Author Topic: Countersteering / Counter Steering / Gyroscopic Merged Threadfest  (Read 56406 times)
Re: Countersteering / Counter Steering / Gyroscopic Merged Threadfest
« Reply #150 on: April 24, 2019, 09:48:45 AM »
Actually centrifugal force has very little to do with what makes the bike lean, its the Gyroscopic forces that do that.
The spinning wheel is like a gyro,  and at lower rpm the forces  are very small but are proportional to rpm and become quite strong.
Turning a spinning gyro (w/handlebars) will cause it to tilt resulting in the lean. It will tilt around a point 90 degrees in the direction of the spin opposite to direction of the turning force applied.
Ok Dusty.
This is where the problem lies for me.
I did not say that centrifugal force tilts the bike and have never believed it to be so..
So I am not at odds with Kirby on that.
The one and only point that I dispute is that “at low speeds, (say 10 mph and under), countersteering is not used to initiate a turn.”
Now I don’t care if you wheel out a hundred disciples that’ll hold hands and swear I’m full of crap, or Kirby has won the Nobel prize for working Man’s Physics for Dummies..
It is only the above statement in quotes regarding the lack of necessity to countersteer at walking pace that I need educating on, (or someone does).
If you bring any other point into the debate...?
You’re answering the question I didn’t ask..
Rough Edge racing
« Reply #151 on: April 24, 2019, 09:54:13 AM »
Ok Dusty.
 Are you saying that at slow speeds, a left turn begins by counter steering right and then the front wheel turns left into the turn as the bike also leans to the left ?  This is all very interesting and I'm learning something...
« Last Edit: April 24, 2019, 09:54:57 AM by Rough Edge racing »
Offline kirby1923
  • '81 CX100
« Reply #152 on: April 24, 2019, 10:00:40 AM »
At slow speeds you may initiate a turn by a slight counter steer and lean a bit but then when crawling thru tight corners/turns you must steer in the direction of travel. The lean in this case is the result of the geometry of the motorbike not countersteer.
Using Utube to validate a point is ...wow.
You can find a utube to prove??!! anything from moon bases to proving the earth is flat or levitation.
Its novelty exercise nothing more...
I don't indulge this activity.
« Last Edit: April 24, 2019, 10:05:05 AM by kirby1923 »
'81 CX100
Rough Edge racing
« Reply #153 on: April 24, 2019, 10:11:11 AM »
 The You Tube video I liked showed a bike performing slow speed turns with the wheel and the bike leaned into the turn...It may or may not have begun by counter steering ....There seems to be some thin skins here ....I'm going to ride my bicycle in circles and see if I have to counter steer...
Offline Tusayan
« Reply #154 on: April 24, 2019, 10:23:57 AM »
One more point to clarify would be that a bicycle can be balanced while stationary by moving the front wheel contact from left to right with the bars. This is the same trail effect that allows you to steer left, go left at very low speeds.  Centrifugal force and counter steering, with or without wheels and gyroscopics as per a ski bike, takes over above walking pace.
« Last Edit: April 24, 2019, 10:30:36 AM by Tusayan »
Rough Edge racing
« Reply #155 on: April 24, 2019, 10:26:38 AM »
 If a bicycle is a valid comparison, here is my experiment...Riding a circa 1960 Hercules 26 inch three speed, I rolled down my driveway at just above walking speed, turned the bars left and the bike went left..I could not detect any counter steering on my part. But maybe it's so conditioned I don't realize I'm doing it? I did it several more times actually jerking the bars left and the bike turned left..I will try it on my old Honda dirt bike shortly  in case a bicycle isnt a good example
« Reply #156 on: April 24, 2019, 10:31:14 AM »
Yes mate I am.
And thank you for asking...(seriously)
As mentioned earlier, Physics does not obey one law at 9 mph and another at 11 mph.
If you tie a piece of cotton to each bar and go for a ride at 10 mph holding the ends of the cotton. Pull lightly on the cotton on the right side at 9 mph and you will turn left.
Do the damn same at 20 mph and you will turn left.
Do the damn same at 50 mph and you will turn left.
Naturally I’m using the example of cotton to exemplify the fact that the only inputs you can make will be subtle ones, or you’ll break the cotton and go arse up...!
This is the only place of consequence where I differ from some of the established luminaries from across the Pacific.
If I am proven incorrect, I will grab reverse without the clutch and back away red faced as I have done before and doubtless will need to again at some point.
If I’m wrong and defininitavely proven so, I’ll defer..
But I’m not..
« Reply #157 on: April 24, 2019, 10:34:15 AM »
Well..
Bugger me...!
« Reply #158 on: April 24, 2019, 10:38:08 AM »
Look.
Of all the extraneous clap trap that’s poured on this debate..?
