That could be a lot worse than it looks...i would start with "the bike is totaled"...until proven otherwise....Think of the twisting motion put on the frame by pushing on the front wheel while on the side stand...forks tweaked? Steering head twisted? Frame bent? Painted rippled off an opened weld? Just the front rim replacement is like $400-$600 at a dealer?.....if bent then replace
When the forks are tweaked, you might just loosen up the fasteners and let it unbind until it settles straight. Then make sure it's square and bolt it back up.
After this^^^ a quick check of wheel alignment with a straightedge or fluorescent tube will give a indication if something's tweaked. Most shop manuals will give frame dimensions and as some disassembly will be required. Paul B
I'm not sure of how you could check the fork tubes without dissasembling them but it's important for you to trust they are good. I wanted to say check the bottom steering head bearing housing for deformity, that's where the get messed up on a front end hit.
I assume you mean a straight edge from the back tire to the front along the edge? Yes, and here's a link to explain https://www.cycleworld.com/2014/02/21/ask-kevin-whats-the-best-way-to-check-motorcycle-wheel-alignment Paul B
Was the bike in gear when it was parked? If not I doubt the frame was damaged. Put the bike on the center stand and put a jack under the pan and lift the front wheel off the ground. Spin the wheel to see if its been bent.Then take a a flat plate of metal or glass that spans the fork legs above the sliders and see if it rocks.If so loosen the triple clamps, remove the jack and pump the forks. Tighten the triple clamps and check the forks again with your flat plate. If it doesn't rock the forks are OK. Pete
Would that be enough out of round for the slight up and down motion I feel in the handlebars?
You should have called the cops when it happened. That way you would know if he has insurance and who they are.
