Author Topic: Side gas tank panel removal help - 2016 Eldorado  (Read 2186 times)
Offline Skyguyz
« on: February 10, 2017, 12:33:08 AM »
I have to remove a side panel on my gas tank on my 2016 Eldorado to get to the wiring harness plugs for my Guzzi multimedia and for the OEM fog lights to be installed. I removed the front and back retaining screws but there is a "Trick" to finding the mid fastening device???
Any link to a shop manual possible or any advice would be appreciated.
Thanks in advance,
Sky
Offline Zoom Zoom
Re: Side gas tank panel removal help - 2016 Eldorado
« Reply #1 on: February 10, 2017, 05:08:57 AM »
Leave that alone and just lift the tank a little if you have to. All additional wire connectors are up front under the plastic cover on the front of the tank. More on that in a second.
The side covers have a screw under the eagle, which will likely end up with broken tabs upon removal. That will require buying a set of eagles to put back on the tank.
So, for the front cover, remove the two screws on the top piece, take the gas cap off and move that piece backwards to release the pin from the hole in the back. There are a couple Allen heads down low in the plastic piece and a phillips screw around the steering neck. Then there are some plastic expansion pins down lower. Pop the center of those out and then you can lift the two pieces out from behind the steering neck. Wire access is there. The plugs for the fogs are on the right side, but the feed connector is on the left. The factory plug is also switched so those lights go off with the high beams. IIRC, there is a switched, but always on wire when key is on, in that plug. I used it for a feed to an SAE connector for powering my GPS. Since I did the factory lights, everything was plug and play. I probably spent more time routing the wires than I did connecting them together.
For something, ah I remember, a USB, and lighter outlet, that I wanted always on even with the key off, I was able to use a fish tape and get a wire from the front to the back to the battery. That way, I'm able to charge things when the bike is sitting if I need to. (Cell phone for instance.)
John Henry
« Last Edit: February 10, 2017, 05:11:43 AM by Zoom Zoom »
Offline mtiberio
    • TiberioRacing
« Reply #2 on: February 10, 2017, 06:57:02 AM »
what he said. to remove the eagles with out damage is tough. Maybe if you were deft with some fishing line, and could push the tabs at either end toward the center simultaneously, while at the same time fighting the double sided tape. When I had a 1400, I had a set of spare eagles on the shelf waiting for the day. If I ever had the side panels off, I was going to drill a small hole through the eagle to give access to the screw head.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline swmckinley54
« Reply #3 on: February 10, 2017, 08:23:30 AM »
Also take note on the screws that hold the chrome gas tank trim to the tank. when I unscrewed mine the threads that are located on the flange of gas tank came out with the screws/bolts. Seems that they were cross threaded by either the factory or the dealer. My solution was to use those body clips that holds fairings together. I inserted the clips onto the flange and found two screws/bolts that were a 1/4" longer. Problem solved.
Steven Mckinley
Austin, TX
2016 Eldorado
Offline Skyguyz
« Reply #4 on: February 10, 2017, 09:54:47 AM »
swmckinley54 - mtberio - Zoom Zoom,
Thank you all for the very quick and really accurate response to my dilemma. There are many forums out there but the kindness, help and general knowledge here from most members is astounding!
Thanks again,
Sky
