Author Topic: Rear drive install ..75 850T  (Read 5028 times)
Offline Woodrow
« on: March 17, 2015, 11:32:53 AM »
Im getting ready to install a fresh rear drive .  And as it says in Gouziology the fill ./level plug is too low on this deep sump unit .
  So , should a guy fill this on the bench before bolting it .to the swingarm ?  340CC and 20 cc moly?     right ?.
 Also if this was already bolted up and in the future a person wanted to change oil do you take.the drive off .to .change oil or what.
Just wondering in Northern Wisconsin
Woodrow
Offline TOMB
Re: Rear drive install ..75 850T
« Reply #1 on: March 17, 2015, 11:45:33 AM »
Not really . The Eldo had that problem. Look in guzziology it tells  you what to look for and how to measure to verify.
You could measure to correct amount  of fluid and not worry  about the level hole.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline mtiberio
    • TiberioRacing
« Reply #2 on: March 17, 2015, 11:51:29 AM »
never use the level hole. drain and fill from measuring cup. if you need to check, use a zip tie thru the fill plug hole.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline normzone
« Reply #3 on: March 17, 2015, 11:58:47 AM »
This information reaches me 35 years too late to do me any good. But I guess in the future I will measure all my fluids and observe their performance re the leveler hole as a practice.
« Reply #4 on: March 17, 2015, 12:10:29 PM »
This.
No matter whether the level plug is located correctly or not, I still don't use it.
Offline acogoff
« Reply #5 on: March 17, 2015, 01:54:38 PM »
    Besides that that level hole is one of those extremely easy to strip out bs-terds- best to just not use it.
Marshall County Minnesota USA
