Author Topic: Any thoughts on the amount of energy required to compress valve springs?  (Read 4425 times)
On my desk in my office I have one intake and exhaust valve and one valve spring.  They came from my 1991 R100GS when I had the shop refresh the engine top end with new valves, guides, and springs.
Just for grins, I tried to compress the valve spring by placing it between the heels of my hands and compressing it.  It wasn't happening.  I could budge it less than a quarter of an inch ... no more.
This got me to thinking about the Ducati Desmo design.  Although it is complicated compared to a more conventional valve actuation design, the fact that it doesn't require a heavy valve spring to control returning the valve to its seat may have more benefits than I've thought about in the past.
Granted, the old airhead design is 2v per cylinder, and being heavier than smaller valves from 4v per cylinder designs, probably required much heavier springs.
I guess my question is ...... how much additional power is required to compress heavy valve springs vs controlling valve motion via desmodromic actuation?
Offline pyoungbl
Re: Any thoughts on the amount of energy required to compress valve springs?
« Reply #1 on: November 16, 2016, 09:18:11 AM »
I cannot give you a NM figure but the energy consumed is substantial.  I'm told that the highest metal to metal pressure in an engine is between the cam and lifter, due to that spring pressure.  Where I could easily rotate my Ducati 1000DS engine by hand (with the spark plugs removed), and stop that rotation at any point in order to check the valves, my little 250cc single has enough spring pressure to make the same rotation difficult.  On the 250 the engine wants to jump past TDC due to the spring pressure.  I also found that, once broken in and set correctly, the desmo valves would stay in spec for a very long time.  That is surely due to the reduced wear at the cam/lifter interface.  The most recent Ducati engines have valve check intervals of about 17K miles (if I recall correctly).  That's a huge improvement over the 7500 mile checks on some earlier engines.  On the down side, checking those valves is still very labor intensive, even if they are still in spec.
Peter Y.
'13 V7 Special (red/white)
« Reply #2 on: November 16, 2016, 09:23:59 AM »
And much of the energy used to compress the springs, is returned to the motor on the 'downhill' slope of the cam.
« Reply #3 on: November 16, 2016, 05:10:55 PM »
 Can't find w reference , but didn't Mr Norton experiment with a desmo very early on ?
kirby1923
« Reply #4 on: November 16, 2016, 05:42:43 PM »
Virtually every major engine manufacturer on the planet experimented with desmo type valve trains at one time or another. They are just too noisy and no one could  figure a method to use hydraulic lifters.
Norton used "mouse trap" spring(s) on the Manx!
Valve train design is like everything else, complicated and a compromise.
« Reply #5 on: November 16, 2016, 05:46:22 PM »
 Quote: Just for grins, I tried to compress the valve spring by placing it between the heels of my hands and compressing it.  It wasn't happening.  I could budge it less than a quarter of an inch ... no more.
You didn't eat your wheaties
« Last Edit: November 16, 2016, 05:47:34 PM by Sasquatch Jim »
kirby1923
« Reply #6 on: November 16, 2016, 05:54:03 PM »
Desmodromic valve
From Wikipedia, the free encyclopedia
Jump to: navigation, search
 In general mechanical terms, the word desmodromic is used to refer to mechanisms that have different controls for their actuation in different directions.
 Desmodromic poppet valve in Ducati engine.
A desmodromic valve is a reciprocating engine valve that is positively closed by a cam and leverage system, rather than by a more conventional spring.
The valves in a typical four-stroke engine allow the air/fuel mixture into the cylinder at the beginning of the cycle and exhaust gases to be expelled at the end of the cycle. In a conventional four-stroke engine valves are opened by a cam and closed by return spring. An engine using desmodromic valves has two cams and two actuators, each for positive opening and closing without a return spring.
6
Etymology[edit]
The word comes from the Greek words desmos (δεσμός, translated as "bond" or "knot") and dromos (δρόμος, "track" or "way"). This denotes the major characteristic of the valves being continuously "bound" to the camshaft.
Idea[edit]
The common valve spring system is satisfactory for traditional mass-produced engines that do not rev highly and are of a design that requires low maintenance.[1] At the period of initial desmodromic development, valve springs were a major limitation on engine performance because they would break from metal fatigue. Vacuum melt processes developed in the 1950s helped remove impurities in the steel used to make valve springs, although after sustained operation above 8000 RPM often springs would still fail.[2] The desmodromic system was devised to remedy this problem. Furthermore, as maximum RPM increases, higher spring force is required to prevent valve float, leading to increased cam drag and higher wear on the parts at all speeds, problems addressed by the desmodromic mechanism.
Design and history[edit]
 Desmodromic poppet valve example.
