Author Topic: ev11 gearbox oil leak  (Read 5607 times)
Offline oranges3
  • "this amp goes to eleven..." Nigel Tufnel, Spinal Tap
« on: March 04, 2018, 04:37:58 PM »
just changed the oil on my 2003 ev11 hydro
went for a ride and there is oil all over the bottom of the tranny and it looks like it is coming from the gearbox vent tube... it is redline HD shockproof. i know i put in the proper amount.
what shoud i look for first?
« Last Edit: March 09, 2018, 12:11:50 PM by oranges3 »
2012 ducati diavel
1995 Triumph Speed Triple
1998 Triumph Thunderbird Sport
2004 V11 Cafe Sport
1999 Confederate America GT
2018 Motus MST
2007 griso
1986 kawasaki ninja 600r
183 Honda VT500 Ascot (son's bike)
Re: ev11 oil from gearbox vent tube
« Reply #1 on: March 04, 2018, 05:09:18 PM »
Did it have Shockproof in it before the change? It is so tenacious that it all won't drain out. If you refill with the "correct" amount, it will be overfilled. Don't ask me how I know.  :smiley:
« Reply #2 on: March 04, 2018, 05:10:24 PM »
Most likely if you look in fill hole it's all foamed up inside, one reason I don't use it. I seen too many messes.
Also make sure the trans vent hose is routed over and up behind the frame top rail like stock.
« Last Edit: March 04, 2018, 05:48:31 PM by guzzisteve »
« Reply #3 on: March 04, 2018, 05:42:26 PM »
Double check the vent line from the bottom of the air box. It is common to get oil from the airbox and it drains near the back of the transmission. The oil is blown out the crankcase vent if you overfill the engine and run it a bit hard.
Offline oranges3
« Reply #4 on: March 04, 2018, 08:03:17 PM »
i did not have the redline stuff in there before
what would cause the gearbox oil to come out of the vent?
tomorrow i will check out the routing oof the hose.
are there any "improvements" one could make on the breather system?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #5 on: March 04, 2018, 08:06:43 PM »
How much did you put in?
« Reply #6 on: March 05, 2018, 08:47:44 AM »
As I said, you changed the oil. My money is it is coming out the airbox because you overfilled the engine oil..
The transmission vent hose is to near the rear of the battery. Is the oil from back there?
The airbox vent is near the rear of the trans. Is it from there?
« Last Edit: March 05, 2018, 09:53:15 AM by Wayne Orwig »
Offline oranges3
« Reply #7 on: March 07, 2018, 05:48:26 PM »
so you are saying that if i overfilled my engine oil, that would make my transmission oil come from the transmission vent tube?
please educate me here.
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline oranges3
« Reply #8 on: March 07, 2018, 05:52:15 PM »
the oil coming from the vent tube is redline shockproof
anyone ever come up with a vented fill plug for the transmission like i have seen for the final drive oil fill plug?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #9 on: March 07, 2018, 06:20:04 PM »
Read the last line of his post .
Offline oranges3
« Reply #10 on: March 07, 2018, 06:25:19 PM »
i did read it
it is not eng oil... it is redline shockproof coming from the vent tube.
what am i missing here?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #11 on: March 07, 2018, 06:30:32 PM »
i did read it
Did you drain it completely? If so, then 750 cc of gear oil.
A vented fill plug would need a long vent hose attached or gear oil would just burp out of it. Not necessary since there's already a transmission vent...
« Reply #12 on: March 07, 2018, 07:38:06 PM »
sounds like it was overfilled.  Open the level drain, put a rag under it and let it dribble out for 20 minutes.
when it stops draining, it should be at the right level.
« Reply #13 on: March 07, 2018, 08:57:18 PM »
If it absolutely is the pink milk shake stuff, then pull the level plug on the right side. As I mentioned, the vent line goes up and back to near the back of the battery. Is that where it is from? I have never seen a 5 speed vent oil.
Any chance that you cracked the drain plug. They are hollow with a magnet and easy to break. Which drain plug did you use? The bottom one, or the rear one? The rear cover one doesn't drain to well unless the front of the bike is a bit higher.
« Last Edit: March 07, 2018, 09:07:01 PM by Wayne Orwig »
Offline oranges3
« Reply #14 on: March 09, 2018, 12:11:20 PM »
ok... did some exploring on the guzzi:
airbox is dry as a bone.
transmission vent line is dry as a bone
i have pepto colored oil on the rh lower part of the drive shaft.
the fwd shaft boot clamp was loose enough to move by hand.
there is oil all over the bottom from the wind spreading it around.
looks like i have a leak... anybody want to chime in?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline oranges3
Re: ev11 gearbox oil leak
« Reply #15 on: March 09, 2018, 12:13:16 PM »
i also removed the leveling plug and nothing came out... oil is at the proper level.
