Author Topic: Throttle lock type for Calvin  (Read 5364 times)
Online Ncdan
« on: November 05, 2016, 11:05:45 AM »
Can anyone suggest a simple working throttle lock for a 07 Calvin. I have even considered simply unhooking the throttle return spring if it can be done easily. If this sounds radical I am very familiar and use to this method. As an ex motor cop this procedure was did on all our bikes as we had to have a free right hand on demand. Responses appreciated up front.
Offline Dean Rose
    • Twin Valley Riders
Re: Throttle lock type for Calvin
« Reply #1 on: November 05, 2016, 11:10:08 AM »
I can switch it from one bike to the other.
https://www.amazon.com/Go-Cruise-2wheelride-Universal-Throttle/dp/B00ERXG4TM/ref=sr_1_1?ie=UTF8&qid=1478362137&sr=8-1&keywords=motorcycle+throttle+lock
Dean
« Last Edit: November 05, 2016, 11:11:21 AM by Dean Rose »
Magnolia '02 EV
Sophia '06 Breva 1100
Offline dlapierre
    • Habitat Farm
« Reply #2 on: November 05, 2016, 11:33:56 AM »
A 1" rubber "0" ring around the heel end of the throttle is what I use on mine. It increases the return friction just enough that you can release your hand from the throttle for, say, 20 seconds before having to nudge it up again. Otherwise, the throttle feels normal. Can't get simpler than that.
« Reply #3 on: November 05, 2016, 12:33:04 PM »
« Reply #4 on: November 05, 2016, 01:34:19 PM »
 :blank:
Offline Sheepdog
« Reply #5 on: November 05, 2016, 03:24:03 PM »
I use a modified Vista Cruise. It is locked to the Throttle pod with a self tapping stainless screw. This turned out to be the best solution for me...and it was cheap.
http://www.aerostich.com/a-to-b-utilities/rider-comfort/cruise-controls/vista-cruise-control.html
« Last Edit: November 05, 2016, 03:27:53 PM by Sheepdog »
Offline ccoli
  • What? Me Worry?
« Reply #6 on: November 05, 2016, 06:58:00 PM »
While rodekyll was visiting, we drove by Marker Machine. It is the home of the Throttle meister. Pointed the shop out to him. See in the local paper that there are having a complete auction. Not sure if the Throttle Meister will be available any more.
I love them.
Wisconsin MGNOC Rep
Offline willowstreetguzziguy
« Reply #7 on: November 05, 2016, 07:10:36 PM »
On my 1200 Sport, the distance between the throttle grip and the bar end was the same width as a bungee cord. I took an old bungee cord, wrapped it around that vacant space (with no tension) zip tied it, cut off the excess and that's it! In a split second I can move it from its off position on the bar end to ON position lodged between the grip and bar end when I want the throttle to be wedged in place. Still able to operate the throttle. Taking it off is a split second pull onto the Barend.
2008 Guzzi 1200 Sport
« Reply #8 on: November 05, 2016, 07:35:33 PM »
Throwing this into the mix.  I have one on SP1000.  It was a gift.  Works well.
https://www.amazon.com/Throttle-Rocker-TR-101-Right-Handed/dp/B00HGHM468
Offline stevet
« Reply #9 on: November 05, 2016, 07:54:54 PM »
http://www.aerostich.com/go-cruisetm-throttle-control-1.html
These work very well.  Tossed the Uni. Vista in the trash after clipping this on.  You'd probably want the larger model.  I've got them on both bikes.
Steve.
Steve T.
Twin Cities, MN
Feejer, '10 Yamaha FJR
-George Eastman.
Online Ncdan
« Reply #10 on: November 05, 2016, 08:19:07 PM »
i have one of those Tom, they work great, just won't hold the throttle:(
Online Ncdan
« Reply #11 on: November 05, 2016, 08:23:41 PM »
Yea, I forgot about the O ring trick that does do a fare job of briefly holding the throttle for a clothing adjustment or getting a bee out of your shirt, thanks for the reminder!
« Reply #12 on: November 05, 2016, 08:25:16 PM »
Yeah, it doesn't stay open.  Okay...."never mind".
Online Ncdan
« Reply #13 on: November 06, 2016, 01:16:27 PM »
Tom, they really do work great when on an extended riide as your wrist is under no pressure. It would be great if they would incorporate these with some type of lock system.
