Author Topic: V7ii Stornello shaft spline lube  (Read 18412 times)
Offline helipic
« on: October 28, 2017, 03:10:47 PM »
Hi all, I just got a Stornello last month.  Coming up to 600mi first service, I am thinking to take the rear end apart and lube the drive shaft splines.  Before dissecting into the brand new bike, I would like to hear from members here if there is anything I need to look out for to avoid screw ups.  Do they come well greased from factory already?  Many thanks in advance.
Offline SmithSwede
  • I don't want a pickle
Re: V7ii Stornello shaft spline lube
« Reply #1 on: October 28, 2017, 03:16:36 PM »
Splines on my 2013 V7 Stone were dry.   I say lube them up.  I use GuardDog 525 with 30% moly.
« Last Edit: October 28, 2017, 03:18:47 PM by SmithSwede »
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #2 on: October 28, 2017, 04:14:03 PM »
The most tenacious stuff I've ever found..
Wurth SIG 3000 spline grease, 14oz tube. High quality, extreme pressure/sling off resistant.
« Reply #3 on: October 29, 2017, 08:57:40 AM »
This ^^^ . http://www.mgcycle.com/index.php?main_page=product_info&cPath=23&products_id=1914
Offline ramarren
  • Not Quite Anonymous
« Reply #4 on: October 29, 2017, 10:02:00 AM »
Hmm. I'm coming up on my break-in service on Tuesday. Perhaps I'll ask them to check the drive shaft splined coupling and lube it if necessary...
Offline malik
« Reply #5 on: October 29, 2017, 03:12:22 PM »
And as they have the same arrangement as the other V7's (& small locks), every time you have the rear wheel off to change the tyre, take off the final drive to drain the collected water & re-grease the splines.
Only just did so with the '14 Special, but this time found a thick brown oily goo in there. Nasty seemly stuff. Indicative of a problem? Oil from the final drive squeezing past the seal? More investigation is needed and questions will be asked in appropriate places. Watch this space. BTW this bike has now done 96,000km.
Mal
Offline sign216
« Reply #6 on: October 29, 2017, 04:40:38 PM »
I wrote a guide for spline lube on the older pre-2013 models.  It might have a few tips for you.
Double click on the photos to get the text.
https://www.flickr.com/photos/sign216/albums/72157625569987011
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #7 on: October 30, 2017, 01:49:20 PM »
^^^^^^ Very nicely done, as usual, Sign..  attaboy.  :thumb:
Offline sign216
« Reply #8 on: October 30, 2017, 04:18:24 PM »
Thanks Chuck.  Unfortunately for this guide, I don't have any "assistant" photos.
I must correct that.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline pyoungbl
« Reply #9 on: October 30, 2017, 04:35:48 PM »
Sign, thanks for the photos.  I see that the splines are back by the final drive, not at the output shaft like on the Stelvio.  That's nice to know....much less to take apart.
'13 V7 Special (red/white)
« Reply #10 on: October 30, 2017, 05:08:21 PM »
You don't want the chocolate milkshake coming out and coating your bike.  :angry: Any grease is good.  Marine type better.  When you go to the factory museum.  Punch Guido in the face for me.  :tongue:
« Reply #11 on: October 30, 2017, 06:03:16 PM »
There are splines at the output shaft where the u-joint slips on as well. Wouldn't hurt to grease those, even though the swingarm needs to come off to do it.
« Reply #12 on: October 30, 2017, 07:10:29 PM »
Yep, it's really no big deal.
Small blocks, like Earth Girls.. are easy.
 :smiley:
Offline helipic
« Reply #13 on: October 30, 2017, 08:29:46 PM »
I just reviewed the parts schematics; there is a small spring within the spline sleeve pushing against the driveshaft.  What is the function of the spring?  Is the reassembly straight forward?
Offline SmithSwede
« Reply #14 on: October 30, 2017, 09:29:08 PM »
Malik:
About three times I pulled the swingarm and drained out nasty brown water.   What is worse, I would drain the final drive oil, and it would come out “water contaminated green.”    A build up of water in the swingarm will just sit next to the final drive seal and eventually work its way in.
I pulled the swingarm, removed the circlip and worked silicon goop all there.  Result was a waterproof swingarm.
Problem was it was also airtight, and the rubber boot would swell up as the air heated up and pressurized.
So I drilled a very small hole in the rubber bellows to bleed the air.    Result?  Past 40,000 miles and no water in swingarm, and no green contaminated final drive oil.
I think it’s worth doing.
« Reply #15 on: October 31, 2017, 08:47:20 AM »
The spring keeps the coupler in the right location. Yes, straight forward.. just don't put the spring on the wrong side.  :smiley:
Offline malik
« Reply #16 on: October 31, 2017, 04:32:40 PM »
Malik:
About three times I pulled the swingarm and drained out nasty brown water.   What is worse, I would drain the final drive oil, and it would come out �water contaminated green.�    A build up of water in the swingarm will just sit next to the final drive seal and eventually work its way in.
I think it�s worth doing.
Interesting.
On the V7C, I positioned the break in the boot's circling to the top & applied silicone around it. There has been some water inside the swingarm cover, but significantly less and there was still grease on the splines. I had thought about drilling a hole at the lowest point of the swingarm & tapping it to fit a drain  nipple. Theoretically the water should drain out.
Then just recently, I took the bevel box off the V7S and a muddy mix of oil, water & rust poured out. Ugly stuff. Unsure at this stage whether the oil's coming through the seal from the final drive, or from the gearbox. A bit of a worry. I'll drain both to see if I can't ascertain the shortfall over the last 5,000km since the last service. The V7S does not have silicone on the boot.
