Author Topic: 1977 Le Mans running and on the road  (Read 368096 times)
Offline Rick4003
Re: 1977 Le Mans Rebuild getting started
« Reply #60 on: June 26, 2017, 10:02:21 AM »
Sounds resonable, I will try and do the same to mine when I get home then. I have a leaking drain plug, so I will do the change of seals, bearings and helicoil the drain and level plugs.
Thanks for sharing your rebuilds, they give a whole lot of excelent infomation, tips and tricks
-Ulrik
Sent from my SM-J105F using Tapatalk
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
« Reply #61 on: June 26, 2017, 10:34:29 PM »
Transmission strip, clean up and inventory. This transmission is out of a 850T, I don't think it had many miles on it, the original Le Mans transmission went into Luca's 750S3. The S3 gears and dogs where just too worn out and I had to get a good transmission into the S3.
I heated the case and cover to 350 degrees in my shop oven to sweat the bearings out, the bearings are probably 'good enough' but I ordered a complete set from HMB Moto Guzzi so I am going to go ahead and replace all the case bearings
The shift forks show very little sign of wear, that's a first!
This gear dog and matching gear has some noticeable wear, I need to find a better set in my transmission spares box
Bearings, gaskets, O rings, seals, a new deep clutch spline drive and replacing the return spring should take care of parts.
Offline swooshdave
« Reply #62 on: June 27, 2017, 01:05:11 AM »
What's the difference between a T box and a LeMans?
2001 V11 Sport
« Reply #63 on: June 27, 2017, 09:43:59 AM »
Nothing
« Reply #64 on: June 28, 2017, 10:37:47 PM »
Picked up my wheels today from the local bike shop, they could not get the front tire to sit properly, claimed the powder coat was too thick inside the rim???
So I fit an axle into a vice and quickly spun the wheel why I ran a 120 grit disc across the flange
And a drum on the flat
And a micro band sander
Damn powder coat!
Back to the transmission, heated the case and cover up to 350F and then dropped the cold bearings into place
Thanks to Joe W for sending me a tutorial on setting the shift drum and forks,
I swapped a better 5th gear and dog
New bearing pack
And O rings
mostly back together,
done for the night
Offline Groover
    • Scooteropolis
« Reply #65 on: June 29, 2017, 08:00:20 AM »
I've have come across posts mentioning the powdercoat thickness causing problems like this, but other say it's not a problem. I would blame the seal on the new TL tires as being too "good". When I had my Pirelli Sport Demons mounted on my G5 (same rims as yours), the installer almost gave up on the front as well; It finally then popped into place when the PSI went over 100psi - mine were not powder coated, and I didn't even paint the inside either. Just factory finish.
Nice work on this, I'm enjoying this thread a lot. Is the tutorial Joe W sent you a public document published somewhere? I've found a few other out there, some by Pete Roper and others from this board.
« Last Edit: June 29, 2017, 08:01:10 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #66 on: June 29, 2017, 08:41:18 AM »
I've experienced this issue when mounting almost any tire to the original Guzzi cast lead/butter rims. The only thing that seems to help is Windex - yes, the stuff used to clean glass. Other brands don't seem to work as well even.
« Reply #67 on: June 29, 2017, 09:39:19 AM »
 Thanks for the info on mounting tires. I will drop the rim / tire off again and hope the shop is successful today
« Reply #68 on: June 29, 2017, 12:38:42 PM »
Sorry but I can't find the email Joe sent me. Similar to what Pete Roper explains but Joe has cut open a transmission case to allow for a full view of the drum and forks in place. Installing the detent plunger along with the gear clusters, shift forks and shift drum made checking play and engagement so much easier. It never dawned on me in the past to fit the detent to assemble the forks and fork shaft was going to make the assembly easier. Also Joe has found that in most cases the drum shims are needed on the back side of the drum to center the shift forks.
I don't try to tighten up the shift drum too much from what it was originally shimmed at, this may be going against common wisdom but I have a suspicion that the Guzzi engineers may have intentionally designed in the slack in the shift drum to reduce wear on the shift forks and the dogs.
On this particular transmission the shift forks where in such nice shape that I just put it back together with adding one very thin shim to the back (rear cover side) of the drum. There is still some end play in the drum even with a paper gasket between the cover and case with the cover torqued down.
