Author Topic: Putting Bitubo shocks on the V7 Stone  (Read 7465 times)
Offline right_slide
« on: April 23, 2014, 09:02:10 PM »
Has anyone tried to put the Bitubo shocks onto a V7 Stone?
Once again, the dealership wasn't too helpful when I asked if the shocks were comparable with the rear luggage rack. Doesn't look as though they'll even fit with the stock hand rails...
Offline right_slide
Re: Putting Bitubo shocks on the V7 Stone
« Reply #1 on: April 23, 2014, 09:04:18 PM »
rossw
« Reply #2 on: April 23, 2014, 09:08:50 PM »
If they foul the luggage rack you can always mount them upside down. That's the only way they fitted on my Breva. Downside is that preload adjustment requires muffler removal to get access for the C-Spanner.
Offline right_slide
« Reply #3 on: April 23, 2014, 09:12:44 PM »
Quite the simple solution. I'll check it out tomorrow.
Offline Grokked
« Reply #4 on: April 24, 2014, 10:18:18 AM »
Or rotated 180 deg. around the long axis such that the adjustment is toward the front of the bike...
Though there might be interference with the side cover or passenger peg support?
Offline pyoungbl
« Reply #5 on: April 24, 2014, 12:31:17 PM »
Isn't there an offset on the shock mounts?  What I'm saying is that the shocks have to have the mount offset from centerline, like this:
This also shows how RaceTech tried to create more clearance between my shock and the rack....still did not clear enough.  Now they are inverting the shocks but had to install an offset for what will  now be the top.  I'll post a photo when the 'improved version' arrives.
Peter Y.
'13 V7 Special (red/white)
Offline right_slide
« Reply #6 on: April 28, 2014, 07:58:21 PM »
No offset. Flipped them over so everything clears
Offline right_slide
« Reply #7 on: April 28, 2014, 07:59:42 PM »
all together again!
Re: Re: Putting Bitubo shocks on the V7 Stone
« Reply #8 on: April 28, 2014, 08:04:38 PM »
SWEET...looking good!
V7ClassiCGR
« Reply #9 on: May 30, 2015, 04:12:27 AM »
you had problem with the installation of the back rack?
