Author Topic: Help needed to find neon bulbs  (Read 1541 times)
Offline nc43bsa
« on: October 04, 2017, 09:23:04 PM »
I need some 120 VAC neon bulbs to complete repairs on a stereo component.
They are 0.147" diameter and 0.450" OAL, with wire leads and an 8K ohm resistor.  My catalogs show a T1-1/4 with a diameter of 0.157" and OAL of 0.413", but it is rated at 65 VAC.
Anyone know where I can get these unicorns?
1990 MilleGT
Offline delrod
Re: Help needed to find neon bulbs
« Reply #1 on: October 04, 2017, 09:45:03 PM »
Damar worldwide damarww.com lots of stuff available
Call them. They are one of my customers embarrassed my self once by mentioning that the obsolete panel I was working on was probably done for because the bulbs would be too hard to find. The guy said follow me I'll show you what we do.
Doug in Pittsburg KS
2003EVT
Online Kiwi_Roy
« Reply #2 on: October 04, 2017, 10:02:12 PM »
I have some of the miniature bayonet cap ones, think old torch bulb size
a Dozen Model 5502 1.1" tall
They are yours if you want
I think these were intended for indicator lights as in illuminated pushbuttons etc
I expect this is more what you are after
http://www.bulbtown.com/A1A_NE_2_NEON_GLOW_BULB_WIRE_TERMINAL_BASE_p/a1a.htm
« Last Edit: October 04, 2017, 11:46:31 PM by Kiwi_Roy »
Online Kiwi_Roy
« Reply #3 on: October 06, 2017, 03:32:42 AM »
On the link I posted theres a video on how to identify the lamp, the guy just happens to have picked a T 1-1/2, very close to the one you are looking for.
I don't believe neons have a Voltage rating as such, like an LED you simply add the series resistor to burn up the excess Voltage. You must have an existing resistor you can measure.
I have found neons tend to fail after many years or the glass goes black, but then even LEDs don't last forever.