This is the one that makes slow down a bit and if this is what Kirby’s on about, then maybe the water is a little clearer.
The jury is still out for me, but the verdict is not a slam dunk..
« Reply #159 on: April 24, 2019, 10:39:50 AM »
Right, kids are usually pretty sharp and figure things like that out on their own, even if they don't realize it.
They learn to be cheeky too, but they’re not told to be..
Rough Edge racing
« Reply #160 on: April 24, 2019, 10:46:14 AM »
 Here's a short video I just took.....Me on the old Honda...Watch as I go onto the lawn and head back towards the camera and then jerk the bars to the left...Bike turns left...I was trying really hard to avoid counter steering....Could it be I still was pushing the bars ever so slightly to the right but it's not noticeable?  The bike flying by is good special effects....
           https://www.youtube.com/watch?v=nalPASnb1b4
Online Wayne Orwig
« Reply #161 on: April 24, 2019, 11:28:10 AM »
Yep, you can see a quick right before the left turn.
« Reply #162 on: April 24, 2019, 11:28:22 AM »
Ok not bad..
Here’s one. Get two large rubber bands and stretch them from each bar end back to a point right near your nether region.
Secure the close end of the rubber bands near the tank securing bolt.
Put on your helmet.
Ride on grass.
Get the band aids.
Go for a 5 mph ride no hands, the stretch in the rubber bands will let you do this.
The natural COUNTERSTEERING of the bars will be allowed to occur due to the ability of the rubber bands to stretch.
When you are stable, (riding no hands), cut the right one.
Which way do you think the bars will swing ?...(left)
Which way do you think you’ll turn ?...(right)
The remaining left rubber band will be able to stretch as the bars swing right and a right hand turn will result.
Conclusion..?
@ 5 mph a right hand turn is initiated by a right bar push (turning bars to left) and vice versa.. :whip2:
This experiment is designed to apply a force to the bar, independent of any other bodily input, be it conscious or sub conscious.
We all say, “I pushed or pulled on this bar or that” but the rubber band will provide a sudden and unassisted input into the system that will answer the question.
Whatever that says...?
I’ll accept.
« Last Edit: April 24, 2019, 11:45:04 AM by Huzo »
« Reply #163 on: April 24, 2019, 11:28:57 AM »
 The force of gravity is a constant , the other forces involved in cornering vary with speed .
 Try this experiment , at slow speed initiate a turn by counter steering and observe what happens . Yep , if you don't put a foot down you will fall down because the force of gravity will be pushing down . The other forces aren't great enough to overcome the force of gravity at really slow speeds . Go ahead , we will wait patiently  :grin:
« Reply #164 on: April 24, 2019, 11:34:47 AM »
But please don’t die.
You owe us all an answer... :evil: :popcorn:
Rough Edge racing
« Reply #165 on: April 24, 2019, 11:36:04 AM »
  I don't see it on the last sharp turn..And I did yank the bars.....Must be very subtle......Interes ting we both see the same scene and have different points of view
« Reply #166 on: April 24, 2019, 11:57:41 AM »
Now we need to expand in to "counter leaning", when rolling speed drops below walking speed...   :evil:
« Reply #167 on: April 24, 2019, 12:10:50 PM »
A mod that promotes controversy...
Trouble in paradise..? :wink: :popcorn:
« Reply #168 on: April 24, 2019, 12:21:28 PM »
I've been promoted from "diplomatico di moto" to "agente provocatore"
« Reply #169 on: April 24, 2019, 12:24:51 PM »
We need one of each
Online Ncdan
« Reply #170 on: April 24, 2019, 01:50:37 PM »
I was reluctant to get involved in this discussion however I am going to venture out into the unknown here. After I offer an explanation based on my experience as a motor officer and having to qualify twice a year on a Precision slow speed course, I will remain silent and possibly learn something.
Counter steering does not apply here. You only apply this  technique at speed. If one is making a sharp left turn around a cone you MUST turn the bars to the left as well as leaning the entire bike sharply to the left side. Dragging the floorboards is common in these extreme  maneuvers. If there is any way a rider can make a sharp left turn by turning the bars to the right, and visa versa, please send a video  executing this  maneuver so I can learn a new  technique in precision riding.
« Reply #171 on: April 24, 2019, 02:20:08 PM »
 It is amazing to watch a really talented motor officer maneuver a large motorbike thru an obstacle course .
Online Ncdan
« Reply #172 on: April 24, 2019, 02:33:07 PM »
I agree Dusty. I still go to the  competitions to watch the young guys, some of which are two generations from me, to see if any  techniques has changed, they have not. I must admit I can no longer ride at that degree of  perfection. One must ride that way all the time to continue riding way.
