Author Topic: Difficulty shifting up from first at stand still  (Read 7731 times)
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
Re: Difficulty shifting up from first at stand still
« Reply #30 on: November 03, 2017, 06:24:42 PM »
You will have loosened off the adjuster right off to get the new lever on, then re-set it. I leave the rubber sheath folded back until I'm happy with the adjustment. It's a bit of a pain, even with a touch of rubber grease. I also re-route the cable so that the 90 degree metal curve is pointing down rather than forward. That seems to help.
Thanks for the curve trick, I'll give it a try.  The rubber sheath moves without too much trouble, but I'd already left it back knowing work was still to be done.  The adjuster bolt, on the other hand, is a pain in the A$$!  It doesn't want to turn either way, even with the lock nut completely loose.
I just rode Anni around the neighborhood, and initially the clutch would engage at about 1.5" from the grip.  After half a dozen uses, it started to catch at .5" out, so adjusted back out to about an inch.  Hopefully it will stay there, as my fingers aren't too happy with all the adjusting.
Hitting neutral is still 50/50, but I didn't have to go into 2nd to get 'er into gear, just had to try 1st again.  Some improvement, is better than none. :thumb:
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
« Reply #31 on: November 03, 2017, 06:34:53 PM »
Lubing the barrel ends of the cable help.
Offline malik
« Reply #32 on: November 05, 2017, 02:19:42 PM »
......The adjuster bolt, on the other hand, is a pain in the A$$!  It doesn't want to turn either way, even with the lock nut completely loose.
That happened to me not so long ago. It was a pain & felt wrong having to use pliers on it It shouldn't be that way. I couldn't fix it, so I tried a new cable, with a mere smear of grease on the threads. Magic. Finger adjustments again.
I'll keep the old cable, clean it up & try it again sometime. And put a tag on it, telling the story of the problem, so I will know the cable is suspect.
« Reply #33 on: November 05, 2017, 02:39:16 PM »
I made a tool to adjust the one on my SP in 1981.  A piece of steel 1/8" thick 3/4" wide and 10" long. I cut a slot on one end wide enough to fit slot on adj.. Early tool kits had a short one bout 3" for doing valve adj and I hated working on hot bike w/it.
On the opposite end of tool cut the slot on the side then you can adjust every 1/4 turn.
Offline Guzzi Gal
« Reply #34 on: November 05, 2017, 04:31:23 PM »
It was a pain & felt wrong having to use pliers on it.
'Xactly!
"Miri" and Mori"
Offline sign216
« Reply #35 on: November 05, 2017, 09:05:19 PM »
And...I added a lock nut to try to keep things tight, but that's also a vain effort.
Just monitor it as always.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline freedom
« Reply #36 on: November 07, 2017, 12:08:11 AM »
Havin the same issue on my 2013 V7.
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." Bruce Lee
« Reply #37 on: November 07, 2017, 10:11:00 AM »
And the cable free play will change as the operating temp changes. Sometimes the accumulated tolerances are such that a happy medium can be found where it works hot and cold, mostly though I have to adjust it after it heats up. That's on small blocks as well as big blocks. I've no experience with hydraulicy actuated clutches
Offline voncrump
« Reply #38 on: November 08, 2017, 02:25:17 AM »
When I replaced the clutch on my 1100 sport I spent a lot of time shagging around with the adjustment. Then I made a decision to set the lever clearance when the bike has warmed up. When it is cold it has almost no clearance. When warm it has about 5mm. I haven't touched it since.
I also have a V711 and I have adjusted the clutch once. The lever clutch lever on a lot of Guzzi's has to be pulled right into the bar to get clutch release. Short levers with a dog leg can be a problem.
Cheers, voncrump.
1996 1100 sport
2016 V711
1988  Lario ( long gone )
1982 V50111 (long gone)
Offline TimmyTheHog
« Reply #39 on: November 08, 2017, 10:13:53 AM »
Cheers, voncrump.
My V7 is exactly this...not that excessive (1.5mm cold to 4~mm hot)...
Work well...might have a louder clunk when the bike is hot...but I have not miss a shift since the first 300 KM
Currently Bikeless...*cry*
Offline Kev m
« Reply #40 on: November 08, 2017, 10:28:52 AM »
FWIW, I made this adjustment to my 2013 Stone back in Dec 2012 and have not needed to repeat it since.
Offline mtiberio
    • TiberioRacing
« Reply #41 on: November 08, 2017, 10:46:35 AM »
My buddy brought his Guzzi Lemans 1 by my garage, he was having trouble shifting up from first. We discovered his crankshaft was broken in half.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
