Author Topic: Mapping Guzzi Stelvio 2009  (Read 3977 times)
Offline bengrootde93
« on: March 29, 2017, 03:22:19 AM »
Hello,
I am Ben from the Netherlands.
I ride a Guzzi Stelvio 4v from 2009 with ABS
I enjoy it a lot but i was fiddling with guzzidiag.
Now i disable the lambda sensors, en the engine runs even better then before.
But i was wondering if there is a map available for my guzzi, wich would give my Guzzi even more torque from down below.
Its a stock Guzzi with a carbon mistral exhaust.
I heared it would run better on the mapping of a newer stelvio, but im not sure where to find those mappings.
Thanks in advance,
ben de Groot
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Mapping Guzzi Stelvio 2009
« Reply #1 on: March 29, 2017, 09:20:55 AM »
Ben,
 Beetle here makes mappings, look at griso.org They aren't  free but considered the time he put in, cheap.
Paul
Daytona 1225, Stelvio 1151
« Reply #2 on: March 29, 2017, 01:06:17 PM »
Most important question is has it been rollerised? If not, get it done before anything else and then worry about the mapping.
beetle
« Reply #3 on: March 29, 2017, 04:08:44 PM »
Ben, I don't have a map for that exhaust, but you are welcome to try the 1-lambda map I do have.
Offline Huzo
« Reply #4 on: March 29, 2017, 04:25:11 PM »
Welcome to the forum Ben. The two respondents to your posts (Beetle and Roper), are people you must trust. They have both contributed to my Norge and I reckon it is perfect. Enjoy your bike and don't delay checking what Pete Roper said, also ask for advice when you need it, from here. I will be in the Netherlands soon on my Norge visiting friends in Tilburg and Appledorn, and for sure we could meet and enjoy a coffee !! Also, do you understand the significance of checking if your bike has roller or flat tap pets ?
« Last Edit: March 29, 2017, 04:32:15 PM by Huzo »
Offline jiri.kaspi
« Reply #5 on: March 30, 2017, 02:15:56 AM »
Hi Ben,
I have Stelvio 4V 2008 with 1 lambda with stock intake and exhaust.
I remaped my bike befor twoo weeks by Beetle map. I feeling, the Guzzi is better in low RPM, slower ride is smoother (in city) and has lower fuel consumption (maybe 05l/100km).
It was my first experience with GuzziDiag, and remaps.
Jiri
Stelvio 08'
« Reply #6 on: March 30, 2017, 02:30:41 AM »
@roper: You are the first to tell me about the different cams, so if i get my VIN number i can get check if its been done by a recall?
Or how can i check if i have flat tappets or rollers?
@beetle Cool! When i got the cams done/checked i'll be sure the check out your maps!
@huzo I read some on the internet just now about these "rollers/ flat tappets" I understand it would give my bike a more linear power curve en better reliability?
You are more then welcome for a cup of coffee here in Heerenveen! Maybe we could go on a ride then, so i can show you some nice dutch roads ;)
ben
Offline Huzo
« Reply #7 on: March 30, 2017, 02:51:40 AM »
ben
I'll get an address and put it in my Tom Tom. We could look for some hills ???
Offline Huzo
« Reply #8 on: March 30, 2017, 03:28:17 AM »
ben
Yes ! Only one hour from Appledorn where I will be for sure, so grind some beans...Can you send me your address or e mail ?
« Reply #9 on: March 30, 2017, 03:44:10 AM »
ben
Ben, this has been covered many times before, just take a rocker cover off and have a look.
Here are two disassembled camboxes. The one on the left is e dead flat tappet box. The one on the tight is a roller tapper box.
You will notice that the holes in the LH box that the tappets run in are much smaller than the ones in the box on the right. The flat tappet motors also have a small 'Dumbell' shaped pushrod sitting in a *Tube* in the tappet. The Rollers have a *Bridge* with a tower on top.
If you still have a flat tappet engine it has to be rollerised or it will fail with possible worse damage.
Offline pauldaytona
« Reply #10 on: March 30, 2017, 05:37:40 AM »
Hi Ben, I put some in the past about it in the Dutch Moto Guzzi Club Nederland forum:
https://www.mgcn.nl/forum/index.php?showtopic=20116#entry308162
Paul
