Author Topic: V7C shock springs  (Read 1878 times)
Offline rbond
V7C shock springs
« on: January 28, 2016, 12:57:53 PM »
Just got a pair of Ikons. Need to swap springs, problem is I need something to compress springs about 1/2 to 1 inch to remove keeper. Any home tools to do the job? I can't see buying even a $25 tool I will use only once in my life. Tried all the auto parts tool loaner programs, no tool small enough for cycle springs. I only need something for like 10 minutes, then I am done. Help please!
2012 MG V7C
1976 Suzuki GT500A
1978 Suzuki GS400C (long gone)
1973 Suzuki TS 100K (first new bike)
1969 Honda S90 (very first bike)
Re: V7C shock springs
« Reply #1 on: January 28, 2016, 01:17:28 PM »
I've only used the correct tool.  I wouldn't want to do that with a "jury rigged" set up.  Lots of energy in the spring.
Is there a shop that will assist for a few bucks?
Offline bigtex
« Reply #2 on: January 28, 2016, 01:35:54 PM »
I have seen it done with bunches of zip ties.  You can google it.
But I would spend $16 at Harbor Freight.
http://www.harborfreight.com/macpherson-strut-spring-compressor-set-61654.html
Offline pikipiki
« Reply #3 on: January 28, 2016, 02:19:09 PM »
I would not use zip ties alone.
you can do it with strong nylon rope but its a bit of a fiddle, best with two people.
make like a winch or round a few times or tension with a screwdriver through by twisting. two sets ropes lock one tension one. lock that one tension the other. repeat and repeat.
« Reply #4 on: January 28, 2016, 02:30:02 PM »
I've done it with a shop press.
I've seen home-made tools fabricated from a couple of 4x4 pieces (or metal plates) and some long threaded rod.
I betcha you could do it with a floor jack or bottle jack and some ingenuity. Bolt the other end to something (the bike, a workbench, etc.) and fabricate something for the jack to jeep the other end in place while you're working.
« Last Edit: January 28, 2016, 02:31:22 PM by Kev m »
Online John A
« Reply #5 on: January 28, 2016, 03:36:05 PM »
Just be aware that it is a quick way to loose a couple teeth if the spring gets away while under compression. I modified a large old drill press that works well.
