Author Topic: Searching for a crash bar (title change)  (Read 8102 times)
Offline normzone
« on: June 02, 2016, 11:35:55 AM »
EDIT: I hope it's not deceptive marketing, or worse to repurpose this thread, but in the interest of pixel & bit conservation...I'd hope to find the rectangular one (Cali II or III ?) but I guess should buy whatever I can find - if you've got one or a clever idea your counsel appreciated.
Thanks all for your counsel regarding yesterday's spill in the parking lot - I'll not be pursuing compensation from the trigger driver's insurance, since damage is minimal and my legal position is weak.
Before I left for work this morning I removed the highway peg/bar that so bravely gave it's best to protect the bike. I have not yet decided on appropriate honors for it - It was but a simple piece of metal, but it selflessly sacrificed so that other (more expensive) parts of the bike could live.
And when I removed the sturdy soldier from it's post, I learned that there's a BIG FREAKING HOLE IN THE FRAME  where it mounts, with a corresponding spacer/washer doodad, that appears to have also deformed in the moment that the bar took the hit.
They were Harpers Highway Pegs and Mounts 01 1081 - What did the bike have plugged in that tooth socket when it left the factory?
In this thread             http://wildguzzi.com/forum/index.php?topic=68828.0           crash bars for the Bassa are discussed - I seem to recall that a rectangular one from another model (Cali III ?) that I like the look of also fits the Bassa.
Your valuable counsel is appreciated.
« Last Edit: June 03, 2016, 11:59:08 AM by normzone »
Offline pehayes
Re: EV 11 highway pegs - what's the story ?
« Reply #1 on: June 02, 2016, 12:14:28 PM »
Don't have that model or highway pegs.  Pics would be helpful.
 :gotpics:
« Reply #2 on: June 02, 2016, 12:27:06 PM »
 Norm , were they mounted where the frame is designed to split ?
Offline normzone
« Reply #3 on: June 02, 2016, 12:39:05 PM »
Lemme guess...I have the alternate universe model Bassa. That would explain a lot.
Okay, I don't have any pics at the moment, but just to confirm, in this universe, Patrick Hayes is a highly respected specialist in the field of quantum mechanics, and Dusty is a retired counsellor of the Multiverse Investigation Bureau - correct? Because if not, then my worst fears are confirmed - I have slipped again.
« Reply #4 on: June 02, 2016, 12:47:33 PM »
Still on the meds?  Describing the doodad is probably more productive than describing the alternate universe.
I suspect what you're looking at is the lower front crash bar mount hole and the spacer from the crash bar is being used to position the highway peg.  Was there an odd flat nut with a 19mm head holding it in place?
« Reply #5 on: June 02, 2016, 12:49:10 PM »
 Norm , yes you may have slipped into a different universe than ours , extensive testing completed just before I retired from MIB indicates some cross communication is likely , in fact WG is the most efficient conduit for said communication . That becomes obvious if you read enough of the activity here  :shocked:
 Or , we could just be having a Green Acres moment  :laugh:
Offline kidsmoke
« Reply #6 on: June 02, 2016, 01:28:31 PM »
in this Tonti/Cali universe....I believe this is the most common configuration of which you speak....no?
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
« Reply #7 on: June 02, 2016, 01:49:45 PM »
 Probably so Kid , Norm is this it ? Oh Norm , where fore art thou Norm ? :grin: Anyway , that is where the lower frame rails attach to the front down tubes , fairly important .
Offline normzone
« Reply #8 on: June 02, 2016, 02:48:42 PM »
Thanks Dusty - Yeah, that's it. The Bassa has the peg support going into that location where the crash bar is mounted in your picture.
Looks like when I buy the crash bar I'll have to pull the pipes to install it. What damn fool came up with that idea?
I swear, they'll let anybody be a design engineer these days...
So what other useful tasks can be accomplished while the pipes are off, other than the obvious sending them out to be ceramic coated, which I (red suspender moment here) don't really want to do, when a rattle can of high heat white/gray/black will serve.
Can I port and polish the exhaust pipe exits from the head? What about putting deer whistles in the pipes?
Offline twhitaker
« Reply #9 on: June 02, 2016, 02:56:20 PM »
If I remember correctly it's a M12 x 50 socket head cap screw but that might be too long. There's a big hex nut on the back that's a real pain to get to.
I think there is wiggle room. If not, taking off one pipe should be enough.
« Last Edit: June 02, 2016, 03:26:24 PM by twhitaker »
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #10 on: June 02, 2016, 02:56:50 PM »
  :laugh: Grease the header bearings   :rolleyes: Seriously , a bit of high temp grease where everything mates together can't hurt , like where the headers enter the mufflers , etc . AND , it probably isn't necessary , but since you are already pulling the pipes , a good time to retorque the heads . Of course some would suggest my head needs , well , you get the idea ...
 Oh , thank Kidsmoke for the pic , I just appropriated it for my own glory  :grin:
Offline kidsmoke
« Reply #11 on: June 02, 2016, 03:12:58 PM »
Well you kinda had to. From what I can tell, your bike woefully camera shy....
