Author Topic: JB weld high temp question  (Read 3134 times)
Offline Oldrat
  • Brian
« on: January 13, 2016, 01:55:09 PM »
Hi gents
Once my T3 frame has been vapour blasted, I will send it off to the powder coating company for the finish.
Having cleaned up the frame of (now) unnecessary tabs, I have some saw blade marks and minor blemishes to fill.
I've bought some JB weld (high temperature) filler after reading that it is fine to use in this situation.
Has anyone any experience of using this stuff and how it copes with the powder coating process
I think I'm just after a bit of reassurance really please. :undecided:
1976 'Zagato' Guzzi cafe racer
1978 Black & Gold, Coburn & Hughes Mk2 Le Mans
2001 Ducati 996R
2017 BMW R1200 GSA
Re: JB weld high temp question
« Reply #1 on: January 13, 2016, 02:04:15 PM »
 Aren't there some low temp powders that melt at 350 degrees or so ? What is the Hi-temp JB Weld rated for ?
Offline guzzista
« Reply #2 on: January 13, 2016, 02:35:02 PM »
Dont know if this helps, but  my local powder coater has been able to fill over small depressions, pitting or cut marks when I have given him pieces as such to coat.
Offline Groover
    • Scooteropolis
« Reply #3 on: January 13, 2016, 02:40:54 PM »
The powder coater I used told me that JB weld can be used to fill dents and such and can be powdercoated. This conversation came up when I was thinking about getting my tank powder coated and it had a dent to fill, but I ended up going with paint on those parts. I did get the frame powder coated, but I didn't fill in any of the scars before hand.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #4 on: January 13, 2016, 03:17:40 PM »
i think most powder coaters reccomend JB weld for repairs under powdercoat instead of bondo for exactly this reason...
Offline Rich A
« Reply #5 on: January 13, 2016, 03:53:31 PM »
I wanted to remove some JBW from a project and did a quick look on the 'net. The stuff is supposed to deteriorate around 600 deg as I recall. (search "how to remove JB weld")
Rich
Rough Edge racing
« Reply #6 on: January 13, 2016, 04:33:57 PM »
 You may want to read info from powder coating companies ....Some claim two part exposes will fail and to use special one part high temp filler that are available. When in doubt, ask the man who is going to do the work...If he says JB Weld is ok, get it in writing..
Offline geodoc
« Reply #7 on: January 13, 2016, 04:57:47 PM »
I've used JB weld to fill dents, divots and scrapes in 5-6 frames that were then powder coated with satisfactory results.
Offline Scud
« Reply #8 on: January 13, 2016, 06:43:05 PM »
I have used QuickSteel to repair a few imperfections before powdercoating. As with anything, the quality of your prep work determines the quality of the finish - so take your time with the sanding. I haven't used JB Weld, but if it's more liquid than the QuickSteel (which is a putty) it might be easier.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline Oldrat
  • Brian
« Reply #9 on: January 14, 2016, 02:43:31 AM »
Thanks for all the advice guys.
It seems that speaking to the PC company is the way to go.  I am optimistic as the blemishes are quite minor, as in saw marks and scratches rather than any serious dents for filling.
Thanks again
2001 Ducati 996R
2017 BMW R1200 GSA