Fully controlled valve movement was conceived during the earliest days of engine development, but devising a system that worked reliably and was not overly complex took a long time. Desmodromic valve systems are first mentioned in patents in 1896 by Gustav Mees.[citation needed] Austin's marine engine of 1910 produced 300 bhp and was installed in a speedboat called "Irene I"; its all-aluminium, twin-overhead-valve engine had twin magnetos, twin carburetors and desmodromic valves.[3] The 1914 Grand Prix Delage and Nagant (see Pomeroy "Grand Prix Car") used a desmodromic valve system (quite unlike the present day Ducati system).[4]
Azzariti, a short lived Italian manufacturer from 1933 to 1934, produced 173 cc and 348 cc twin-cylinder engines, some of which had desmodromic valve gear, with the valve being closed by a separate camshaft.[5]
The Mercedes-Benz W196 Formula One racing car of 1954-1955, and the Mercedes-Benz 300SLR sports racing car of 1955 both had desmodromic valve actuation.
In 1956, Fabio Taglioni, a Ducati engineer, developed a desmodromic valve system for the Ducati 125 Grand Prix, creating the Ducati 125 Desmo.
He was quoted to say:
The specific purpose of the desmodromic system is to force the valves to comply with the timing diagram as consistently as possible. In this way, any lost energy is negligible, the performance curves are more uniform and dependability is better.
The engineers that came after him continued that development, and Ducati held a number of patents relating to desmodromics. Desmodromic valve actuation has been applied to top-of-the-range production Ducati motorcycles since 1968, with the introduction of the "widecase" Mark 3 single cylinders.
In 1959, the Maserati brothers introduced one of their final designs: a desmodromic four-cylinder, 2000cc engine for their last O.S.C.A. Barchetta.
Comparison with conventional valvetrains[edit]
In modern engines, valve spring failure at high RPM has been mostly remedied. The main benefit of the desmodromic system is the prevention of valve float at high rpm.
In traditional sprung-valve actuation, as engine speed increases, the momentum of the valve will eventually overcome the spring's ability to close it completely before the piston reaches TDC (top dead centre). This can lead to several problems. First, and most damaging, the piston collides with the valve and both are destroyed. Second, the valve does not completely return to its seat before combustion begins. This allows combustion gases to escape prematurely, leading to a reduction in cylinder pressure which causes a major decrease in engine performance. This can also overheat the valve, possibly warping it and leading to catastrophic failure. In sprung-valve engines the traditional remedy for valve float is to stiffen the springs. This increases the seat pressure of the valve (the static pressure that holds the valve closed). This is beneficial at higher engine speeds because of a reduction in the aforementioned valve float. The drawback is that the engine has to work harder to open the valve at all engine speeds. The higher spring pressure causes greater friction (hence temperature and wear) in the valvetrain.
The desmodromic system avoids this problem, because it does not have to overcome the static energy of the spring. It must work against the momentum of the valve opening and closing, and that force still depends on the effective mass of the moving parts. The effective mass of a traditional valve with spring includes one-half of the valve spring mass and all of the valve spring retainer mass. However, a desmodromic system must deal with the inertia of the two rocker arms per valve, so this advantage depends greatly on the skill of the designer. Another disadvantage is the contact point between the cams and rocker arms. It is relatively easy to use roller tappets in conventional valvetrains, although it does add considerable moving mass. In a desmodromic system the roller would be needed at one end of the rocker arm, which would greatly increase its moment-of-inertia and negate its "effective mass" advantage. Thus, desmo systems have generally needed to deal with sliding friction between the cam and rocker arm and therefore may have greater wear. The contact points on most Ducati rocker arms are hard-chromed to reduce this wear. Another possible disadvantage is that it would be very difficult to incorporate hydraulic valve lash adjusters in a desmodromic system, so the valves must be periodically adjusted, but this is true of typical performance oriented motorcycles as valve lash is typically set using a shim under a cam follower.
Disadvantages[edit]
Gnome-searchtool.svg
 This section's factual accuracy is disputed. Please help to ensure that disputed statements are reliably sourced. See the relevant discussion on the talk page. (June 2011) (Learn how and when to remove this template message)
Before the days when valve drive dynamics could be analyzed by computer, desmodromic drive seemed to offer solutions for problems that were worsening with increasing engine speed. Since those days, lift, velocity, acceleration, and jerk curves for cams have been modelled by computer[6] to reveal that cam dynamics are not what they seemed. With proper analysis, problems relating to valve adjustment, hydraulic tappets, push rods, rocker arms, and above all, valve float, became things of the past without desmodromic drive.
Today most automotive engines use overhead cams, driving a flat tappet to achieve the shortest, lightest weight, and most inelastic path from cam to valve, thereby avoiding elastic elements such as pushrod and rocker arm. Computers have allowed for fairly accurate acceleration modelling of valve-train systems.
Before numerical computing methods were readily available, acceleration was only attainable by differentiating cam lift profiles twice, once for velocity and again for acceleration. This generates so much hash (noise) that the second derivative (acceleration) was uselessly inaccurate. Computers permitted integration from the jerk curve, the third derivative of lift, that is conveniently a series of contiguous straight lines whose vertices can be adjusted to give any desired lift profile.
Integration of the jerk curve produces a smooth acceleration curve while the third integral gives an essentially ideal lift curve (cam profile). With such cams, that mostly do not look like the ones "artists" formerly designed, valve noise (lift-off) went away and valve train elasticity came under scrutiny.
