Author Topic: Cheap Welding & Grinding Curtain  (Read 2109 times)
« on: July 31, 2016, 10:03:20 PM »
I am often too lazy in the winter to move the car out of the garage when I need to grind or weld something and too many times the grinding lands on the car, not good.
So long before winter returns and now that I bought a new welder I splurged the $70 bucks for a welding curtain and from Home Depot a cheap curtain rod for $10 bucks and some shelf brackets and I have a curtain I can quickly slide into place and save the paint on the car.
I screwed the shelf bracket to the ceiling and then bolted the curtain rod bracket to the shelf bracket. I used a chain link, bulk box from Home Depot for about $16 bucks, double up the little rollers that glide on the curtain track to each eyelet on the curtain.
For well under $100 I have a flame and UV retardant curtain and no more excuses to isolate my welding and grinding from the rest of the shop.
Re: Cheap Welding & Grinding Curtain
« Reply #1 on: August 01, 2016, 02:09:06 AM »
  I like the lathe, where is the milling machine?
Offline Groover
    • Scooteropolis
« Reply #2 on: August 01, 2016, 07:52:28 AM »
That's a dreamy garage, nicely done! You should see mine.. actually you don't want to see mine  :grin:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #3 on: August 01, 2016, 11:36:22 AM »
My off shore (China or Taiwan??) milling machine has crapped out for the third time, never blows a fuse, just burns out motors cutting aluminum, POS!! It's back at the repair depot where it sits for weeks on end before I get a call that it needs parts that takes weeks and weeks to get. I wish I had not been so cheap (Guzzi content) and bought a machine of decent quality rather than sinking $2K into this money pit. :Beating_A_Dead_Hors e_by_liviu
If only I had a another 100 square feet of shop space a Bridgeport would be sitting on the floor.
Online John A
« Reply #4 on: August 01, 2016, 11:49:40 AM »
I got welding curtains from a welders supply but they are heavy white things, makes them hard to use, 25 bones . I like yours, I'll get some like it, easier to use. I'm in a constant battle against grinding and welding dust, air circulation filters and all that but it still gets all over.
