Author Topic: Any Recent ECU Map Updates for CARC bikes?  (Read 3620 times)
Bonaventure
« on: August 05, 2017, 09:34:03 AM »
My new Stelvio won't be picked up for transport until probably mid to later this coming week.  Is there an ECU engine map update since model yr 2016 that I should call the dealership and request a Tech flash in the update if so?
Offline Xlratr
Re: Any Recent ECU Map Updates for CARC bikes?
« Reply #1 on: August 05, 2017, 09:40:20 AM »
There have been no factory map changes at all on the 2 Lambda Stelvios.
Sent from my iPhone using Tapatalk Pro
« Reply #2 on: August 05, 2017, 09:50:45 AM »
Unless you know Xlratr or Beetle.
Bonaventure
« Reply #3 on: August 05, 2017, 10:43:51 AM »
I don't know the meaning of this.  Have Xlratr and Beetle developed a tuned ECU map for the 1200 CARC's that one can flash on his own with a laptop, GuzziDiag, and proper cable?
Offline lorazepam
  • Almost ready for suspenders
« Reply #4 on: August 05, 2017, 10:56:18 AM »
Sounds like you have the meaning down just fine. Griso.org is where you will find maps.
« Reply #5 on: August 05, 2017, 11:09:10 AM »
Yes, nice 2O2 Stelvio map and Beetle has some nice ones too. Bikes I put them in usually have a pipe, so I need something.
Bonaventure
« Reply #6 on: August 05, 2017, 11:54:24 AM »
So the ECU tunes are mainly for if you've replaced the factory silencer/cat with an after market slip-on?
Offline Xlratr
« Reply #7 on: August 05, 2017, 12:22:40 PM »
A re-map can help improve the riding experience and power delivery in multiple ways, whether you use the standard or aftermarket exhaust. I would say give your Stelvio a try in stock trim first and see what you think. You then have a basis for comparison. If you then want to try a different map it's very easy using the cables and Guzzidiag as you mentioned.
Bonaventure
« Reply #8 on: August 05, 2017, 12:47:33 PM »
Thank you !!  :smiley:
