Author Topic: Need help with Eldorado saddlebag mounting  (Read 2350 times)
Offline Farmer Dan
« on: June 03, 2016, 11:16:12 AM »
I found out that Dad had bags mounted from a 1972 Harley XLH, took some serious searching but I found a pair with the mounts.  My problem is they mount to the shock mount and rear seat bolt.  The shock stud does not have enough threads on it, is there a longer one?  Looks like I'm also missing a spacer that should go on the bolt for the rear seat mount.  Does anyone know how long that spacer is?  Thanks for your help.  If anyone is curious what a HD Sportster hard bag looks like here is a picture.
Hope to have these cleaned up and on the bike in time for the show at Gilmore.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
Offline John Ulrich
Re: Need help with Eldorado saddlebag mounting
« Reply #1 on: June 03, 2016, 11:27:32 AM »
On my DB bags there is an offset bracket.  Go to Home Depot or equivalent and get some metal and bend it to suit.
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #2 on: June 03, 2016, 11:32:05 AM »
The wixom set up used a long nut that supplied extra female threads , then you put a bolt thru the bag bracket
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline Farmer Dan
« Reply #3 on: June 03, 2016, 11:35:35 AM »
I was just thinking about calling you :-) but you just answered my question.  Guess it's time to blow the dust off my lathe and start making stud extensions.  Thanks.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
« Reply #4 on: June 03, 2016, 01:09:29 PM »
For the shock stud mount, I use metric coupling nuts from McMaster-Carr:
http://www.mcmaster.com/#90009A223
The spacer between the grab rail and frame is 15 mm long.
Offline Farmer Dan
« Reply #5 on: June 03, 2016, 03:16:04 PM »
Thanks Charlie, I ordered  a bunch of them since I don't like cutting internal threads on a lathe.  Should be easy to make the spacers.
1972 Eldorado
1940 Ford 9N
1937 Browning A5
I love old iron
