Author Topic: How to make the SP sidestand more stable and convenient to use  (Read 2213 times)
Offline guzzista
In order to make my SP sidestand more convenient to use  as well as more stable, a solution that worked well for me is to use the LM4 sidestand (Thanks Big Rick !).http://www.stein-dinse.biz/Complete-partlist/Unsorted/Side-stand-kit-for-LM-5-Mille-GT-black::195075.html .Some folks on this board like Brown sidestands and that's OK, but I was looking for  Guzzi solution for a Guzzi problem.   Both center stand and transmission through bolts needed to be a tad longer on my bike in order to have sufficient thread to fasten the sidestand mounting plate, (which, BTW may be the only sidestand part needed and the other items :stand, pivot bolt, springs and spring plate re-used from your existing sidestand >> Red Suspender info). The mounting plate   http://www.stein-dinse.biz/images/product_images/popup_images/28434162.jpg was not currently available so having a complete stand was helpful. This course of action might also work on other non Police stand, non Footboards Tontis, however YMMV based on exhaust used and other factors that might cause interference
« Last Edit: July 15, 2017, 03:12:05 PM by guzzista »
Re: How to make the SP sidestand more stable and convenient to use
« Reply #1 on: July 15, 2017, 04:31:13 PM »
Put one of those on a customer's SP after the "Brown sidestand" didn't fit correctly. Worked just fine and was $100 less costly even with shipping from TLM in Holland.
« Reply #2 on: July 15, 2017, 05:11:37 PM »
Yep, best thing you can do is pull the stock sidestand and chuck the POS and get a Brown. Mine works great on the LMIII :thumb:
Offline guzzista
« Reply #3 on: July 15, 2017, 07:27:01 PM »
Just a quick revision to OP. Long through bolt (12mm) under tranny needs to be about 260mm . Center stand bolt about 55 mm. Both bolts  10mm longer  in order to bolt up the sidestand  plate correctly. A front engine bolt can be used by cutting additional thread then shortened as needed .
