Author Topic: Need ID of EV/Jackal upper fork tubes  (Read 2452 times)
Online rodekyll
« on: June 19, 2016, 05:05:17 PM »
Title says it -- if someone has a bare upper tube for an EV/Jackal (late model Tont = 45mm outside?) lying about, could you measure the inside diameter for me?  Thank you kindly!
(edited for typo)
« Last Edit: June 19, 2016, 05:06:06 PM by rodekyll »
Re: Need ID of EV/Jackal upper fork tubes
« Reply #1 on: June 19, 2016, 08:44:29 PM »
FOTOGUZZI GO OUT AND MEASURE THE ID OF THAT SPARE SET OF TUBES.!,! I may want to buy them, let's talk
« Reply #2 on: June 20, 2016, 06:58:35 AM »
Brad probly doesn't have the plugs out or the lower legs off. He told me he had a set off an EV, I may buy them for another project I have in mind.
Offline stEVe
  • speed safe!
« Reply #3 on: June 20, 2016, 07:06:54 AM »
I've got a set for sale. They are attached to my 98 EV. New seals a while back. 86,000 miles or so on the bike. Cosmetically not the best but mechanically sound and you can drive it anywhere!. $2,000. It's listed on the classifieds on this site.
Steve Parendo
98 HD&M EV- mine
01 Jackal     - Luanne's
07 Norge    - mine
08 Goldwing - Luanne's
08 Cal Vintage- mine
ALAZARCACOFLGAIDILI NIAKSKYMDMIMNMSMOMT NENVNMNYNCNDOHOKORP ASCSDTNTXUTVAWAWVWI WYsm
« Reply #4 on: June 20, 2016, 07:50:10 AM »
I'll take apart tonight and get the measurement.
Orange Guzzi
« Reply #5 on: June 20, 2016, 08:53:19 AM »
I replaced my upper tubes with a set from a Bassa.  I now have compression and rebound dampening.  Direct replacement.  Along with seals and teflon coated bushngs.  Good luck finding  donor pair though.  I do have the oem Jackle set with after market compression dampers, YSS brand.
Online rodekyll
« Reply #6 on: June 20, 2016, 01:07:56 PM »
I'm trying to find out how close the ID of a jackal/EV tube is to the OD of various leading link forks that I know are too small a tube to fit my trees.  If they fit the forks, perhaps with heat and presswork, I could slide them up the tubes and weld them in place.
