Author Topic: Magni bevel box leak at pinion.  (Read 1963 times)
Mad Murph
« on: August 15, 2016, 08:21:15 AM »
Hi fans of the V,
Almost finished the resto of my Magni Le Mans and there appears to be a missing seal.
Does anyone out there know if there's an oil seal for the bevel box pinion.
Oil is leaking out through the bearing and into the Magni Parallelogrammo bracket that mounts onto the drive box. (red arrow)
And the main pinion nut has what appears to be a bearing face on it (blue arrow) which is fairly rough so I need a new one of those as well if I find a seal to fit. I've measure the inside of the bracket housing and the face of the nut that would take the inner lips of the seal.
OD: 47mm
Width: 7 or 8mm
I have found after market seals that would appear to fit, but would like the "real thing" if possible.
Any help would be grand.
Mad Murph
850 LM 2 for 27 years and a Magni Le Mans for 16 years.
Orange Guzzi
Re: Magni bevel box leak at pinion.
« Reply #1 on: August 15, 2016, 08:44:30 AM »
You should be able to find a shaft seal for a couple of bucks u.s.   Nothing special. Look at the old seal and see if you can read the numbers on it.  Use a dual lip seal.  It will seal better.
Offline Old Jock
« Reply #2 on: August 15, 2016, 09:54:32 AM »
I don't recall anything special about the bevel box of the Magni, the drive shaft is very different, but not the box
Its been a while since I looked at mine
As I remember there is an O ring on the pinion but that's about it.
The my LM 1000 parts manual only shows an O ring too
This is all just off the top of my head mind so I could be (and often am) wrong
You could also contact Giovanni Magni and ask as well, although it may take several attempts to elicit an answer.
I'd also add that his parts prices are reasonable, I've gotten a few parts direct and he is not out to rip you off, which is surprising considering the bikes are not exactly thick on the ground. He still supplies parts for nearly every model (I just got a spare fairing for mine a few weeks back)
« Last Edit: August 15, 2016, 10:30:41 AM by Old Jock »
Orange Guzzi
« Reply #4 on: August 15, 2016, 06:16:38 PM »
There is a shaft seal inside the cone section.  You can see in the top picture where it has been rubbing on the stepped/shouldered nut.  I know on my Magni, there is an shaft seal inside the swingarm where the gear box attaches and the shouldered nut passes thru.  Or inside where you have the arrow pointing.  I have the original Tonti style swingarm.
file:///C:/Users/Owner/AppData/Local/Microsoft/Windows/INetCache/IE/39V11Y3K/Seal-Specification-Guide.pdf
1.299 x 1.850 x 1.859 x 0.276 Pn 223340 320 S 33 x 47 x 7
BMW Shaft Seal 35x47x7 Pinion Gear Seal R100 R80 R1100 R850 R1200 K1100 K1200
« Last Edit: August 15, 2016, 06:49:52 PM by Orange Guzzi »
Mad Murph
« Reply #5 on: August 16, 2016, 04:01:01 AM »
Cheers team, I have all the O rings but they don't stop this prob.
I think Orange Guzzi is in the right area. I've ordered 2 seals 47/33/7 & 47.3/33/8 to see which fits better in the "cone" of the bracket
 Have contacted Giovanni, but it's August and Italy is on holiday. :)
Brace yourselves
