Author Topic: whats involved in changing a rear seal in my ev1100? after the motors out  (Read 3845 times)
Offline troyhamilton
  • Dr frankie
so my rear seals leaking now . after the motors out, clutch is out whats involved with changing the rear oil seal
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline Mr Revhead
Re: whats involved in changing a rear seal in my ev1100? after the motors out
« Reply #1 on: December 20, 2017, 03:20:34 PM »
Carefully pluck the old one out, drive the new one in.
I made a tool out of some plastic plumbing pipe to drive it in.
I assume you have confirmed that is the leak? Mine wasn't. Mine was the gasket around the bearing carrier.
  • Dr frankie
« Reply #2 on: December 20, 2017, 03:28:49 PM »
i dont know yet. aint tore it apart. fire it up and it drips from the bellhouseing. see oil on the teeth on the ring. got coming from top.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Mr Revhead
« Reply #3 on: December 20, 2017, 03:30:52 PM »
Ok, oil on the ring gear sounds like maybe seal. Seeps out on to the flywheel and gets flung all over the place.
My gasket leak just dribbles out the bottom if I over fill it
  • Dr frankie
« Reply #4 on: December 20, 2017, 03:40:00 PM »
 could be wrong. im gonna keep an eye on it.
i havent rode it far since i put the motor in.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #5 on: December 20, 2017, 04:33:25 PM »
 if it smells like gear lube it's coming from the tranny up the clutch push rod.
Offline yogidozer
« Reply #6 on: December 20, 2017, 05:02:15 PM »
good advice, more common
« Reply #7 on: December 20, 2017, 05:04:58 PM »
If you just let it leak, then every 2000 miles you'll have done a complete oil change!  :boozing:
Online Chuck in Indiana
« Reply #8 on: December 20, 2017, 05:13:53 PM »
As mentioned, make sure it isn't transmission lube first. There are many places it could be engine oil. Another common and simple fix is the breather hose.
« Reply #9 on: December 20, 2017, 05:14:26 PM »
One quick check is to pop the timing plug and see if I can find fluid on the front of the flywheel and engine side bellhousing.  That would indicate engine oil.  If it's on the back of the flywheel and clutch (might have to pull the starter for a good look) then assume transmission grease.  This check is not 100% accurate and works best before there's so much oil flinging about that it's on both sides.
Another way to sort the type is to collect some fluid from the drip on a q-tip (or similar wick) and burn it along with samples of engine and tranny fluids like a redneck mass spectrometer.  The flame will look and smell like the matching sample.  If it doesn't, it's both.
Offline normzone
« Reply #10 on: December 20, 2017, 05:41:45 PM »
I'm have an external auditor in the house this week, but when I saw "redneck mass spectrometer" I had to give you props.
Thanks for that technique, I will remember.
 :bow: :thumb:
  • Dr frankie
« Reply #11 on: December 20, 2017, 06:01:59 PM »
its motor oil...
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #12 on: December 20, 2017, 06:50:54 PM »
It could be coming from the cam plug, many leak from there so when the flywheel is off clean it well and put on your favorite sealant, cover the dern  thing with J B weld, Proseal etc. avoid silicone. it'ks an item to do anytime the transmission is off.
« Last Edit: December 21, 2017, 08:31:21 AM by John A »
Offline flangeman_70
« Reply #13 on: December 20, 2017, 09:37:02 PM »
If you do change the seal be aware there is no bottom out when driving/pressing it in. The result is you can insert it, the seal, too far and then block an oil passage. I did this myself but realised my mistake before doing any catastrophic damage. Only my pride was hurt and I had to wait an extra week to repair it.
Good luck!
Adam
Adam
SP III 1990
V10 Centauro 1996
Orange Guzzi
« Reply #14 on: December 21, 2017, 12:59:14 AM »
Another source of oil in this area is the crankcase vent return hose.  It connects to a tube at the top of the bell housing.  It oil can leak out of the connection and run into the clutch area.  I found this to be the source of the oil in my bike clutch area.  I did replace the seals in tranny and rear main while in there though.
« Reply #15 on: December 21, 2017, 04:42:07 AM »
What year? There have been several venting systems.
  • Dr frankie
« Reply #16 on: December 21, 2017, 04:49:27 PM »
motor is a 98 ev1100 pete. i can find no oil leaking any where other than the botom of the bell housing. i was too busy to pull the starter today. thanks for every ones input. im useing a breather box from the 850 t chassis kinda cobbed up for a return...in a 850 t chassis
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Dilliw
« Reply #17 on: December 21, 2017, 05:04:46 PM »
Orwig fixed mine and it wasn't the main seal.  It was the rear cover gasket.
George Westbury
Austin, TX
Offline Chet Rugg
  • Administrator
  • Chet & Rusty ( 99 Bassa )
« Reply #18 on: December 21, 2017, 07:12:51 PM »
get some seal conditioner pour in motor and ride.  I think p205 at napa. but not sure on that # but they got it.
since the bike hasn't been far since you got it running maybe the seal just needs a little living up!
Cheap try before tearing it all down again.
I did that on Rusty for along time before tearing it down. Made it to 91000 probably started leaking at 60000
Chet Rugg
99 Bassa
01 Cali Special
100,000 miles
  • Dr frankie
« Reply #19 on: December 21, 2017, 08:11:12 PM »
thats what im thinking too. i only put 3 quarts in it so i know i didnt over fill it Chet. just getting depressed lol...
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Dilliw
« Reply #20 on: December 22, 2017, 08:41:38 AM »
For what it's worth mine leaked for about 50k before it got fixed :)
George Westbury
Austin, TX
