Author Topic: Suddenly it all became quite clear !  (Read 3711 times)
« on: January 09, 2018, 10:31:10 PM »
For anyone who's happy with the stock mirrors on their early Norge, there's no need to read on..
But.
Mine has had the handlebar mounted ones since new and I've been ok to accept that, up till now.
Up to 100 kph, they are pretty much clear, but between 100 and 130 they become fuzzy, and above that they're useless.
So here's the thing...
I took the mirrors that JDGretz GAVE me and unscrewed the mirror from the stem.
Then I ran a thread onto the end of the stem that has the blank reduction turned on the diameter and wound that end back into the mirror.
A suitable size hole bored through ONE side of the screen mount allows the (now reversed) mirror stem to be poked through the hole and a locknut placed on the inside.
This results in mirrors that are fairing mounted and isolated from the "vibrations" at the handlebar ends.
As the pics will show, I put a rubber sleeve between the stem and the fairing, to stop any tendency for the mirror to "wobble" as opposed to "vibrate", ( there is a difference).
The mirrors are 700 mm outside to outside which is somewhat narrower than stock, but given that they are further from the eye, there is not much reduction in rearward peripheral view. I can see the corners of the top box in both mirrors simultaneously, I've accepted a slight trade off in field of view, for the gain in vibration free vision.
To see completely behind while riding, I need to bring my elbow in slightly, but still better than the stock set up that I had on my MV Augusta F4.
Anyway...
Just thought I'd mention it.
« Last Edit: January 10, 2018, 01:41:43 AM by Huzo »
Offline ITSec
Re: Suddenly it's all become quite clear !
« Reply #1 on: January 09, 2018, 10:38:26 PM »
An interesting approach, but seemingly at odds with some things I've observed on my Norge.
My GPS (mounted to the windshield supports) vibrates more than my mirrors in the stock locations. Also, my mirrors vibrate less(!) on the HeliBar risers (longer and higher) than they did on the factory risers. There's more to this than is obvious, apparently, but any shared experience is helpful to us all.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #2 on: January 09, 2018, 10:39:10 PM »
:1: Good for you!
:sad: Anni doesn't have a fairing.  Looking into her vibromirrors I can see there are vehicles behind, just not with any detail.  Is the driver texting, looking my way, wearing a ski mask and brandishing an uzi?  Eff if I know!
« Last Edit: January 09, 2018, 10:40:14 PM by Guzzi Gal »
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
« Reply #3 on: January 09, 2018, 10:54:39 PM »
Can't comment on the GPS thing I'm afraid. Mine is a Touratech and is mounted to the top steering clamp.
I'm guessing that the different length of the Helibars has a different relationship between the centre of mass of the riser and the mount.
I've forgotten more than I ever knew about simple harmonic motion... :embarrassed:
« Reply #4 on: January 09, 2018, 10:56:25 PM »
:1: Good for you!
Halfway along the second line of your response GG, suggested a hundred lines of quippy banter fodder, but perhaps it's better that I don't.  :boxing: :evil:
« Last Edit: January 09, 2018, 11:12:08 PM by Huzo »
Offline Ozrider58
« Reply #5 on: January 09, 2018, 10:59:12 PM »
But.
I took the mirrors that JDGretz GAVE me and unscrewed the mirror from the mount.
Then I ran a thread onto the end of the stem that has the blank reduction turned on the diameter and wound the stem back into the mirror.
Anyway...
So when are you off to join the design team in Mandello? Lol
Sent from my F8131 using Tapatalk
« Reply #6 on: January 09, 2018, 11:03:31 PM »
No bloody point mate..
Can't speak Italian !
But for the record, I'll be there in 2019 and 2021.
I'll have to Go Pro most of 2021, 'cos it's odds on that I won't remember much.
« Last Edit: January 09, 2018, 11:14:27 PM by Huzo »
Offline Ozrider58
« Reply #7 on: January 09, 2018, 11:32:21 PM »
You won't be by yourself in 2021 that's for sure mate
« Reply #8 on: January 09, 2018, 11:34:28 PM »
The last two times I've been over, the seat next to me on the A 380 has been empty... :wink:
Offline ITSec
« Reply #9 on: January 10, 2018, 01:08:48 AM »
You won't see that on flights from North America!  :cry:
ITSecurity
« Reply #10 on: January 10, 2018, 01:16:20 AM »
It's the tight arsed Australians who won't pay the extra money to get the exit row seat with no one in front of you.
Offline Ozrider58
Re: Suddenly it's all became quite clear !
« Reply #11 on: January 10, 2018, 01:17:04 AM »
Sounds like you'd better change your brand of deodorant ha ha!
« Reply #12 on: January 10, 2018, 01:20:46 AM »
What manner of wizardry is this substance called "deodorant" of which you speak ?
Perhaps that's why there was no one else in the restaurant the night you wined and dined me in Stoke.
At least I kept the flies off the meat !
And now that I think about it, you were rather insistent that I showered before we went to bed !!!
Only your best friends will tell you.. :kiss:
« Last Edit: January 10, 2018, 01:24:46 AM by Huzo »
Offline Guzzi Gal
« Reply #13 on: January 10, 2018, 11:41:48 AM »
 :thumb: Good-natured banter is always welcome, as long as there are no additional expectations.  Sometimes at work, almost everything that came out of our mouths could be interpreted as a sexual innuendo.  We ran with it and had fun until we were all played out.  I've worked with men (warehouses, wineries, electronic retailers) all my life if I couldn't go with the flow work would have been miserable.
"Miri" and Mori"
Offline Matteo
  • Alaska Guzzi's on Facebook
« Reply #14 on: January 10, 2018, 12:22:02 PM »
You can join Galluzi in California, you should be able to communicate there. :boozing:
« Last Edit: January 10, 2018, 12:22:19 PM by Matteo »
