Author Topic: Friend on Canadian Kaw Triples Board Found Guzzi Rear Drive Bearing Missing  (Read 5874 times)
This one is pretty strange.  I thought I'd post a link to the thread to see what the folks here think.  A friend recently bought a 2000 V11 and after riding it quite a bit, found that a bearing in the rear drive was completely missing.
http://triplescanada.proboards.com/thread/12252/horseshoes-lucky-charms
 Can't access it Jim .
I'm guessing the needle bearing was missing? Not the first I've heard of.
Offline nc43bsa
Same here.
1990 MilleGT
It's dead, Jim.
Darn, I didn't think it required logging in to read it.  He posted this photo:
He said the arrow shows where the bearing should have been.  Now he's wondering if a previous owner screwed up, or if the bearing has been missing from the start.
Hmmm.  Did he look at the ring gear?  I'll bet it's still on the hub . . . .
Offline nc43bsa
That sure is a clean housing.    :thumb:
1990 MilleGT
The pinion looks good. Isn't there another large bearing that supports the crown wheel?
They will know on the other board for sure.
« Last Edit: October 17, 2017, 10:33:26 PM by Kiwi_Roy »
He wrote: "the gears look good, shows slight contact wear on the outward edge. The axle however shows some wear, will need to mic it and see if it`s still in spec."
post images
Yes I was just reading over on VII Lemans
Apparently there has never been a bearing in there
It's not just the grease Luigi leaves out!
« Last Edit: October 18, 2017, 09:40:56 AM by Kiwi_Roy »
Do you mean that there is no need for a bearing there, and Guzzi never installed one at the factory?
The exploded view seems to show one.
« Last Edit: October 18, 2017, 08:51:37 AM by Triple Jim »
 It looks like it never had any oil in three either.
Online acogoff
     The needle bearings deep down in the axle hole in the top photo tells me it is different than the old tonti boxes I've been into?
« Last Edit: October 18, 2017, 09:35:32 AM by acogoff »
Marshall County Minnesota USA
Someone here on Wildguzzi found that the needle bearing was missing from their EV IIRC.
The V11 rear drive is a little different than a Tonti one:
The bearing that's missing is #12, part no. 92234055, 40 x 55 x 20.
Charlie, thanks for the information.  So you're saying the bearing should have been in there, correct?  The seal, #11 was also missing.  How does this thing go tens of thousands of miles with a missing bearing, and no apparent damage to anything?
Yes, the bearing should have been in there, how it was left out at the factory? Amazing. The seal is #10 (90403850, 38 x 50 x 7) #11 is a circlip:
My guess is between the large ball bearing and the drive splines, there was enough support to prevent any real damage. I'd be tempted to replace the large ball bearing #26 (92208014, 80 x 125 x 14) just to make sure it wasn't compromised by the added stress.
Offline swooshdave
Doesn't it mean this bearing took all the load?
2001 V11 Sport
Pretty Amazing, on the axle is 5 bearings. I'll bet it was built on Fri and finished on Mon.
Offline Bill Owens
Holy Sheet!
That's the one the rear drive housing pivots around the axle on, it could have taken some of the load as well.
Offline pehayes
In addition to the roller bearing and race at that location, there should have been an oil seal and a bronze thrust washer.  If the seal was not in there, all of the oil would have been on the road the day it left the dealership.  So, something is very different about this rear drive or something totally bogus about the story itself.  Otherwise, there is something very different about the design of the spine frame rear drive.  I've never been into one of those so I can't opine.  Someone with direct experience needs to chime in.  Pete?
Offline nc43bsa
I believe the seal you're referring to is shown in the picture of the ring gear, at the top, after it was pried out.
1990 MilleGT
I posted an illustration above of the the Spine frame rear drive. It's similar to earlier rear drives, but also a bit different.
There is a seal, but no bronze thrust washer, only a circlip.
Offline normzone
Are we sure it is not April 1st in Canada ? They do some things differently there, you know.
Offline shiloh
hi and thanx to Jim for posting here on my behave, havn`t been on here for a while.
the story, believe me is not bogus, let me fill you in on whats what.
The other day I torn down the rear end to solve or try to solve a leak.
The leak was from the inner seal, it was mangled, thats when I realized the bearing was missing, also the thick trust washer was a thin hardware store type washer, which now makes me think work was done wrong either at the factory or by some third party hack.
But that still dosn`t explain how it appears the bearing was never there, no impression a bearing was ever pressed in there???
I`ve checked everything out and believe it or not its all with in spec, though there is a bit of ware on the axle.
 I`ve concluded that the loads must have been shared among-st the other bearings.
I have ordered all the goodies I need to put this right, except the cir-clip, which is in place, it holds inner race in place.
There was oil in it... lol, red line shock proof, sticky shyte, but it didn`t stand up to a good diesel bath, much easier to check and fix when everything is nice and clean.
I`m going to think its was a factory, Friday late shift, on purpose, by a disgruntled employee f*** up. I`d hate to think Brent Mitton (incase he`s reading) fucked me over when I bought the bike, he`s such a nice guy, but one never knows
I've got one in bits at the workshop somewhere. I'll try and get some pics if I have time. The bearing in the case that allows the reactive movement on the wheel spindle offers no support to the crownwheel. That is done, as it is with the Tontis, by the inboard needle roller and the large, wheel side, ball race.
Even if it did work it would of been hellaciously noisy and I'm really surprised the crown wheel and pinion aren't rooted! Not doubting the veracity of the claim. Just very surprised!
Offline shiloh
exactly, that was my initial Q. when I posted on the other forum,,` how is it possible this thing didn`t detonate and destroy the bike.
Was it noisy, idk, I bought it, I drove it, hard to hear anything over the exhaust note.. lol, then it started to leak, I started to fix it...... then was unpleasantly surprised......
I've read in other Japanese bike forums recommendations to inspect certain parts of certain bikes because several members had early issues with lack of grease, poor quality parts, poor workmanship, etc.
Seems like one is better off if we could buy the bike in kit form and assemble it ourselves.
