Author Topic: 1977 Le Mans running and on the road  (Read 367777 times)
Offline Groover
    • Scooteropolis
Re: 1977 Le Mans Rebuild getting started
« Reply #30 on: May 10, 2017, 08:02:25 AM »
Here is a good site that explains some vapor blasting steps and results.
http://www.arnoldsdesign.com/Vapor-Blasting.html
The part to the right on this image is vapor blasted as final stage.
Image courtesy of the Arnolddesign.com site linked above
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #31 on: May 10, 2017, 08:49:42 AM »
Does vapour blasting give the "factory" look or does it come out a bit flat and without a sheen that new engines have ? Some finishes look ok, but if you touch them once with a greasy hand, you can't get the smudge off. Is that an issue with vapour blasting ?
I will let you know in a couple week's my machine should ne shipping by the end of the week. I coat all cleaned aluminum with ACF-50 which will be greasy until it dries, upon which dirt, smudge etc, just wipe off.
Offline Groover
    • Scooteropolis
« Reply #32 on: May 10, 2017, 08:54:03 AM »
ACF-50 is great stuff. I recommend it to anyone whom owns a chunk of aluminum  :azn:
1980 Vespa SI Moped
« Reply #33 on: May 10, 2017, 08:54:11 AM »
If you Google 'Vapor Honing Technologies' you will get to their site and it's full of You Tube videos that demonstrate all kinds of materials being vapor blasted, they explain the media selection, buying the right air compressor, charging the system and show you how the cleaning process works on various types of metals. I was really impressed with the carburetor cleaning. The finish is almost like a satin polish. I have seen examples of a 1960's Triumph 650 engine that had been vapor blasted and was very impressed with the finish.
I may be tempted to take apart some of the bikes I have finished and re-clean the alloy :wink:
« Reply #34 on: May 11, 2017, 02:19:28 AM »
Thanks very much, I will watch this space.
« Reply #35 on: June 11, 2017, 09:44:14 AM »
Progress is being made, albeit slowly, getting my Laverda SF1 on the road and running right, that sorted its back to the Le Mans.
The Vapour Blast cabinet has been working over time getting all the non painted or plated parts clean. I have vapor blasted with #7 glass bead followed by a hot soapy pressure wash and then into the ultrasonic cleaner and a clean hot water rinse, compressed air blast dry and then re blast again after a couple days. I have never before started an assembly with parts this clean.
Most all looks good but the rear main has some corrosion that is not worth reusing
Pistons are good but a new set or stock rings and big end shells are coming from Harpers (along with a set of NOS lower fork legs).
Bearings pulled out of the transmission case and cover, rear drive stripped, the pinion bearings need to be replace plus seals
Crank sludge trap was surprisingly clean, again I chalk that up to the Le Mans being a filter engine. I will replace the oil pump as new ones are now pretty cheap for oil filter engines
All the powder coating is done, flat black for frame components, wheel silver on the wheels.
Zinc plating and chrome plating is done and ready to start assembly.
Everything else in the motor looks good
Heads look good but the guides will be replaced, valves are pitted and will also be replaced with a new spring kit.
Tomorrow I head down to Phoenix to ride my R1150RT up to Canada winding through central California, Oregon and Idaho, a week of mountain solitude riding, priceless.
« Last Edit: June 11, 2017, 03:14:03 PM by canuck750 »
Offline swooshdave
« Reply #36 on: June 11, 2017, 12:41:12 PM »
If you come through Portland let me know.
2001 V11 Sport
« Reply #37 on: June 11, 2017, 02:16:47 PM »
Marvelous! Have a GREAT ride!!
« Reply #38 on: June 11, 2017, 03:11:03 PM »
Will do, I am thinking of heading from Palm Springs to Bishop and then cross one of the passes to the center of California, after that no plans.
Offline Rick4003
« Reply #39 on: June 11, 2017, 08:49:47 PM »
Hi Jim,
Fantastic stuff as always. I have long wanted one of those vapour blasting cabinets, yours are just making the itch worse. Looks fantastic.
Sounds good with your roadtrip! Have fun!
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
« Reply #40 on: June 19, 2017, 01:57:28 PM »
A box of parts where on my desk after returning from a weeks vacation, thanks to Harpers I have a NOS set of Le Mans MK I fork lowers to compliment the rebuild, and a new set of stock piston rings and big end shells. Pretty cool to unwrap some original Mandelo wrapping and see the original (less than perfect) paint finish on the fork lowers, low gloss black paint to boot.
Thanks Curtis! :thumb:
Offline swooshdave
« Reply #41 on: June 19, 2017, 02:05:10 PM »
Does that mean you need to lower the standards for the finishes of the other parts of the bike to match the NOS parts?  :violent1:
2001 V11 Sport
« Reply #42 on: June 19, 2017, 02:13:23 PM »
The thought has crossed my mind... how many times have you heard that the 'original finish' was never that good and that most restorations are 'over restorations'.
The Italians were not known for the quality of their paint or chrome and from what I have read Ducati was one of the very worst for finish.
Offline Rick4003
« Reply #43 on: June 19, 2017, 07:31:48 PM »
Hi Chuck
Glad you had a nice trip. Funny but not surprising that the NOS finish isn't as good as what you have finished yourself.