When I took apart the swingarm on the 23,000km Breva, the break in the boot's circling was facing up and the drive shaft was pristine though dry & no sign that any water had ever been in there (and no sign that the bike had ever been in rain, either).
Offline pyoungbl
« Reply #17 on: October 31, 2017, 06:46:27 PM »
I'll add just a bit to all the wisdom already offered.  Today I took the time to grease the splines on my V7.  It's less a PITA than the Stelvio...but not much.  Two things really took my time.  Getting the darn boot back on the tranny housing and then putting the rear wheel back on the final drive.  The latter has convinced me that I'll never attempt to fix a flat on this bike while on the road.  There is no way in  hell that I will be able to get the rear wheel off, break the bead, fix the tube, and put it all back together while sitting in a ditch.
With that said I'll mention a couple points that other small block newbees (like me) might find interesting.
no rust but also no grease on the tranny end
same on the final drive end
This is not to say that the sky is falling!  If you have the time and inclination it's a 1.5 to 2 hour job.  You'll need a couple large wrenches and a 27mm socket.  The other bits are common hand tools.
If you are a big block guy like me you will be surprised at the swingarm axle.  There are two of these stub axles, on on each side.  They screw into the swingarm and stick out into sealed roller bearings in the tranny case.  As I recall (and did) you are supposed to make sure the stubs stick out the same distance (from the swingarm body) on each side.
With all that said, I really do like my small block V7.  Every machine has it's 'character' points and the rear wheel mounting system is what I'll call character.  No wonder a shop charged me 1 hour labor to put on a new tire.  That was a real bargain!
« Reply #18 on: October 31, 2017, 07:28:02 PM »
As I said on another post the factory consider the shipping grease is enough for the bearings.
Sent from my shoe phone!
« Reply #19 on: October 31, 2017, 07:52:48 PM »
That is true with the big blocks, but..
*Unless they are different* from the old small blocks, those screws are just turned in until they contact the bearings. Location of the swing arm is by a big washer between the swing arm and transmission case on the D side. The big nuts are just lock nuts once this is done.
If you have the Photoblockit embed fix on your browser, all of this is detailed with pix on page 9 of the Lario Rehab thread on the "bike builds and rebuilds" area.
Offline helipic
« Reply #20 on: October 31, 2017, 08:51:13 PM »
This always puzzles me about the re-installation of the swing arm, how do you keep the small nut from turning while tightening the big 27mm nut to 50nm torque?  or do I just tighten up the big nut without holding the small nut stationary?
« Last Edit: October 31, 2017, 10:04:57 PM by helipic »
Offline pyoungbl
« Reply #21 on: November 01, 2017, 09:25:31 AM »
I did not worry about the stub axle turning when I tightened the 27mm nut.  That big nut is (as Chuck mentioned) just there to lock the stub axle in place so it does not back out.  There is a plug in the center of each 27mm nut so maybe you can insert the correct allen key to keep it in place.
« Reply #22 on: November 01, 2017, 01:05:41 PM »
Loops....you use a needle nose pliers or snap ring pliers.
Offline malik
« Reply #23 on: November 01, 2017, 06:42:47 PM »
The swingarm is aligned by screwing the LHS pin in until it just touches, then the RHS (with its spacer) until it just touches. Then the covering nuts go on & are torqued down. I'm continually impressed by the simplicity & elegance of this design.
« Reply #24 on: November 01, 2017, 07:00:00 PM »
The small block was developed after the big block, and they learned a fair amount. Many things are an improvement in design.
Offline SmithSwede
« Reply #25 on: November 01, 2017, 09:49:14 PM »
Go small blocks !
Offline OlofE
« Reply #26 on: November 09, 2017, 02:27:38 PM »
As a result of reading this I just had my 7500 mile V7 Stornello -16 in for shaft splines lubing. Much needed. The mechanic said that the splines were dry, only grease was a small smear on the shaft end. No damage however. Splines now embedded in LiquiMoly LM47 MoS2 grease and I feel much better. Thanks!
Offline malik
« Reply #27 on: November 09, 2017, 02:55:57 PM »
Good for another 20,000km, or whenever it is you next replace the rear tyre. Well done.
Offline helipic
« Reply #28 on: November 10, 2017, 02:57:53 AM »
Just did my 600 mi service with spline lube job.  I removed the entire swing arm and the drive shaft just to make sure everything is properly lubricated.  Contrary to what I read about bone dry splines on V7's, my Stornello's final drive coupling splines were lubricated with grease from the factory, thank you Luigi.  However, the u-joint spline and the trans output shaft were bone dry.  The disassembly was pretty straight forward.  I removed pretty much everything attached to the rear swing arm to ease the wheel removal and installation.  The hardest part of this entire process was the installation of the wheel while keeping the cush-rubber pieces in place. Reattaching the rubber boot to the transmission was a piece of cake.  I would like to thank you all here for the inputs which made this job less challenging.
Offline malik
« Reply #29 on: November 10, 2017, 01:52:30 PM »
Those cush rubbers can be annoying. Sometimes the wheel goes straight onto the hub with no problems, and sometimes it doesn't. (Leads me to suspect that there is an "Italian" secret technique involved). When it doesn't just slip on, no matter what you do, walk away for a bit, have a drink, chat with someone, whatever. Often when you come back to it, it works easily & quickly.
I usually have the centre stand up on a couple of blocks of wood, so that the wheel clears the mudguard easily. That also tends the give a little more room to move in there. If I take away the left hand block so that the bike is leaning to the left, (or do it on the sidestand), that (sometimes) helps the cush rubbers stay in their cups.
Usually it's not a problem, all goes well. Sometimes though it's a nightmare. Note that if the cush rubbers are worn, or twisted they seem more likely to catch the tangs of the hub & pop out midstream. I keep a spare set of rubbers on hand in case.