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #12 on: June 02, 2016, 03:21:20 PM »
 Takes after its rider  :rolleyes: Never can figure out why folks take pics of me at our gatherings and then scare the internet by posting those pics , that has to hurt someone's eyes  :copcar:
« Reply #13 on: June 02, 2016, 03:28:52 PM »
Why?
A little maneuvering and the crash bar will go right on, without removing anything...
Online fotoguzzi
« Reply #14 on: June 02, 2016, 03:32:53 PM »
Why?
« Reply #15 on: June 02, 2016, 03:34:44 PM »
Why?
 Don't confuse him Mike , maybe Norm just wants the experience  :rolleyes: Yes , no need to pull the headers , unless my first assessment is correct ...
Red Dog
« Reply #16 on: June 02, 2016, 05:30:07 PM »
KidSmoke: That is one beautiful Jackal!!!!!
Apologies to the OP for bumping the thread but I just had to comment.
Offline normzone
« Reply #17 on: June 02, 2016, 06:46:37 PM »
Hey, is this well worn piece a fit for the Bassa ? It kinda looks like it would be...
http://www.ebay.com/itm/moto-guzzi-crash-bars-/231849222992?hash=item35fb4a6350:g:ew4AAOSwB4NWxUUM&vxp=mtr
Put some of that exhaust pipe wrap stuff on it and it's good to go.
« Last Edit: June 02, 2016, 06:47:30 PM by normzone »
Offline twhitaker
« Reply #18 on: June 03, 2016, 11:19:06 AM »
I vaguely remember seeing a set like that. Notice the lower attachment. Different from the Jackal mount above. Might be for a small block.
MGNOC-11168
Dayton, OH
LaMojo
« Reply #19 on: June 03, 2016, 11:43:36 AM »
V65c, maybe others as well.
Offline normzone
« Reply #20 on: June 03, 2016, 11:44:54 AM »
Hmmm, you're right. Dammit...
Last time I wanted to buy a crash bar, I ran out of money.
Today I have both money and motivation. I prefer the rectangular look, but I guess if I was clever I'd mount anything there and call it clever. The money will only last so long - and you know what the Furry Freak Brothers said.
Offline twhitaker
Re: Searching for a crash bar (title change)
« Reply #21 on: June 03, 2016, 12:23:00 PM »
My bikes wear their bruises like badges of honor. I even put a bullet hole sticker over one of them.
MGNOC-11168
Dayton, OH
Offline normzone
« Reply #22 on: June 03, 2016, 01:00:54 PM »
Hmm...I am going to try polishing compound on the fairing mar, but I like your approach.
Offline normzone
« Reply #23 on: June 03, 2016, 01:35:59 PM »
" And I'm gettin' old " (cue harmonica)
« Reply #24 on: June 03, 2016, 02:34:26 PM »
One of the all-time best harmonica songs, ever.
I'll trade you my square crash bar for your leading link front forks.
No, seriously.  I will.  Straight across.  You don't even have to add cash.
« Reply #25 on: June 03, 2016, 03:05:10 PM »
What makes this a truly great deal is that unlike all the other offers for trades in this topic, I actually possess the crash bar under discussion.  It's not one of those "Send me your leading link forks and then I'll check my stash and see if I have the crashbar" sorts of deals that you normally see offered in these situations.  I can dig it out of a tote in under a half hour.  How can you lose?   :thumb:
Offline kidsmoke
« Reply #26 on: June 03, 2016, 03:20:31 PM »
normzone, did I miss pics of said damage somewhere else? The jackal pictured above took about a 20 yard skid down a highway a few weeks back. Ground off a good 3/16" of steel, but they didn't bend at all. The highway pegs, also pictured, also lost a bit of skin and did bend just a tad, but the rest of the bike  did fine, barely even a scratch...all to say, they work. And well. I'd not consider another set up after what I experienced. Simply cant be improved upon, IMHO.
Good luck in your quest.
Oh, and Red Dog, thank you kindly. I'm rather fond of it myself.
« Last Edit: June 03, 2016, 03:21:24 PM by kidsmoke »
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline normzone
« Reply #27 on: June 03, 2016, 03:26:33 PM »
Nah, no pics yet - life is too busy.
So is this squaretangular crash barre I seek made of unobtanium? Searches in the USA make it appear so. Do I need to ask [Daniel Kalal] to bring one back from the factory for me?
« Last Edit: June 03, 2016, 05:22:10 PM by normzone »
Offline normzone
« Reply #28 on: June 03, 2016, 04:20:54 PM »
Thanks [JNMathews], that is the one. I just came from a google image search to confirm.
I remember seeing one of those at Sonny Angels in National City in the eighties, and my dumb self thinking " who would ever want that kind of bike ? ".
Memo to self: Kick self when I get home - they're beautiful. I was just accustomed to my stripped down Eldo.
Offline davedel44
« Reply #29 on: June 03, 2016, 04:55:43 PM »
No I don't but Fat Freddy's cat caped in my shoe once.   :undecided:
Bambino- 2013 V7 Stone