I found that using a very long set of bent end needle nose pliers worked great for pulling up the 1st gear shift fork to get it to pop into the shift drum, the 'bent' end of the needle nose fits clear of the case / forks and then could be twisted 90 degrees to pull up on the closed needle nose to lift the shift fork. The typical hook puller has never worked well for me in the past to lift the shift fork.
Offline Groover
    • Scooteropolis
« Reply #69 on: June 29, 2017, 12:57:57 PM »
Good info. I'm far from digging into the transmission, and at this point I'm just gathering info and working on building up my confidence level to jump in at some point, so build threads like this one, are greatly appreciated!
1980 Vespa SI Moped
« Reply #70 on: June 29, 2017, 10:13:41 PM »
Finished up the transmission this evening, new gasket for the neutral switch
Checking contact to the shift drum bulb
Replaced the shift return spring
Fitted the cam bolt that centers the return spring pawl
Rotating the cam bolt moves the return pawl mechanism up or down to meet the center of the shift drum
I 'glue' the gasket into position with wheel bearing grease and use long bolts to align the cover to the case and not fold the gasket while the cover drops down
Then the shim that goes under the speedo drive gear
And then the gear
then the ball bearing that keeps the gear in place
the big nut torqued down
lubed the seal and then set it onto place
peen the nut
new deep spline drive
lock washer and nut
torque it down
O rings on the clutch rod
lube and install the active end of the push rod
and fit the clutch arm
done
Offline Rick4003
« Reply #71 on: June 30, 2017, 12:01:46 AM »
 :popcorn: Top notch :)
How do you adjust the cam bolt to center the return yawl on the shiftdrum? I guess it will be done after the end cover has been mounted on the gearbox, if so, how do you know that it is adjusted correctly?
-Ulrik
Offline Groover
    • Scooteropolis
« Reply #72 on: June 30, 2017, 07:30:29 AM »
Good stuff, nice job and thanks for taking the time to take the photos of the steps and parts!
1980 Vespa SI Moped
« Reply #73 on: June 30, 2017, 09:21:59 AM »
-Ulrik
The cam faced adjustment bolt has a range of about 3/4 a turn, I wind the bolt in hand tight, unwinding the bolt moves the shift pawl up and down, it needs to fall into alignment with the center of the shift drum, the hole in the transmission case cover for the shift drum is the center point. You don't need to be 100% accurate just get it as close as you can. if you keep unwinding the cam faced bolt it just  keeps moving the pawl the same amount, there is no additional adjustment possible beyond the original 3/4 turn.
Once the transmission and shift pedal is installed you can fine tune the adjustment bolt a wee bit to move the pedal / pawl to the centre between shift up / shift down.
« Reply #74 on: June 30, 2017, 10:32:46 PM »
Replaced the block to transmission studs with replated ones, the old studs will get replated for the next build
Locktight to keep them in place
Painted the underside of the block with engineers blue and then flat sanded the base of the block with a 400 grit sheet of sanding paper glues to a 18" square granite tile
Fitted the front bearing with new lock tabs and locktight
Refitted the sludge trap cap
New rear bearing, replaced the oil feed tube
I heat the case to 200 degrees in the oven, drop on a new flange gasket and place a couple studs into the case bolt holes to guide the bearing in, the hot case expands and the bearing just falls into place
I used schnor washer to fix the rear bearing flange to the block and dab of locktight
Thread sealant on the bottom two bolts that penetrate the case
JB weld mixed to fill the cam plug
New gasket on the big breather tube
New rear main seal lubed and ready to press in
The press tool works great setting the seal to just the right depth and square
Heads came back from the machine shop today with new guides, springs and valves
Offline swooshdave
« Reply #75 on: June 30, 2017, 10:47:02 PM »
What is the JB Weld for?
2001 V11 Sport
« Reply #76 on: June 30, 2017, 11:30:27 PM »
Sealing over the rear cam plug is a long standing recommended mod for all big blocks. I have never had one leak but its cheap insurance when you have the engine out of the bike. There is a lip in the block casting that the cap pops into, a smear of JB Weld in the recess lapping over the cap should keep it sealed for life.
Offline balvenie
« Reply #77 on: July 01, 2017, 04:13:28 AM »
Very good :thumb: and now I know what I need to install a new rear main seal in my bike.
Oz
04 Cali
« Reply #78 on: July 01, 2017, 02:25:29 PM »
The rear main seal installation tool is worth buying if you need to replace a rear main seal, the seal is very hard to get in square without the tool. Nothing fancy to it and one could make a seal driver with a proper bolt that matches the crank center thread and big thick plate or washer.
