Author Topic: Transmission oddness (Safari AWD content)  (Read 3265 times)
Online rodekyll
« on: August 12, 2017, 07:53:18 PM »
 have a 1996 GMC SAfari van with AWD.  It's got about 160k on it now.  I has started to act oddly.
It started after an hour of stop-and-creep driving in ~80f weather.  It did not seem to be accelerating properly, and there was an intermittent "shuddery" feeling behind me, but not at the differential.  The shudder happens at the point of shifting, occasionally.  Also occasionally on neutral throttle, and occasionally when the t/c "locks" and "unlocks".  It's not sharp and bumpy, like going over rocks.  It's more of a "slippery" shudder, like slipping on those rubber dot-pads they put in the sidewalk at crosswalks.  I've wiggled the drive shaft and checked the fluid so far.  No clues there.
It's not happening often enough for me to be able to get a good feel for the source, but it does have me riding the Convert only, on account of I'm nervous about a total failure while on the road.  The Convert is a problem because the odometer goes nuts.  It reads 4 miles to the store, but if the weather gets warm and sunny, it can show 30 miles for the trip home.  Also, the trip home takes a LOT longer.  What's up with THAT?
But I digress.  Anyone got a thought on the problem?  I'll give more detail if that helps, but I need to know what is significant.  Last time I had oddness was about 40k ago.  The fix then was to drain and fill the transfer case.
Offline Chesterfield
Re: Transmission oddness (Safari AWD content)
« Reply #1 on: August 12, 2017, 09:31:15 PM »
Sounds to me ( no expert ) like sticking shift solenoids that I have experienced in GM automatics. Is it the 4T60E transmission?
Online RinkRat II
  • Lake Powell AZ
« Reply #2 on: August 12, 2017, 09:54:10 PM »
  Well now RK, 96 should be OBDII and if you can pull drivetrain trouble codes it should steer you in the right direction. Could also be simple like fluid and filter change.
       Paul B :boozing:
Online rodekyll
« Reply #3 on: August 12, 2017, 10:05:38 PM »
The heck, you say.  And all these years I was keeping it running without the codes.  I'll see if I can limp it in to NAPA and get a reading.  It's 7 miles away.  The Autozone is 40.  I don't want to drive it that far without a little peace of mind.  It will be fun to see what the computer has collected over the years.
Offline Two Checks
« Reply #4 on: August 13, 2017, 11:11:24 AM »
Typical symptoms of worn out fluid. Change, do not flush fluid and filter.
1987 1000 SPII "Il Duce' II"
« Reply #5 on: August 13, 2017, 01:38:10 PM »
Flush it if possible. Lot`s of misinformation on do not flush. Or pump out and replace at the same time, it becomes sort of a mini-flush then. If you`re lucky sometimes clearing codes works, but I doubt it from what you are describing.
Online rodekyll
« Reply #6 on: August 13, 2017, 02:05:44 PM »
Are you saying to not mess with the filter?
What is your flush routine?
Offline Two Checks
« Reply #7 on: August 13, 2017, 05:05:17 PM »
I am saying do not flush. Drop the pan and change both fluid and filter.
Flushing runs any swarf in the pan where? Think about it. Plus when the pan is dropped you can see if there is anything in the pan which will say its time for a rebuild.
If you flush the filter is still dirty.
Online RinkRat II
  • Lake Powell AZ
« Reply #8 on: August 13, 2017, 05:12:23 PM »
    100% :1: :1: :1:
      Paul B :boozing:
Online rodekyll
« Reply #9 on: August 13, 2017, 06:50:22 PM »
That's what I was trying to get clarified, thanks!
« Reply #10 on: August 14, 2017, 01:13:06 AM »
Of course drop the pan, take a look, change the filter. Then flush. If any swarf goes in the pan from a flush, that`s what the filter is for. There`s a reason machines to flush transmissions were made and it`s not to ruin your transmission.
« Last Edit: August 14, 2017, 01:16:04 AM by Chesterfield »