Today, most cams have mirror image (symmetric) profiles with identical positive and negative acceleration while opening and closing valves. However, some high speed (in terms of engine RPM) motors now employ asymmetrical cam profiles in order to quickly open valves and set them back in their seats more gently to reduce wear. As well, production vehicles have employed asymmetrical cam lobe profiles since the late 1940s, as seen in the 1948 Ford V8.[7] In this motor both the intake and exhaust profiles had an asymmetric design. More modern applications of asymmetrical camshafts include Cosworth's 2.3 liter crate motors, which use aggressive profiles to reach upwards of 280 brake horsepower.[8] An asymmetric cam either opens or closes valves more slowly than it could, speed being limited by Hertzian contact stress between curved cam and flat tappet from accelerating the mass of valve, tappet and spring.
In contrast, desmodromic drive uses two cams per valve, each with separate rocker arm (lever tappets). Maximum valve acceleration being limited by cam-to-tappet galling stress, is governed by moving mass and cam contact area. Rigidity and contact stress are best achieved with conventional flat tappets and springs whose lift and closure stress is unaffected by spring force, both occurring at the base circle[9] where spring load is minimum and contact radius is largest. Curved (lever) tappets[10] of desmodromic cams cause higher contact stress than flat tappets for the same lift profile, thereby limiting rate of lift and closure.
With conventional cams, stress is highest at full lift, when turning at zero speed (engine cranking), and diminishes with increasing speed as inertial force of the valve counters spring pressure, while a desmodromic cam has essentially no load at zero speed (in the absence of springs), its load being entirely inertial, and therefore increasing with speed. Its greatest inertial stress bears on its smallest radius. Acceleration forces for either method increase with the square of velocity resulting from kinetic energy.[11]
Valve float was analyzed and found to be caused largely by resonance in valve springs that generated oscillating compression waves among coils, much like a Slinky. High speed photography showed that at specific resonant speeds, valve springs were no longer making contact at one or both ends, leaving the valve floating[12] before crashing into the cam on closure.
For this reason, today as many as three concentric valve springs are sometimes nested inside one other; not for more force (the inner ones having no significant spring constant), but to act as snubbers to reduce oscillations in the outer spring.[citation needed]
An early solution[when?] to oscillating spring mass was the mousetrap or hairpin spring[13] used on Norton Manx[14] engines. These avoided resonance but were ungainly to locate inside cylinder heads.
Valve springs that do not resonate are progressive, wound with varying pitch or varying diameter called beehive springs[15] from their shape. The number of active coils in these springs varies during the stroke, the more closely wound coils being on the static end, becoming inactive as the spring compresses or as in the beehive spring, where the small diameter coils at the top are stiffer. Both mechanisms reduce resonance because spring force and its moving mass vary with stroke. This advance in spring design removed valve float, the initial impetus for desmodromic valve drive.
Controversy[edit]
While the desmodromic system is not ideal in a practical world of mechanics, it still survives and performs without problem. While it can be more expensive to maintain than traditional spring-actuated valve systems, many aftermarket precision machined components can extend the maintenance interval to that of spring actuated systems (in comparable motorcycles).
While newer, high-performance pneumatic systems may follow more specific design and engineering specifications (computer-aided) they are typically limited to racing applications (Formula 1, Moto GP, etc.). Currently, there is no method of determining longevity or extended maintenance intervals of such systems in practical, everyday, systems such as the automobile.
While the design can be noisy, it is typically masked by wind noise and other engine components such as intake and exhaust noise. Though stated above the noise is "uncomfortably loud in engines with four or more cylinders", if true, this is limited (in terms of Ducati) to the MotoGP and MotoGP Race Replica bikes, which are the only current production desmodromic motors that feature four cylinders and are intended for racing. (Note that exhaust noise levels can exceed 110 dB on full race systems.)
« Reply #7 on: November 16, 2016, 07:26:47 PM »
Not Wheaties, but whole grain nasty cereal of some sort!   :boozing:
Bob
« Reply #8 on: November 16, 2016, 07:28:06 PM »
Kirby ... thanks for posting the write-up re desmodromic valve actuation.  Nice read.  And Wayne and Peter Y, good comments!
Bob
« Last Edit: November 16, 2016, 07:29:37 PM by ohiorider »
« Reply #9 on: November 16, 2016, 07:52:46 PM »
How far do you expect it to compress normally?
And, many manufacturers give a spec for testing valve springs, it's a minimum lbs. / Distance of compression sort of thing.
The first one I found said about 30-40# of pressure should mean about 5-7 mm of spring compression from free length.
That sounds relatively typical.
« Last Edit: November 16, 2016, 08:07:27 PM by Kev m »
« Reply #10 on: November 16, 2016, 08:10:02 PM »
 Yes , and those springs were out in the open air  :shocked:
 Seem to remember that Norton experimented with desmo systems around 1910 .
 Very interesting to read about IC engine development , not much is new , and what was once old can become new again , and the opposite can also happen . New materials , manufacturing methods , and simple serendipity allow for change . Before WW2 there was no consensus whether air or water was better for cooling aircraft engines . In fact , air cooling was not well understood , and if not for the US Govt pushing air cooling for its simplicity water might might have become much more common as a coolant .