On the final drive, could you make a write-up on the fitment of new bearings, seals and the shimming of the bearings? I need to do my final drive too when I get home so it would be nice to have some expert knowledge to start out with :)
-Ulrik
« Reply #44 on: June 20, 2017, 11:50:37 AM »
Hi Chuck
-Ulrik
I am not swapping the ring and pinion so I will be leaving the stock steel shim as is for the ring gear, and I plan on  only replacing the pinion bearings and hope to not have to replace the pinion shims. That said I am replacing all the seals and bearings and will run some engineers blue over the gear mesh and record the imprint and see if I can make sense of the pattern as compared to the service manual. The Guzzi service manual black and white pictures are in my opinion pretty hard to read for what the correct mesh pattern should look like.
Offline Rick4003
« Reply #45 on: June 20, 2017, 10:40:27 PM »
For now I'm not planning on changing the bearings, but all the seals should probably be changed while I'm at it. If you could take some pictures along the way like you usually do, that would be a big help :)
-Ulrik
« Reply #46 on: June 25, 2017, 12:12:07 AM »
I could not get the front engine / frame bolt to come free, I had to cut the bolt off with a Sawsall hack saw blade to remove the motor. I soaked the engine front cover in Evaporust for three weeks and still the remnants of the bolt would not come free. I tried heating the aluminum cover, penetrating fluid and a press, nothing. I set the cover in my milling voice on my tiny bench lathe and drilled the damn bolt out.
And this is what was left
I turned the FAC damper heads to look more like the stock Le Mans fork caps, the FAC dampers come like this
A little machining they look more like stock parts
Assembled the forks, new progressive springs, I had the damper tubes zinc plated
Home made spring compressor to get to the snap ring
New fork bottom bolts and crush washers
Fitted two new fork seals
I put 50 ml of fork oil into the fork tube to keep the springs lubricated
New dust boots and the forks are done
I started on assembling the wheels, new bearings, zinc plated the spacer, I had the wheels powder coated with a clear top coat
Offline smdl
« Reply #47 on: June 25, 2017, 06:18:02 AM »
First rate work, Jim!  Thanks for sharing.
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
« Reply #48 on: June 25, 2017, 10:26:02 AM »
Thanks Shaun, only 99 +/ - more components to build!
Offline guzzinka
« Reply #49 on: June 25, 2017, 05:43:25 PM »
Awestruck as usual with your work - what is the story behind this particular Lemans, as in - how did you come to get it and what do you know of its history?  Looks like it led a rough life for a while....
Offline smdl
« Reply #50 on: June 25, 2017, 06:17:12 PM »
Lol.  Almost there, then.
Cheers,
Shaun
'61 Galletto
'24 Stelvio
« Reply #51 on: June 25, 2017, 09:39:01 PM »
Rear Wheel assembly, center hub replated and a new O ring
Tight fit it takes a big hammer to get it in
Snap ring
Brake disc bolts and cush rubbers
Drive plate
Simple press to pull the drive plate down
Rubber ring
Steel plate
Bearings and distance spacer
Brake disc
Rear wheel done
The front is a piece of cake, just bearings, distance spacer and two discs
Now to get some rubber on these wheels
« Reply #52 on: June 25, 2017, 09:40:40 PM »
I bought this Le Mans off a long time WildGuzzi member, I don't know how long he owned it or where it came from, I have owned it for a couple years and finally got around to rebuilding it
« Reply #53 on: June 25, 2017, 09:45:00 PM »
Assembling the bearings into the swing arm
The big drive shaft bearing is a snug fit, big driver and a big hammer
Snap ring to keep it there
Pivot bearings greased
New seals and test fit the spacers and pivot pin
Offline Rick4003
« Reply #54 on: June 25, 2017, 09:53:58 PM »
 :popcorn: :thumb:
Nice job Chuck, perfection as always :grin:
-Ulrik
« Reply #55 on: June 25, 2017, 09:59:48 PM »
I assembled the rear drive, new bearings, seals, O rings and gaskets
Getting the pinion nut off takes some real force
I pulled the bearings and put the shims back exactly as they where
Drove out the old races, pressed in new ones until they reach the stop
New O rings
Drive off the lower bearing
Note the shims
Drive on the new bearing
Put the shims, spacer and upper baring on, torque the big nut back on and peen the nut
Fit the snap ring back on
New seal in the case, then the brass shim
New bearing set
Drop the pinion cluster back in
Drop in the crown wheel and the distance spacer
New paper gaskets sandwich the steel shim
I heated the cover in the oven to drop the bearing in
Fitted the big seal and then new lock tabs and bolts
Then when it was all done I realized one of the drain plug threads was shot so I ran compressed air into the case while I drilled for a helicoil, worked great the alloy shards blew out the hole as I drilled
Rear drive done
Offline swooshdave
« Reply #56 on: June 26, 2017, 12:07:04 AM »
You sure you want to use a Helicoil and not a Timesert?
2001 V11 Sport
Offline Rick4003
« Reply #57 on: June 26, 2017, 09:14:59 AM »
Looks good, you make it seem so simple :grin:
How do you check the preload of the pinion bearings and what should it be?
-Ulrik
« Reply #58 on: June 26, 2017, 09:26:04 AM »
I don't have Timeserts and a Helicoil has never let me down in twenty + years of using them, especially in something as non-stressed as a drain plug. There has been lots of debate on this site in the past on the pros and cons of both systems, good points for both.
« Last Edit: June 26, 2017, 10:13:13 AM by canuck750 »
« Reply #59 on: June 26, 2017, 09:35:04 AM »
-Ulrik
Just take it all apart then put it all back together! I didn't replace the crown and pinion so I am hoping the shims / load does not change.
