Author Topic: 74 Eldo timing  (Read 1503 times)
Offline toolittletime
    • mysportgear.com
74 Eldo timing
« on: June 30, 2017, 12:14:38 PM »
 I can't quite get the timing to advance enough for smooth idling.....do I need to remove the distributor and advance it one tooth, so it will be able to advance more?  If so which direction ??
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Re: 74 Eldo timing
« Reply #1 on: June 30, 2017, 12:19:33 PM »
Are you using the marks on the front pully and a timing light?
    • mysportgear.com
Re: 74 Eldo timing
« Reply #2 on: June 30, 2017, 12:20:48 PM »
Yes I am.
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Re: 74 Eldo timing
« Reply #3 on: June 30, 2017, 12:51:57 PM »
If you have 4 marks on pulley, it's the one all the way to the right @ 3600rpm or there abouts for timing the LH cyl. Turn dizzy  either way & watch marks. If you need to go more in one direction, the rotor shaft needs to go 1 tooth in the opposite direction when you put it back in.
For me to see marks line up, I look on an angle in between the forks. You can't see it strait on cause belt is in the way.
« Last Edit: June 30, 2017, 12:55:56 PM by guzzisteve »
    • mysportgear.com
Re: 74 Eldo timing
« Reply #4 on: June 30, 2017, 12:56:07 PM »
That's what I thought.........tha nks for the info.
Tim
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
Re: 74 Eldo timing
« Reply #5 on: June 30, 2017, 04:39:50 PM »
Before pulling the distributor, Make sure the TDC mark on the pulley is correct when the LH piston is at TDC on a compression strike. The pulley may not be installed correctly.
