Author Topic: 850-T Turnsignal/Horn/Lights Switch  (Read 5419 times)
Offline swooshdave
« on: March 24, 2017, 01:49:48 PM »
https://www.harpermoto.com/t-s-horn-switch-17750301.html
Harpers has some of the original switches still available. The crappy Yamaha one on my bike needs to go away.
I was thinking of either getting the original T style one, which I assume will crap out in a couple years or get the later one from MG Cycle.
http://www.mgcycle.com/index.php?main_page=product_info&products_id=4352&zenid=f2df6869df6ef36fc2627b34b0d03249
I'm obviously ok with not staying original.
Thoughts?
2001 V11 Sport
Offline Yeahoo Whoyah
Re: 850-T Turnsignal/Horn/Lights Switch
« Reply #1 on: March 24, 2017, 02:30:39 PM »
Did you look here? http://www.kandstech.com/index.php?page=switchescontrols
Other opinions here, Topic H for handlebar switches.
 http://www.thisoldtractor.com/moto_guzzi_tonti.html#H
Greg Tillitson
El Dorado Hills Calif.
Offline Idontwantapickle
« Reply #2 on: March 24, 2017, 02:42:57 PM »
Since you're not worried about keeping it stock I would recommend the K&S or similar. Much improved over original.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline guzziownr
« Reply #3 on: March 24, 2017, 02:55:33 PM »
I have had a K&S on my Eldo for 14 years.  No issues, would buy again but don't have to!
Offline swooshdave
« Reply #4 on: March 24, 2017, 02:57:21 PM »
How do you order the K & S stuff? You have to find a dealer? I can just get switches off of eBay and they would be better than the stock one. For some silly reason I want to keep a Guzzi switch on it.
It has a Yamaha switch on it now (that looks like ones on TOT but doesn't actually match up to the wiring, someone has hacked the wiring)
Any experience with the later MG switch shown? Are they also as useless as the original ones?
2001 V11 Sport
Online Matteo
  • Alaska Guzzi's on Facebook
« Reply #5 on: March 24, 2017, 03:49:50 PM »
Dave, I've never had a problem with the left hand switch, still have the originals on all .
Now the start /kill switch is a different story. I've had to replace two of them. Opted for the one offered by MG.
Offline swooshdave
« Reply #6 on: March 24, 2017, 05:23:55 PM »
Yeah, my starter switch won't last long so I've also been looking for something there too. Including modifying the key switch to also start the bike, if that's possible.
If I could get the Yamaha switch sorted it might work but the wiring doesn't match anything I've found. While it looks like the ones on ToT the wiring doesn't match.
2001 V11 Sport
Offline Testarossa
    • Skiing History
« Reply #7 on: March 24, 2017, 05:26:33 PM »
I've used the K&S switches on my T for years, and used them on the Triumph when I rebuilt it.  Lots of sources -- mgcycle, amazon, ebay etc.
Offline Mark Dasher
« Reply #8 on: March 25, 2017, 07:19:14 AM »
I installed K&S switches on my T last year.  Greg Bender shortened the wires and installed molex connectors for me.  I also used his subharness and relay setup.  It's amazing how good it all works now!
'75 850T
'78 Robin
'06 Breva 1100
TOYS:
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper,
1988 Mercedes 560SL
Online Perazzimx14
« Reply #10 on: March 25, 2017, 08:48:48 AM »
I have this. Bought for a Tonti project that was sold before I got to use it. $45 shipped Sold in the lower 48.
Also have a diode board, regulator and NIB bow type timing chain tensioner.
« Last Edit: March 25, 2017, 09:16:26 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline swooshdave
2001 V11 Sport
Offline swooshdave
« Reply #12 on: March 25, 2017, 08:52:47 AM »
I have this. Bought for a Tonti project that was sold before I got to use it. $45 shipped in the lower 48.
Also have a NIB diode board, regulator and bow type timing chain tensioner. Will sell all together for $155.00 shipped
I'll take that switch. Look for a PM.
2001 V11 Sport
Online Perazzimx14
« Reply #13 on: March 25, 2017, 09:15:31 AM »
PM replied. I'll get 'er boxed up
Offline guzzista
« Reply #14 on: March 25, 2017, 10:33:11 AM »
My favorite so far. Have used K&S, generic CEV, Yamaha pot metal ones. All work fine, but the LM 5/ CAL3 SP3 types are my favorites. Here is a used one http://www.ebay.com/itm/Moto-Guzzi-LM5-handlebar-switch-for-lights-indicators-etc-from-LH-bar-/182467325820?hash=item2a7be66f7c:g:L8sAAOSwo4pYghU4&vxp A pic of a new one http://www.stein-dinse.biz/images/product_images/popup_images/27738015-z.jpg Note: US versions as some currently on EBAY, don't have the  "Lights off " option.
« Last Edit: March 25, 2017, 10:35:08 AM by guzzista »
Offline swooshdave
« Reply #15 on: March 25, 2017, 02:16:31 PM »
The LM5 ones are pretty nondescript. But I'm sure they are good switches. I believe Ducati went to Nippon Denso at some point. Did Guzzi do the same?
2001 V11 Sport
Offline Testarossa
    • Skiing History
« Reply #16 on: March 25, 2017, 07:37:12 PM »
I'd like to find a Euro spec switch for the Mille -- so I could turn off the headlamp for starting and idling. Could put in a K&S but don't want to splice into the good wiring harness.
Online Matteo
« Reply #17 on: March 25, 2017, 08:23:40 PM »
You don't have to, just replace the pins. A good electric / electronics supply will have them. Harpers has new connectorswith pins. Radio shack has the pin tool.
« Last Edit: March 25, 2017, 08:27:25 PM by Matteo Manfredi »
« Reply #18 on: March 25, 2017, 09:51:48 PM »
I'm sure Greg Bender could make you an "adapter" that is "plug and play". I'll be getting this one for my Convert:
Or he can supply the necessary Molex bits to do as MM says. An old section of brake line works great as a tool to remove the male pins.
Offline swooshdave
« Reply #19 on: March 25, 2017, 10:11:33 PM »
https://www.amazon.com/Connector-Remover-Computer-Extractor-Sleeving/dp/B0094MIS9U/ref=sr_1_2?ie=UTF8&qid=1490497662&sr=8-2&keywords=molex+tool
Getting the right crimper makes a huge difference. If you get a simpler one like below just take your time and you can crimp away.
https://www.amazon.com/DR-1-Crimper-DELPHI-Terminals-Barrel/dp/B00GD03NI2/ref=sr_1_65?ie=UTF8&qid=1490497800&sr=8-65-spons&keywords=molex+crimp&psc=1
2001 V11 Sport
Offline guzzista
« Reply #20 on: March 25, 2017, 11:42:32 PM »
The one that I posted the link for is a Euro type (headlamp off option)
Offline Testarossa
    • Skiing History
« Reply #21 on: March 26, 2017, 11:01:35 AM »
Guzzista:  Thanks for that link.  Looks like the solution!
