Author Topic: V65 airbox - pipe test...  (Read 1760 times)
Offline chrisk
« on: April 20, 2016, 05:51:26 AM »
Hi, just checking - the yellow marked pipe goes to the sump and the red is just an overflow right?
« Last Edit: April 20, 2016, 06:02:51 AM by chrisk »
Offline chrisk
Re: V65 airbox - pipe test...$100 reward
« Reply #1 on: April 21, 2016, 02:41:28 AM »
Come on, someone must know... :-)
I lied about the $100...
LaMojo
« Reply #2 on: April 21, 2016, 08:28:44 AM »
The air box looks very similar to the one on my 1984 V65C,  but the small hose arrangements are very close as being in the same positions.  I would say you are correct  in what you have labeled.
« Reply #3 on: April 21, 2016, 08:39:10 AM »
Dripage from crankcase venting comes out into the yellow lines, red one is for pressure to escape. I got rid of the boxes and used K&N's w/V65TT collector up by steering head. Well, at least I answered.
Offline chrisk
« Reply #4 on: April 21, 2016, 11:55:09 AM »
Well I'm probably gonna do that at some stage...
Did you change the jetting ? Did it run ok?
Offline v65tt
    • Streffords
« Reply #5 on: April 21, 2016, 02:24:13 PM »
I got rid of all the plumbing, and collector box on my TT, blocked the sump return with a bolt and crush washer.  Connected the two rockerbox out lets to a y barb and ran 10mm hose to rear of the bike.  Works really well and its worrying how much mayo it spits out!
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
