Author Topic: Scura cold start issue  (Read 6544 times)
« on: April 02, 2015, 05:28:45 PM »
Remember, this bike sits.. a lot.. right beside the ocean. Normally on the Scura or Rosie, you turn on the switch, hold just a smidgen of throttle, punch the button, and Vroooom.
This time out, it's crank crank, hunt for just the right throttle position, hold my mouth *just*right, then it fires on one cylinder then both. Every time so far this trip out, cold start is the same. So far, I've pulled the TPS connector, relays and fuses, and spritzed them with DeOxit, same scenario.
Is this indicative of dirty injectors?
After it struggles to life, it runs normally.
Offline Markcarovilli
Re: Scura cold start issue
« Reply #1 on: April 02, 2015, 05:41:27 PM »
Chuck
Could be - can't hurt to try some Seafoam in the gas....
Mark
« Reply #2 on: April 02, 2015, 05:43:51 PM »
clean /tighten battery connections?
« Reply #3 on: April 02, 2015, 06:06:35 PM »
Given the fact it sits for long periods my first action would be dump the fuel, scrap and replace the fuel filter and refill with fresh petrol and a dose of 'Jecter cleaner. Oh, and chuck some new plugs in it. Stale fuel, especially ethanol laced fuel, is murder on plugs.
« Reply #4 on: April 02, 2015, 08:16:29 PM »
I've run enough fuel through it already, that it ought to be fresh. I'll try new plugs, they're cheap. Injector cleaner, too. Once it gets running, it still runs like a scalded dawg. Just figured "somethin ain't rat."  ;D
« Reply #5 on: April 02, 2015, 08:30:11 PM »
Try cleaning out the air bypass screws, doesn't hurt. Don't forget to count were they're at.
All that stuff gets gooey.
« Reply #6 on: April 02, 2015, 08:36:36 PM »
 It thinks it is an airhead beemer   ~;
Offline Moto Fugazzi
    • Griso
« Reply #7 on: April 02, 2015, 09:10:46 PM »
Techron FI cleaner works great. My first thought is the plug wires are getting moist from being too humid. Wouldn't hurt to change those, or spritz with WD-40 to remove the moisture.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
« Reply #8 on: April 03, 2015, 01:18:34 PM »
And the winner of this session of Stump the Guru is GuzziSteve! Come on down and take a bow, Steve!  ;D
From the way it was acting, this seemed like the most logical place to start. Yep, there was black goo (technical term) on both bypass screws. SPritzed them and the seats, let it dry, but them back in, and crank..Vroom. Just like it usta be.. ;D
« Reply #9 on: April 03, 2015, 01:45:28 PM »
I think your plan to take the Scura back to Indiana is looking more sage by the day.....
« Reply #10 on: April 03, 2015, 02:00:45 PM »
Yeah. The Mighty Scura is rusting and corroding. I don't *care* what happens to the Commie Thumper, and from all accounts I've read, they are fine handling machines.
