Author Topic: Turn signal problem-update  (Read 5325 times)
Offline Rich A
« on: March 15, 2015, 09:19:01 PM »
Something weird is going on with the turn signals on my Ambassador.
With the ignition on, but engine not running, all of the turn signals work normally. I should add that all of the indicators have regular, i.e., incandescent bulbs. But when I start the engine, the turn signals flash (too) rapidly. I've tried two different flashers, and the same thing happens.
Thoughts?
Rich A
« Last Edit: March 16, 2015, 09:22:02 PM by Rich A »
Re: Turn signal problem
« Reply #1 on: March 15, 2015, 09:35:56 PM »
I had to get an electronic one on the Cal2, was doing same thing w/Warner regular & heavy duty.
Offline Testarossa
    • Skiing History
« Reply #2 on: March 15, 2015, 09:42:02 PM »
Your flasher may be sensitive to the higher voltage. You're probably driving about 12v without the engine running, 14.5v with the generator running -- or higher if the voltage regulator is wonky.
« Reply #3 on: March 15, 2015, 09:46:16 PM »
It would be worth checking to see if the regulator is allowing the battery voltage to get too high.
Offline Rich A
« Reply #4 on: March 15, 2015, 09:51:48 PM »
I'll check the VR when I get a chance--I thought that might be the culprit. But this didn't start happening until I changed out the front indicators; I realize that might be a co-incidence, but I put a different set of indicators on and the problem persists. I also tried some LED bulbs and the problem didn't go away.
Rich A
« Reply #5 on: March 15, 2015, 10:52:30 PM »
I've had to isolate the flasher unit from vibration a little better than it was originally. Still didn't totally fix it though, would still flash irregularly sometimes. Only going to an electronic flasher, like guzzisteve mentions, fixed it for good.
Offline Rich A
Re: Turn signal problem-update
« Reply #6 on: March 16, 2015, 09:22:49 PM »
Installed a new, heavy duty flasher, and the turn signals work properly now.
Rich A
