Author Topic: Attaching seat on a T3  (Read 2217 times)
Offline keuka4884
« on: November 21, 2016, 11:33:53 AM »
I want to eliminate the grab bars on my T3. The seat is attached at the rear to the grab bars. After eliminating the bars, how do I hold the seat down at the rear and still be able to raise it up to get underneath? Swoosh Dave, I see you did this. How did you do it? I imagine there is more than one way to skin a cat here so anyone that has done this, please comment. I'm open to all suggestions.
1978 850 T3
Offline swooshdave
Re: Attaching seat on a T3
« Reply #1 on: November 21, 2016, 12:12:27 PM »
IMG_9981 by swooshdave, on Flickr
I think someone said my old seat and bracket are from a G5/T5?
2001 V11 Sport
Offline Groover
    • Scooteropolis
« Reply #2 on: November 21, 2016, 12:28:56 PM »
1st Generation G5 and/or 1st Generation Convert - the ones that have the rectangular taillight with cowling.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #3 on: November 21, 2016, 12:43:14 PM »
I'd probably just cut the grab rail portion of the seat mount/grab rail off. I can show you what I mean if it's not clear and I have another grab rail if you don't want to cut yours.
Offline siabeid
« Reply #4 on: November 21, 2016, 03:39:32 PM »
On my t3, I cut the rear loop off leaving about a 3/4"" or so stub on each side and put black plastic caps over the cut off ends. It looks like it came that way and also leaves the horizontal grab bar in place to help put it on the center stand or to attach bungees to if you are carrying something on the passenger part of the seat. It looks and works good, and took about 5 minutes.
Offline Gliderjohn
« Reply #5 on: November 21, 2016, 03:51:45 PM »
I cut and capped the rails. You can see it fairly well in this picture. Is something like that what you are wanting to do?
Back in central KS
Offline Rob in Austin
« Reply #6 on: November 21, 2016, 07:59:18 PM »
A few dollars flat stock and minutes with a drill and vice grips...