« Reply #173 on: April 24, 2019, 02:56:45 PM »
 Motor officers need to have a very particular set of skills that don't come into play much under normal riding conditions . Have had the chance to ride one of the courses set up at the OHP training center at Burns Flat OK , negotiating the course requires a different mind set than normal street riding , very challenging . We have a small contingent of pursuit troopers here that employ Hayabusas , watching those guys toss around a Busa was entertaining . One of those guys lives here in Muskogee , have ridden with him a few times on his regular street bike , the man can ride a motorbike .
Online Ncdan
« Reply #174 on: April 24, 2019, 03:12:14 PM »
That's interesting, about the pursuit bikes, dangerous and interesting. In my day we did pursue on bikes but I think that practice has been discontinued if the past few years. In fact pursuits in general has been stopped except in certain circumstances such as allowing the suspect not to be stopped is more dangerous to the public that the pursuit does. I must admit I as I have gotten older tend to agree with that thought process. Police chases are extremely dangerous to the public for the most part.
Sorry if we got off topic a bit my friend.
Online Wayne Orwig
« Reply #175 on: April 24, 2019, 03:40:02 PM »
Repeat the experiment. Only this time let go of the bars. Then, avoiding any other input, make the left turn by pressing with an open hand on the left side. It will be hard to avoid other inputs at low speed, like moving on the seat.
Report back what you find.
https://www.youtube.com/watch?v=OLzB5oriblk
« Last Edit: April 24, 2019, 03:42:16 PM by Wayne Orwig »
Rough Edge racing
« Reply #176 on: April 24, 2019, 04:16:22 PM »
 Well, I did as you asked....Rolling at a speed just fast enough to be stable....Pushing with an open hand on the left bar makes the bike do a quick  very slight left lean as expected but it turns to the right  . It does not want to turn left while I'm doing this, not at all....This old dirt bike with knobby tires may steer a bit different?
« Last Edit: April 24, 2019, 04:21:37 PM by Rough Edge racing »
Offline PJPR01
« Reply #177 on: April 24, 2019, 04:17:16 PM »
Since we're talking about bicycles here, I'm surprised no one has mentioned it, but don't most people here remember riding their bike as a kid or adult with no hands and once you mastered riding in a straight line at a reasonable speed or faster, you learned how to ride going around a corner with NO hands also.  You can gently (not police style competition) get a bike to follow a curve (pedaling or not) w/o any input from the hands at all, now tell me how that translates to counter "steering" without input in the handlebars, rather than leaning and "controlling" the turn using body shifting.
P.D.  Riding a unicycle you can easily turn hard corners or gentle corners, and there are no handlebars to "push on" either.  It's body lean and input thru the pedals...so I'm guessing you'll say we are counter steering thru the pedals.
By the way, I do agree that the counter steering of push left, go left to initiate the turn is a very easy and fun way to ride when going thru extreme twisties, but for general riding, it doesn't seem to be as conscious a required decision to stay in the right spot on the road, but for sure it's happening intuitively.
« Last Edit: April 24, 2019, 05:29:27 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #178 on: April 24, 2019, 05:19:51 PM »
The main point is the rider is maintaining the turn by steering and leaning into the turn...This is my point and it's something that does not happen at higher speeds when countersteering opposite the turn alone maintains the arc of the bike into the turn...
You need to focus on the word "initiate"  Countersteering is used to initiate any turn where the bike is leaned over.
Countersteering to maintain the arc is not always the case.  On the older bikes you are used to it is probably true.  Some bikes are neutral which means you initiate the turn through countersteering and once you are on your line the bike maintains that line without any input from the rider.  Some bikes require you to apply pressure the other way to keep the bike from falling too deep into the turn.
Now I see why the first couple posters called this another oil thread.  LOL!  Please don't quote me again because I am done with this discussion.  :)
« Reply #179 on: April 24, 2019, 05:34:59 PM »
By the way, I do agree that the counter steering of push left, go left is a very easy and fun way to ride when going thru extreme twisties, but for general riding, it doesn't seem to be as conscious a required decision to stay in the right spot on the road, but for sure it's happening intuitively.
I’m going to start everything with “I think”, because I MAYBE there is more to learn here for me.
Not sure yet.
The push bike is countersteering all the time if you provide no inputs. We have all seen a pushbike or motorbike , continue on alone if a rider falls off.
You will see when the bike is in it’s final throes before it crashes, oscillations in the bars that are increasing in amplitude as the unit departs ever more from it’s stable condition.
I suggest that these oscillations are ever present, just minuscule under normal conditions.
If you lock the bars so movement is impossible, the bike will not go more than a couple of metres.
Remember the old friction dampers on bikes of yore ?
There was a small slot in the friction plate that allowed minute movement of the bars before the friction pads took hold.
This was so that minute oscillatory motion could be allowed under normal operating conditions.
