirrors, and used a longer bolt to mount it without threadlocker.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
HarleyTheBarber
« Reply #12 on: May 12, 2015, 06:54:18 PM »
Hi Ken,
So what your saying is that you got the CRG LS without the adapters and just picked up a longer bolt that you then used in the existing Guzzi stock bar ends? And if so diid you run into any trouble with them being flush with the throttle?
« Last Edit: May 12, 2015, 07:00:29 PM by HarleyTheBarber »
Offline Yukonica
« Reply #13 on: May 12, 2015, 07:55:49 PM »
Not to knick the original thread but ... Mal you are the only other person I have read about having Laverda multi adjustable bars. Try as I might I have never found a torque specification for the knuckles..... guessed at 65ft/lbs and some blue loctite. Any information you can add? Thanks.
Offline malik
« Reply #14 on: May 12, 2015, 08:42:03 PM »
In the beginning, one of the knuckles would loosen itself. I just kept tightening it a little more each time until it stopped doing that. No loctite (which would, perhaps, be wise) and hasn't loosened off since.
Mal
    • Griso
« Reply #15 on: May 12, 2015, 08:48:47 PM »
Hi Ken,
If it's flush or rubbing against it, you can add a washer or two as a spacer. I have aftermarket grips which are a little shorter than stock.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
AGRO!
« Reply #16 on: May 12, 2015, 11:46:35 PM »
Im running these.....http://www.aliexpress.com/item-img/Bar-End-MIRRORS-Suzu-GSXR-R-600-750-1000-1300-BLACK-K10/526436066.html
You just need to use the standard guzzi bar end bolt.
RickTReloaded
« Reply #17 on: May 13, 2015, 10:41:19 AM »
Ken
I'm still here, guys.  Just "reloaded myself" recently.  I swapped our my bar for the Rizoma MA001B and now have the CRG Blindsight Mirror/Rhino Moto bar end (w/CRG provision) on the left and the Rhino Moto bar end on the right (no mirror).  I like the clean look this achieved.
The current setup:
    • Griso
« Reply #18 on: May 14, 2015, 12:41:30 AM »
The current setup:
Glad to see you're still around! It sucks when people just disappear. Nice work on your bike!
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
HarleyTheBarber
« Reply #19 on: June 07, 2015, 06:02:25 PM »
So I ordered the CRG lane split mirrors online and I also ordered the Rhino Bar End Adapters which are awesome and only take about 1 minute to install. I'm sure theres a DIY method for attaching the mirrors but when I'm not working I wanna be riding not putzing around trying to make a square peg fit into a round hole so speak. If I weren't a city dweller without a garage and had adequate access to tools perhaps I'd  be more inclined to figuring out a solution but I digress......
The guys at Rhino have what you need if your like me and just wanna pop the mirror on and get out there and ride on your days off! I went for a four hour ride down the California coast today and the mirror did great! No vibration and no need to readjust at all. I ordered 2 but only needed the one left side mirror so I returned the second one which felt good to do seeing as they are $75.00 a piece (ouch!) I ordered the adapter in black which I'm glad I did cause its nice and clean and doesn't break up the bar like the stainless.
I'd like to post pics of the finished installation but do not see how to do so?
Mirror: http://www.motorcycle-superstore.com/27533/i/crg-hindsight-lane-split-bar-end-mirror?device=c&network=g&matchtype=b&SITEID=Google+SEARCH+NON-BRAND+Google+Dynamic+Search+ads+-+DSA&gclid=Cj0KEQjw18-rBRDogrTg4Lusuu0BEiQACs8YQowE8mVmstLCiXp0uMXk6VOFSb9Vq5oxvPY9Up1lNPgaAuBX8P8HAQ
Rhino Adapter: http://www.e-securedsite.com/rhinomoto/store/myProducts.cfm?parentcategoryid=4%7CBarend%20Sliders%20and%20Mirrors&productID=298&showDetail=1&categoryID=119|Moto%20Guzzi%20Barend%20Sliders&vendoridtodisplay=0&filterFor=&collection=4%7CBarend%20Sliders%20and%20Mirrors
