Author Topic: USB CONNECTION KIT V7 STONE  (Read 35032 times)
11201ny
« on: November 08, 2015, 10:31:19 AM »
Anyone use this? I just bought one, and am curious how it actually connects to the bike?
Offline JeffOlson
Re: USB CONNECTION KIT V7 STONE
« Reply #1 on: November 08, 2015, 10:35:09 AM »
The bike is supposedly prewired for this, so I think you just need to find the connector. Perhaps it is under the seat.
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline pyoungbl
« Reply #2 on: November 08, 2015, 01:38:24 PM »
A photo or link would most helpful for those of us who don't have a clue about said kit.
'13 V7 Special (red/white)
11201ny
« Reply #3 on: November 08, 2015, 01:46:34 PM »
Offline SeanF
« Reply #4 on: November 08, 2015, 02:08:47 PM »
On my '14 v7 Special, I found an unused connector in the wiring bundle behind the headlight that supplies 12vdc with the ignition on.
On the wiring diagram it is labeled for GPS. Not sure if the connector matches what is in the posted photo.
Might be worth looking at.
elvisboy77
« Reply #5 on: November 08, 2015, 02:29:35 PM »
Battery tender makes a nice kit, simple to install right to the battery.  That is what I did in my Eldorado, but my dealer had already unstable an "SAE" plug for me to plug my USB adapter into.  Your dealer could probably help you with this, too.
11201ny
« Reply #6 on: November 08, 2015, 04:02:42 PM »
What do you mean? You replaced what your dealer did with the Battery Tender version? I figured i'd go with the one Moto Guzzi sells with their kits. I looked around under the seat for the connector hookup, didn't see anything obvious.
« Last Edit: November 08, 2015, 04:07:11 PM by 11201ny »
Offline JProdun
« Reply #7 on: November 08, 2015, 04:37:02 PM »
Is it the one right on top/next to air filter? Ots right there... Shouldn't be hard to find really.
« Reply #8 on: November 08, 2015, 04:49:37 PM »
http://www.batterytender.com/Accessories/USB-Charger-QDC.html
You can find this for about $10.  Hooks right to the Tender pigtail on the battery.  Hope you didn't pay out the ass for that one.
11201ny
« Reply #9 on: November 08, 2015, 04:54:05 PM »
I did, i just figured since it is pre-wired...
Anyway, that would explain why nobody sells them. Does the Tender come with wires? ..Go gently, i'm a dipshit..
« Reply #10 on: November 08, 2015, 05:06:13 PM »
Do you have a Battery Tender pigtail attached to your battery?  If not, I'll send you one.  Whatever you're charging should have a long wire to plug into the USB.  And yes, if you buy a Battery Tender (Junior - I have one for each bike), it comes with an SAE pigtail to attach to the battery.
« Last Edit: November 08, 2015, 05:09:04 PM by Cam3512 »
Offline SeanF
« Reply #11 on: November 08, 2015, 05:21:09 PM »
It actually might be the correct the connector type. Here's the one I lopped off my Special:
11201ny
« Reply #12 on: November 08, 2015, 05:27:51 PM »
Thanks :boozing:
I did read that in the forums. I'll check it out.
« Reply #13 on: November 08, 2015, 05:59:55 PM »
11201ny
« Reply #14 on: November 08, 2015, 06:00:51 PM »
elvisboy77
« Reply #15 on: November 08, 2015, 06:28:24 PM »
Omg not unstable!  Auto correct!  Installed, they had already installed!  I don't think they offer a kit for the 1400.  Sorry about the confusion.
I think you did the right thing getting the official one though, even if it cost more.   That's what I would have done starting from scratch....but I am sure others will disagree.
« Last Edit: November 08, 2015, 06:30:46 PM by elvisboy77 »
« Reply #16 on: November 08, 2015, 06:41:29 PM »
What's easier than just plugging this in?
Offline davedel44
« Reply #17 on: November 08, 2015, 06:43:22 PM »
Do what suits you.  As you get more comfortable working on your bike stuff like this will seem easy.  Enjoy you bike!
Dave
Galveston
Bambino- 2013 V7 Stone
11201ny
« Reply #18 on: November 08, 2015, 06:46:33 PM »
"Hooks right to the  on the battery."
Well maybe because my battery has no Tender pigtails? Regardless, that was the point of this thread... i'm trying to figure it out.
Offline Bradkap
« Reply #19 on: November 08, 2015, 08:14:37 PM »
So, there is a GPS connector already in place on the V7 ? Is it suitable to power a Garmin ?
elvisboy77
« Reply #20 on: November 08, 2015, 08:44:07 PM »
I would ask your dealer, for sure - there is probably a plug somewhere but that stuff can get tucked out of sight.
The connector in your picture is water resistant if not waterproof, which would be one reason to stick with the factory set up.
Hopefully someone on this site with the same bike will chime in if the dealer is not available.
Also, you should try guzzitech.com forums, they are very helpful.
Good luck!
« Last Edit: November 08, 2015, 08:54:03 PM by elvisboy77 »
« Reply #21 on: November 09, 2015, 06:19:08 AM »
Yes, it's wire tied up behind the headlight between the forks.  It is green in color, and fits a Tom Tom GPS.  I changed out the connector to run my Garmin.  It's hot with the switched ignition.
11201ny
« Reply #22 on: November 09, 2015, 06:29:35 AM »
Thanks, this is exactly what I was hoping for!
 :bike-037: :boozing:
« Reply #23 on: November 09, 2015, 06:32:56 AM »
Sorry dude, didn't know you were looking for the same "GPS" plug.
11201ny
« Reply #24 on: November 09, 2015, 06:34:39 AM »
.. didn't either.
« Reply #25 on: November 09, 2015, 06:43:55 AM »
So have we figured out that's where the factory USB kit goes?
If so cool.
Me, I'm buying the Battery Tender one because every single bike in the fleet has a battery tender harness so it makes it real convenient to move it from bike-to-bike.
« Reply #26 on: November 09, 2015, 07:00:25 AM »
I just looked at Jay's new-to-him '14 Special I'm temporarily storing in my garage.  Found it right away behind the headlight on the left side behind the ear.  Easy access if you unbolt the headlight bucket.   I snapped a photo, but can't post it here until I get back home.  You can PM me with your email address and I'll send it to you.
« Reply #27 on: November 09, 2015, 07:25:15 AM »
I betcha this week is killing Jay that he can't ride it yet...  :laugh: :grin: :evil:
Offline slowmike
« Reply #28 on: November 09, 2015, 09:51:57 AM »
The piece in the picture is GU2000166.  It's USB power only.  The ability to read the data comes with the GMP bluetooth ECU 2S000157 plus one of two wiring harnesses:
2S000170-for the V7II
2S000156-for the Cali 1400
I'd spent some time researching this...
11201ny
« Reply #29 on: November 10, 2015, 07:52:55 AM »
The multimedia platform & kit. I had never heard of this until now. Is it pointless? I was just looking for a usb charge, so i could theoretically use phone navigation. Anyway, this doesn't seem to be really available in the states?
