Author Topic: Mityvac Vacuum Brake Bleeder...?  (Read 6498 times)
Offline radguzzi
« on: January 01, 2016, 12:04:51 PM »
I have been meaning to upgrade from the feeble little hand type brake bleeding rigs to a vacuum set up but I cannot tell if this one has the proper adapters for a Brembo brake caliper.
Anyone here use this particular set up that can answer that question...?  I take it also this set up is run off a compressor, any special needs there like an inline valve to regulate the air volume or anything like that...?
Thanks,
Rob
sories_vehicle_main tenance_care_decor_ vehicle_repair_spec ialty_tools_a1_othe r:na:na:na:na:na:2&code=PLA15&k_clickid=315acbd0-2205-4ef9-8723-efaa27a289dc&gclid=CKagnaOYicoCFQotHwodY6sIyQ" class="bbc_link" target="_blank" rel="noopener noreferrer">https://jet.com/product/detail/a97242703b53401ea9f71ef00583f3f6?jcmp=pla:ggl:vehicles_parts_a1:vehicle_parts_acces sories_vehicle_main tenance_care_decor_ vehicle_repair_spec ialty_tools_a1_othe r:na:na:na:na:na:2&code=PLA15&k_clickid=315acbd0-2205-4ef9-8723-efaa27a289dc&gclid=CKagnaOYicoCFQotHwodY6sIyQ
« Last Edit: January 01, 2016, 12:18:24 PM by radguzzi »
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Re: Mityvac Vacuum Brake Bleeder...?
« Reply #1 on: January 01, 2016, 12:36:29 PM »
That's what we use at dealership I work at and also have the same at home. I don't use adapters, plug hose directly on the bleeder. Everything you need is in kit, regulator is not needed on compressor in the set-ups I have worked with.
« Reply #2 on: January 01, 2016, 01:10:56 PM »
Rob, If you don't want to spend the money this one works fine:
http://www.harborfreight.com/automotive-motorcycle/brakes/brake-fluid-bleeder-92924.html
Connectors that came with the kit worked just fine. I used it on the bikes and the car with no issues.
Offline Perazzimx14
« Reply #3 on: January 01, 2016, 01:45:14 PM »
Or you can use a $2 syringe from Tractor Supply and 1 or 2 cent piece of 1/4" tubing and "reverse bleed" the brakes. After using this method I no longer use the a mity-vac.
Offline clubman
« Reply #4 on: January 01, 2016, 03:42:32 PM »
Or, you can save a lot of time and money and just install "speed bleeders" (Google it). Better, faster, cleaner, cheaper. Yes I have a "Mighty Vac" (mighty big PITA) and a Craftsman vac. kit. It took me a long time, but I finally listened to others (I'll never learn). :wink:
Offline radguzzi
« Reply #5 on: January 01, 2016, 07:47:41 PM »
Ahh. good to know, I looked at that on line, we have a HF up here also...  I could not tell by the description whether the connectors would work on the Guzzi caliper nipples.  Excellent.
Don't know if you need something that complex.  I have a hand pump unit that will suck a reservoir dry in seconds and it was pretty cheap.
I have the smaller hand pumps and just do not like them, I have had better luck with pumping by hand than with the small hand pumps.
Yeah, I don't know if I just suck at this job or what but I always have trouble with bleeding on linked brakes, getting fluid to pass through the proportioning valve and all that...
Thought about that as well, the LeMans that I need to do is not mine.  THey look to be a cool set up.
Thanks,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline jrt
« Reply #6 on: January 01, 2016, 09:05:10 PM »
Maybe it is just me, but I have had the worst luck with speed bleeders.  Every last one of them has leaked.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline yogidozer
« Reply #7 on: January 01, 2016, 09:58:13 PM »
yup
Offline Perazzimx14
« Reply #8 on: January 02, 2016, 06:17:50 AM »
Thanks,
Rob
Bleeding linked brakes on my T3 was the 1st time I used the reverse bleed method. After trying for hours on my V50 years ago with a mity vac I was really fretting doing the brakes on my T3. I had recently rebuilt the entire brake system so it was totally void of brake fluid.  Got the courage up one morning to tackle the task and to my surprise within about 20 I has a completely bled and operational set of brakes on the bike using the reverse bleed method. The mity-vac went in the trash shortly thereafter.
« Last Edit: January 02, 2016, 09:22:44 AM by Perazzimx14 »
Offline radguzzi
« Reply #9 on: January 02, 2016, 06:25:27 AM »
Bleeding linked brakes on my T3 was the 1st time I used the reverse bleed method. After trying for hours on my V50 years ago with a mity vac I was really fretting doing the brakes on my T3. I had recently rebuilt the entire brake system so it was totally void of brake fluid.  Got the courage up one morning to tackle the task and to my surprise within about 20 I has a completely bled and operational set of brakes on the bike.
So did you use the reverse bleeding method or the mityvac...?
Thanks,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline Perazzimx14
« Reply #10 on: January 02, 2016, 09:20:43 AM »
Thanks,
Rob
Trying to suck/vacuum brake fluid from a high point to a low point there is a high risk of trapping air or pulling air into the system past the bleeder screw threads. Pushing fluid from low to high and keeping "positive" pressure on the system helps push the air to the high point and will not allow air to be sucked in past bleeder screws. Air wants to rise in fluid anyway, your just helping push it along.
« Last Edit: January 02, 2016, 09:37:31 AM by Perazzimx14 »
« Reply #11 on: January 02, 2016, 09:28:35 AM »
Speed Bleeders!
Offline Perazzimx14
« Reply #12 on: January 02, 2016, 09:58:25 AM »
Speed Bleeders!
Speed Bleeders, Blah. At around $7 per speed bleeder and hearing several people like Clubman experience I'll save the money. I currently have 14 calipers I am maintaining on my bikes and at $7 each that would be over $100 shipped for something a $2 syringe does.
Offline Rich A
« Reply #13 on: January 02, 2016, 10:40:28 AM »
I haven't ever tried the reverse bleeding method as I was afraid I'd blow brake fluid onto places where I didn't want it to go. I should try this.
But I have an old vacuum pump that I hooked it up to a reservoir and it works very well.
Rich A