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #16 on: March 09, 2018, 12:33:15 PM »
I'd say u-joint boot leak from loose clamp or a crack in rubber, that's if you have same oil in the rear drive.
Offline oranges3
« Reply #17 on: March 09, 2018, 03:04:02 PM »
so there is oil inside the boot that could leak out it if it was loose?
i may have found my problem....
steve, this is the 2003 ev11 you did the recall on while at riders hill
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #18 on: March 09, 2018, 03:28:27 PM »
Right, oil vapor is supposed to go up the shaft from rear drive and lube u-joint & splines but it may not happen.
You could slide the boot back on one side and inspect or stick your little finger in there.
Offline bigbikerrick
« Reply #19 on: March 09, 2018, 03:44:54 PM »
If you have the pink milkshake in the rear drive, it could be migrating up from there, if not , possibly the rear output seal on your transmission may be the culprit, allowing oil into the u joint boot.
Rick.
Offline oranges3
« Reply #20 on: March 09, 2018, 05:30:23 PM »
it looks like it is coming feom the boot
i do have pepto in ghe rear drive also....
is this a problem?
is the final drive lube SUPPOSED to migrate fwd to the ujoint under the boot?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline pehayes
« Reply #21 on: March 09, 2018, 06:48:28 PM »
The 2003 has a swingarm with a very long enlarged section to hold the compound u-joint.  The carrier bearing is locked in place by a grub screw on the bottom side.  Is that screw loose?  Could oil be leaking there?
« Reply #22 on: March 09, 2018, 07:05:53 PM »
"is the final drive lube SUPPOSED to migrate fwd to the ujoint under the boot?"
Yes, there's a 1/8 moon cut-out on the pinion bearing housing and a little tunnel matching it on the flange it bolts to.
AND like Patrick said about the grub screw on the underside holding a carrier bearing  in place.
« Reply #23 on: March 09, 2018, 09:02:11 PM »
Any chance the rear drive was overfilled?
On my 2004 EV, it leaked a bit around the set screw (grub screw) under the carrier bearing. I simply cleaned it off and wiped a bit of sealant on it. It is normal for some lube to migraite up towards the boot. But, the boot and everything should keep the lube in, and water out.
Offline oranges3
« Reply #24 on: March 09, 2018, 09:09:25 PM »
anyone got a pic of the grub screw or at least the location?
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
Offline pehayes
« Reply #25 on: March 09, 2018, 11:36:35 PM »
Cant find a pic, but here is the factory diagram.  Screw comes in from the bottom in that expanded area of the swingarm.
Offline Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
« Reply #26 on: March 10, 2018, 02:18:16 AM »
This is what mine looked like.  Misreading the manual, the previous owner had put 750ml in the rear drive instead of 250ml.
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
« Reply #27 on: March 10, 2018, 08:47:56 AM »
Common since the manual calls the rear drive a 'transmission' I believe.
Offline oranges3
« Reply #28 on: March 10, 2018, 09:15:56 AM »
i think i found the grub screw on the swing are and it was wet
what do yohu use to remove\tighten it?
also decided to check the amount of pepto in the final drive... opened the leveling plug with the bike on the centerstand, also slightly jacked the front up so the rear wheel was on ground and it started trickling out...
im gonna leave it like that till it stops.
also found the fuel level sensor plug and manual fuel tap leak... oh well.
ill fix it all one thing at  time.
one thing i also noticed...the tank does not sit center when mounted
it looks like the wire harneses are routed all together on too of the frame... is this correct?
if anyone has a pic of how the harnesses under the tank SHOULD look i would appreciate it.
2012 ducati diavel
2004 V11 Cafe Sport
2018 Motus MST
2007 griso
« Reply #29 on: March 10, 2018, 09:48:30 AM »
I noticed what you describe as the gas tank being off center, on my 03 aluminum, the gas tank would lean to the left. I think it was caused by the weight of a full tank of gas when the bike was sitting on the kickstand, leaning left. The rubber cushions that hold the gas tank center are soft, and will "give" with the weight of the tank.
that problem can be solved by replacing all the rubber bits, and or putting the bike on the centerstand.
In my case mounting a sidecar, where the bike is always upright, solved that issue.
I dont think the wiring under the tank is the culprit, as tere seems to be plenty of room between the harness and the tank tunnel.
Rick.