« Reply #79 on: July 01, 2017, 04:05:40 PM »
If I have the rear main bearing/flange out, I always install the seal into it before installing the bearing/flange into the engine case. Just easier for me.
« Reply #80 on: July 01, 2017, 10:01:18 PM »
Good call, that would be easier!
« Reply #81 on: July 01, 2017, 10:07:01 PM »
I got an hour in today and fitted new big end shells and con rod cap nuts, coated the shells faces with assembly lube
Torqued in t 24 foot lbs.
The piston pins where a real tight fit, even with the pistons heated to 350 degrees it took the pin press to get them in
Lubed the cam
The flange was in spec co I just milled three oil feed reliefs like the new flanged have
New oil pump, they are pretty reasonably priced these days
Offline balvenie
« Reply #82 on: July 01, 2017, 10:17:57 PM »
This is great :grin: :thumb:
Oz
04 Cali
« Reply #83 on: July 02, 2017, 10:37:11 AM »
Thanks Balvenie, I hope it is of some use to anyone interested in rebuilding a Tonti frame bike and in particular a Le Mans MK I.
I make no claims to being a mechanic or an expert, if anyone spots something I have done incorrectly, and that happens!, please post the error or send me a pm.
Cheers
Jim
« Reply #84 on: July 02, 2017, 12:41:05 PM »
This thread is a joy to watch...so envious of your skills!  :bow:
Offline toolittletime
    • mysportgear.com
« Reply #85 on: July 02, 2017, 06:09:51 PM »
Very nice job Jim....love to watch these threads, especially with all of the detailed pictures you post.
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Offline Rick4003
« Reply #86 on: July 02, 2017, 07:51:26 PM »
Tim
 :1: It is like a very detailed instruction in how to build a Moto Guzzi. It is great! :grin:
-Ulrik
« Reply #87 on: July 02, 2017, 10:15:12 PM »
Speaking of errors, here's one, the cam chain tensioner should be installed with the front bearing flange, so I pulled two bolts and the lock tab and fitted the tensioner. I then remove the wear bar and spring until the chain is installed
New endless chain and the gears cleaned up
The marks on the cam and crank sprocket need to align and the chain and all three gears need to be installed as a unit. 1st I fit the gears without the chain and line up the marks then carefully remove the gears and then fit the chain to them and press all three gears onto their shafts at once
Then the crank gear lock tab can be fitted
And the lock nut, round face to the engine, flat side out
Tightening both the cam and crank nuts at once work against one another and can be torqued tight, real tight!
One of the crank lock nut slots will have a star tab that can be bent over to lock the nut
The oil pump nut and lock washer with a dab of locktight
cam followers cleaned up
Lubed
Installed and then the cylinder base gasket and the 6 o'clock and 12 o'clock O rings can be installed
Make sure the gasket does not block the oil passage hole
Oil the piston grooves and fit the new rings
I lightly honed the cylinders with WD-40 and a fine hone
Ring compressor
Carefully tap the cylinder down over the ring compressor
Then remove the ring compressor and finish pushing the cylinder down
Fit the head gasket and make sure the oil hole is lined up
Drop the head on and fit four O rings over the block studs
Then fit the rocker frame and the wave washers
Special nut for the 6 o'clock stud
Then the other cylinder, now it looks like a Ducati!
Viton O rings on the 6 o'clock head plugs
head torqued down
Oil pressure sensor
Head oil feed pipe
The rocker parts
Distributor lock ring
crankcase oil breather one way valve
Made a pair of gaskets for the intake manifolds
The 6mm manifold bolts unique to the Le Mans
New rubber carb boots
Almost a motor now
Offline balvenie
« Reply #88 on: July 02, 2017, 10:29:42 PM »
Looks beautiful Jim. I can just imagine myself  having a severe case of the crazies, trying to install the three cogs fitted to their chain :grin:
Oz
04 Cali
« Reply #89 on: July 02, 2017, 10:44:42 PM »
I should have explained how to do it a little better, to begin I install only the cam and crank sprockets and line up the timing marks.
Next fit the chain around the two gears it will fit easily without the oil pump gear.
Now pull the chain and two gears off the shafts but not off the front of the engine and drop the oil pump gear into the bottom loop of the chain
Next push the whole thing back as a unit onto the shaft, wiggle it around until the cam pin and crank slot align and your home free,
Spin the crank and makes sure the cam and crank timing marks align
sounds a lot harder than it is
Cheers
Jim