« Reply #14 on: November 06, 2016, 01:39:24 PM »
One of the friends uses a leather strip/string with a Throttle Rocker.  Uses it as a friction type throttle lock.  Loop it around the grip and use it to hold open the throttle.  Cheap and easy to use.  I always forget about adding one but remember on a long ride.   :grin:
Offline Scott DeRoss
« Reply #15 on: November 06, 2016, 06:29:30 PM »
I have had one of these on my vintage for years. Works great but pricey. Must use metric version.  https://www.brakeawayproducts.com/productinfo.html
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
Online Ncdan
« Reply #16 on: November 06, 2016, 07:02:51 PM »
Can anyone advise if they have used or know anyone who has simply disconnected the throttle springs? This was the method we used on the patrol bikes when I was a motor officer, on the Harley's and later on the 900 Honda customs. This was back in the early 80s so I'm sure other techniques are used on today's cop cycles.
« Reply #17 on: November 06, 2016, 08:03:59 PM »
Dan,
Can't reply to your PM, the system is still down.  Got your reply in an email notification (how did you reply to my PM?).
Anyway, I'll dig it up and mail this week.  Free trial.
Cam
« Reply #18 on: November 06, 2016, 08:14:17 PM »
Dan,
Cam
Figured out an end around to reply to PM.  Sent.
Offline ITSec
« Reply #19 on: November 06, 2016, 10:17:05 PM »
I love them.
Interesting - and sad to hear. However, some Internet searches show notices regarding the auction, but don't show any results for liquidation or bankruptcy. With any luck, it's an orderly re-organization and the owner(s) and products will see daylight down the road.
I've put a Throttlemeister on every bike I've owned since 2002, except for my DRZ-400 Super Motard (who'd lock the throttle on a Super Motard?!?  :grin: )
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #20 on: November 06, 2016, 10:28:38 PM »
A Calvin is a fuel injected bike. You can't simply unhook a spring.  Are you wanting less fight to twist/hold the throttle, or are you wanting it to have zero return when you let it go yet no resistance to rolling on/off?
Offline CPRMan
« Reply #21 on: November 07, 2016, 01:51:25 AM »
Its not quite the same, but I used a Crampbuster on my CalVin, the best $5 I ever spent.
« Last Edit: November 07, 2016, 01:52:07 AM by CPRMan »
Offline Cross-tie Walker
« Reply #22 on: November 07, 2016, 04:02:36 PM »
Attn :SheepDog
Can you give some details on modifying that Vista Cruise for your Vintage? That's a nice clean setup.
(I sent you a PM but I think it is still down.)
Many thanks
Kevin in Seattle
'72 Eldo
'07 Vintage
Offline Sheepdog
« Reply #23 on: November 07, 2016, 11:34:36 PM »
To install the Vista Cruise, all that is needed is to trim the locking tab and drill a hole in it. Fasten the locking tab to the throttle pod with a stainless self-tapping screw, taking care to avoid the split and without interfering with the cables within. The photo in my previous post really shows all you need to see. It has a tension adjustment, so it can be as loose or as tight as you wish. It works great...
Online Ncdan
« Reply #24 on: November 08, 2016, 03:25:11 PM »
I just want some way to hold the throttle for a bit in the event I need to use my right hand for a few seconds such as zip a zipper or get a bed out of my shirt. I have alwYs used the vista Cruz throttle lock but they don't show one for the Calvin
Online Ncdan
« Reply #25 on: November 08, 2016, 03:27:49 PM »
Thanks sheep, looks like that may work. I just can't figure out why these companies won't in luxe moto guzzy in the product line up:(
« Reply #26 on: November 08, 2016, 03:45:26 PM »
Might not be worth the business.
Offline Sheepdog
« Reply #27 on: November 08, 2016, 05:03:48 PM »
Tom's right; Moto Guzzi is a tiny fraction of the US motorcycle market. However, that's what lends the marque exclusivity. Besides, I like solving problems on my bikes. I like figuring things out and making a motorcycle mine...mine in a singular way. There are very few CalVins out there...and even fewer that are turned out like mine. I like that.
Offline Guzzidad
« Reply #28 on: November 08, 2016, 05:17:22 PM »
   Instead of screwing my Vista Cruise to the throttle pod I glued it with hi temp Permatex RTV.
