fuel tank rattle
Topic: fuel tank rattle (Read 1540 times)
gearman
fuel tank rattle
November 08, 2016, 03:49:25 PM »
I finally studied why my converts tanks all rattled. The whole concept of holding 30 pounds of mass with a rubber bungee that stretches 2 inches with 23 pounds of force is a joke. The bottom of my tank has wear points on it from the bouncing. When it was full it bounced less, but still a horrible design. I made a real hold down that eliminates all bouncing. I can't believe I have fought this problem for 20 years on all my converts.
yogidozer
Re: fuel tank rattle
Reply #1 on:
November 09, 2016, 08:34:43 AM »
I saw your previous post, and advised to remove the tank and look for rub/wear spots. Many manufactures use that bungee system. Even when held tight, I think a rubber/foam cushion is a good idea.
gearman
Reply #2 on:
November 09, 2016, 08:56:53 AM »
I still have the rubber cushions, but don't use the bungee to hold the tank tight against. I did the math and the bungee on the guzzis are not reliable.
thomas
Hatchling
Reply #3 on:
November 09, 2016, 11:28:52 AM »
Good design!
Funnily enough I've never had that problem on my two SP1000's (same frame & tank) or on my two 850 LeManses (same frame, different tank).
Guzzi riders represent the ragged fringe of motorcycling!
1980 Guzzi SP1000 & 1979 Guzzi 850 LeMans II
1969 Honda CB750 Four & 1971 CB750 Four & 1977 Seeley CB750F
1996 Yamaha YZF750SP
1983 Bimota KB-3
1966 Ducati 50 SL/1
1938 Miele 98cc & 1955? Miele 50cc
fuel tank rattle
